Anyone have an ICBM? Need some help
  • baniels
    • Nov 2006
    • 158
    I have an original Outlaw ICBM. Somewhere in the years of not using it, I misplaced the power supply. I am trying to find a replacement. I have put in word to Outlaw, but I was hoping someone here with one might be able to snap a picture of it.
    The specs on the product page aren't clear enough for me to find one. I've tried entering what I could from there onto Mouser, but it yielded no results.
    If you have one that is accessible, could you take a picture of the part of the power supply that shows the input/output details/specs?
    Thanks in advance.
    •L&R Build•
    •Sub Build•
    Okay. Here's the power supplies from my ICBM.
    (couldn't resist)
    • baniels
      • Nov 2006
      • 158
      Thanks for the thread bump.
      Next...
      •L&R Build•
      •Sub Build•
      • dyazdani
        • 7032
        A quick search on the web indicates that the power supply is 15VAC, 300 mA...
        Mouser Possibility
        Danish
          Aw, you guys are so serious.
          No fun...
          • baniels
            • Nov 2006
            • 158
            As stated, I already know the specs listed on the product page. Can you tell me if there are other variables to the power supply spec that I ought to be considering?
            Thanks for pointing out that product. Looks promising.
            Mouser Possibility
            •L&R Build•
            •Sub Build•
            • dyazdani
              • 7032
              Polarity and the connector size are two obvious things that you will need to sort out. Other than that, I am not a power supply expert, I've only matched the rated outputs for times I've had to come up with a supply.
              Danish
              • baniels
                • Nov 2006
                • 158
                I just spoke with a tech at Outlaw. Apparently the power supply that shipped with these units listed 16VAC on them, and he said anywhere from 15-18VAC would suffice.
                I think this means I did not lose the power supply and that either the one I have is broken, or there is something wrong with the unit. I had tried the one I have with 16VAC on it, but it did not turn on the green light. That is what led me to believe I had lost the original.
                UPDATE: The 16VAC wall wart I had appears to be dead.
                •L&R Build•
                •Sub Build•
                • Glen B
                  • 1106
                  I have a never used 16VAC 300mA wall wart power supply that came with my old Monolithic Sound PS2 phono preamp that you can have for free if you want. Just reimburse me for shipping. The only thing is, it has a DIN type connector on the end, so you would have to cut that off and splice on the right connector.
                  • baniels
                    • Nov 2006
                    • 158
                    Wow, Glen. That's a very kind offer. I'm going to dig around a little more this weekend. I'm pretty sure I have a few more wall warts tied up in my ball of miscellaneous cables and wires (we all have one of these, right?). If I can't find one, you may be getting a PM.
                    •L&R Build•
                    •Sub Build•
                      Oh yes, believe me, you aren't the only one. Mine has become an overgrown medium-sized packing box full of them, as time goes by.
