Power Supply
  • Trevor Schell
    • 10936
    Power Supply
    I am about to pounce on a new case, however I can buy this case with a 300 watt power supply included or a 420 watt power supply.
    What would be sufficient. In what I have seen so far, the 300 watt size seems to be most common. So why would there be a 420 watt supply available? What would you need it for?,, or is more better.
    Thanks.
    Trevor
    My HomeTheater S.E.
    Sonically Enhanced
    C5
    Trevor
    XBOX 360 CARD
    • 16101
    Well, Trevor,
    If you have a power hungry CPU, lots of RAM, and a high performance GForce video card, that ups the ante for base system power. Note that Pentium IV systems even have a special 12V connector for extra power for the CPU.
    Then, there's peripherals. One or two hard disks. A CD-R or CD-RW; a DVD-ROM drive. A sound card. An NIC card, if its not on the motherboard. USB power. Etc.
    Then, many modern power supplies use variable speed fans; depending on power usage and heat buildup, the fan speed varies. If you want a quiet system, a 400W supply running at 65% of capacity may be a better bet than a 300 watt supply running at 88% capacity. But don't make assumptions; check out the MFR's specs.
    As a former mil/aerospace power supply designer, I feel more comfortable if the supply isn't working too hard. Plus, I've seen too many PC problems arise because of marginal power supply behavior- I think I recall KennyG having some problems in that regard last year.
    Best regards,
    • P-Dub
      Office Moderator
      • 6766
      More power is always the best route. You have to ask?
      Paul
        • 16478
        trev this isn't like you Go big or go home LOL
        • Trevor Schell
          • 10936
          ,,OK Guys.
          I guess that was a crazy question.
          Thanks Jon for the excellent explanation, really appreciated.It all makes sense now..420 it is.
          Trevor
          My HomeTheater S.E.
          Sonically Enhanced
          C5
          Trevor
          XBOX 360 CARD
          • Bing Fung
            • 6523
            Nothing for me to add here...
            Bing
            Bing
            • Trevor Schell
              • 10936
              Padding your post count Bing.
              My new baby will have a nice 400 watt power supply.
              The Antec SX1040 in Black.
              Trevor
              My HomeTheater S.E.
              Sonically Enhanced
              C5
              Trevor
              XBOX 360 CARD
