Entry level tube/valve amp advice
  • pedro77
    • May 2010
    I'm interested in getting a tube amp and was hoping someone here may have listened to a couple of the amps I'm considering. I basically got interested when I read some rave reviews about the great value of the Miniwatt S1, which has since been superseded by the N3.
    As 2 of these amps are shipped directly from manufacturers I haven't been able to audition them myself. I have gone to a local stereo store and compared a Prima Luna Prologue One and the Cayin A-55TP and to my ears the Prima Luna sounded amazingly rich and superior to the Cayin.
    I'd like to set up one of these amps to listen to music on my front speakers (Orpheus Aurora 2.3) over an Airport Express streaming lossless music files. And for convenience possibly have the tube amp connected to the front pre-outs on my surround amp and have the tubes drive the fronts for all sources.
    So my current list is out of three amps which span the entry level price point and all use different tube types. They are:
    1. MiniWatt N3 ($480 AUD delivered) 2x3.5W 1x12AX7 2x EL84 Pros- Cheapest Cons- Perhaps underpowered although a couple of positive reviews say it's enough
    2. Neuhaus Labs T-2 ($934 AUD delivered) 2x20W Tubes 4-6N7 2-6N1 2-6N3. Pros- Includes Optical and USB in and has remote control and headphone out Cons- Is the digital input just a gimmick and is the DAC in the Airport Express or Onkyo 705 sufficient?
    3. Prima Luna Prologue One ($1500 AUD demo stock with scratch RRP $2500 AUD) 2x35W Tubes 4 x EL-34, 2 x 12AX7, 2 x 12AU7. Pros- I've listened to it. Saving $1000 for a scratch. Cons- Minimal features for price. Is this overkill for entry level?
    So if anyone has any opinions I'd really appreciate your advice. Reviews on all of these has been positive, as are most reviews I've looked at on entry level tube amps. It's hard to find a good comparison guide. Look forward to your thoughts.
    Cheers
  • twitch54
    • 340
    Of the three you mention I'm only familiar with the PrimaLuna, with that being said I can't imagine the Miniwatt N3 being capable @ only 3.5 watts no matter what 'the reviews' said....remember, the room demensions and accoustics Do have an effect. While your speakers are quite efficient there's just no amount of head room with that little amp and I suspect your highs will be noticeably rolled off and forget about control in the bottom two octaves.
    As for the Neuhaus, again I have no working knowledge of that piece either
    as for real advice, here's mine.........if this is your first foray into valves / tubes stay with a well known company if for no other reason than ...SUPPORT, Warranty, etc. I believe Prima Luna in conjunction with Upscale Audio gives you that.
    I will offer you one or two other affordable suggestions as well......Rogue Audio and Jolida. I own both and know the owners of both companies and consider them to be fine components for the $$ spent combined with excellent support.
    Dave
    • pedro77
      • May 2010
      Hi twitch
      Thanks for the advice and info. Bit the bullet and went with the amp I first heard and liked immediately...the PrimaLuna Prologue One. It was more expensive than I had originally planned but it was nearly half its retail price and it's sounding awesome so far. A nice, rich and warm sound and a great soundstage that sounds like I have the centre speaker running as well.
      Thanks again for the helpful thoughts and tips.
      Cheers
      Pete
      • jpedro
        • Jun 2010
        Oi Pedro77,
        I have a PrimaLuna Prologue one. Is the best buy.
        With a B&W 805s is a sweetness.
        Cheers,
        JPedro
        • 2gumby2
          • Jun 2010
          • 21
          Take a look at what Niteshade Audio has to offer at the link here. I think Blair could set you up with something you would like.
            I've never heard any of the Niteshade lines, but if they sound like they look then WOW! Beautiful amps. :T
            • Jnorth1178
              Step up from Prima Luna
              by Jnorth1178
              I need some sage advice. I have always thought I would like to get into Mcintosh amp and preamp but never had the necessary cash. I presently have Prima Luna 3 pre amp and the Prologue 6 amp. I know very little about the Mcintoshes. Was wondering what you would suggest in a Mcintosh that would be...
              30 December 2008, 23:20 Tuesday
            • brendon
              entry level 5.1 speakers B&W vs Mirage vs M&K
              by brendon
              Hi guys .I got a day off recently and with no wives and kids hanging around snuck out to tour a few local Hi- Fi retailers to get some idea what sort of 5.1 speaker sytem I should look at to go in my small HT room (3.8m x 4.5m 70% 2 channel and 30 % 5.1 usage).
              I had the B&W 602 series 3...
              04 December 2004, 08:57 Saturday
            • Boombox
              Tube or Solid state amp: PrimaLuna ProLogue Two - Rotel RB1070
              by Boombox
              I am by no means a hi-fi/home theater equipment reviewing journalist. I live in the real world where kit is not delivered to my door from the distributor for the latest issue of hearmystuffissocool.com or hifioverthetopcostnooption magazine. I am a student using all my savings to buy bang-for-buck new,...
              08 December 2006, 15:35 Friday
            • Zerileous
              Would like to upgrade my TT setup - entry level
              by Zerileous
              Here is what I have (please don't judge):
              TT: Ion Profile Pro - integrated pre
              Amp: Orb Mini T - this is a very small class-t amp, 20 watts per channel
              Speakers: Pure Acoustics Dreambox (specs) 8ohm, 80W RMS, 3" drivers.
              I'm really not satisfied with this setup....
              08 May 2019, 22:22 Wednesday
            • Jnorth1178
              Trade Prima amp for McIntosh Mc7270
              by Jnorth1178
              My son and I traded amps yesterday with the provision that if either of us wanted to trade back we could. He took my Prima Prologue 6 and I took his Mcintosh MC 7270's. i wish we could have done an a-b. I like both. If I had to make a hard choice right now it would be difficult. Wonder if any of you...
              27 January 2009, 11:47 Tuesday
