MC=less volume and dynamics
  • Mike_Schmidt
    • 48
    I moved into a Dynavector Karot MC from a Rega Exact MM. I moved my phono stage into MC and set it @100K. But I have lost my volume and dynamics even at 2 bells on the dial. My dealer thinks that my Moon LP3 is the problem and isnt a true MC phono stage and does not have the oomph for this low voltage cart. I believe its 0.5v. Anyone have ideas and Im already thinking of moving into the Dynavector phono anyhow from the Moon.
    • 1913
    You've probably tried this, but just some thoughts here. Have you tried adjusting the gain, loading, and capacitance settings on the Moon LP3? I'd think 60dB gain would be enough, but I guess that would depend on the gain of your preamp. Is 100k ohm loading the recommended for that cartridge. Seems kind of high for a moving coil.
    John unk:
    • Mike_Schmidt
      • 48
      Yes its a 100 ohm's and the DC resistance is 38 ohm and its rated at 0.3mv. I switched it to a 100 on my phono. As far as I know there is two settings 47k for MM and 100 for MC. Thanks for your help.
      • braxus
        Phono Stage on Rotel RC-985 Preamp
        by braxus
        Im new here. I have a Rotel RC-985 preamp hooked up to a Rotel RB 1070 amp running B&W 602 S3 speakers. Im currently using a Thorens TD 147 turntable in this setup.
        Im wanting to upgrade my cartridge on my Thorens to a Ortofon Rondo Bronze which is a $900-1000 MC cartridge. Some have...
        03 September 2010, 00:07 Friday
      • nicholtl
        Phono stage? What's that??
        by nicholtl
        Hey all, so I've been doing some research and getting interested in adding a turntable to my system. Lately, I've been looking at the VPI Scout with JMW 9 arm, which is usually sold as a package on several online sites like audioclassics or acousticsounds. Some of you guys might know of it from a...
        28 November 2004, 03:42 Sunday
      • miner
        Rotel phono pre
        by miner
        This weekend I upgraded to the RC-1082 from my RC-1070. Got 25% off of retail without asking. Anyway, this will be used in my analogue setup with a Rega P7 TT and Dynavector DV20XH cartridge. The onboard phono stage sounds good to me but I am wondering what else I may be missing - I have never had...
        11 December 2008, 17:19 Thursday
      • collectslps
        Upgrade from MF A300 Integrated's Phono Stage
        by collectslps
        Hi.
        I'm hoping you might suggest a phono preamp for me as a step up from the one standard in my Musical Fidelity A300 Integrated. If you know, how does the one that's in the amp compare to MF or other phono pres?
        My other gear:
        Rega 3 w/ Dynavector 10x5...
        29 September 2010, 21:34 Wednesday
      • Burke Strickland
        New version of Parasound Halo JC3 phono preamp -- JC3+
        by Burke Strickland
        Parasound has introduced an improved version of the highly regarded JC3 phono preamplifier, the John Curl designed JC3+.
        Press Release:
        Parasound Introduces the Halo JC 3+ phono preamp — An improved JC 3 from legendary Vendetta designer, John Curl.
        20 December 2013, 20:30 Friday
