External sound from PC
  • BWLover
    • Jan 2009
    • 552
    i have a laptop that i want to connect to my stereo. when i used a Y adapter (3.5mm to RCA) i get a hiss in the background from the crappy sound card in my laptop. what would be a good cheap external sound card. all i need is RCA (red and white) outputs. i have a Toshiba qosmio g30. I think i would need either a USB or fire wire sound card. suggestions?
    Bowers & Wilkins 683 Speakers
    Rotel RB-1090 2 Channel Amp
    Rotel RC-1082 Stereo Pre Amp
    Rotel RCD-1072 CD Player
    Pioneer PDP-5070HD 50" Plasma
    Playstation 3
    Shaw HD PVR
    Primacoustic Room Treatments
  • mjb
    • 1485
    This isn't really a "club rotel" question, you might like to try posting somewhere else.
    Either way, a few minuets with google is bound to throw some suggestions. I like the small M-Audio Transit USB adapter.
    - Mike
    Main System:
    B&W 802D, HTM2D, SCMS
    • Ferres
      • Jan 2007
      • 158
      The Rotel RC-1082 has the 'media player' connection. Try that one.
      • Audio_ElF
        • 271
        Agree not really a "Rotel" question ...
        I don't think the "Media Player" connection is anything different from normal RCA inputs than front panel and 3.5mm jack convinience.
        If you're happy spending the money - try looking at the Devil Sound DAC Cables http://www.devilsound.com/. Very good sound (for the money - $400) and very convenient.
        Eloise
        • BWLover
          • Jan 2009
          • 552
          sorry about posting in the rotel thread. didn't know where to put the question
          Playstation 3
          Shaw HD PVR
          • BWLover
            • Jan 2009
            • 552
            i've heard about the M-Audio unit. have you used this unit? is there any background noise from it?
            Playstation 3
            Shaw HD PVR
            • aarsoe
              • 795
              According to the CNET review, your mobile has SPDIF output. I would use that and connect it to what ever you have that can accept such a digital signal. At least try it before you spring for a new sound card on what is effectively an "old" notebook.
              • BWLover
                • Jan 2009
                • 552
                my laptop does have that but only via HDMI. I can use the HDMI while at home, that is no problem. but I do a little amature djing at local parties and need something else. the m audio unit seems to look good.
                Playstation 3
                Shaw HD PVR
                • shtali
                  Question regarding sound card - B&W 685
                  by shtali
                  I have an HTPC with an onboard sound card.
                  I have Rotel PRE 1070 + POWER 1070 + B&W 685
                  The quality of sound coming out of the HTPC is much worst then a stand alone CD player.
                  I am considering buying a sound card + external DAC (as several distinguished members...
                  28 November 2008, 10:55 Friday
                • TommyV
                  Using a USB to Serial adapter for FW update w/ Vista
                  by TommyV
                  OK I would like to hear from people who have successfully used a USB to serial adapter/converter cable to update the firmware on their 10 or 15 series processor or AVR. I want to be able to use my laptop to do this update which is Vista 64bit. I am trying to update my RSP-1069
                  hifiguy...
                  13 June 2009, 04:10 Saturday
                  External DACs and laptops – the good and the bad
                  by bigburner
                  Three years ago I plugged my laptop into my hi-fi using a cheap and cheerful external DAC from Creative. The results were disappointing. The sound was brittle, sometimes it took a lot of messing around to get the thing to work, and I was plagued by a hum that was eliminated only by putting a cheater...
                  22 July 2010, 05:53 Thursday
                • Jon SS
                  Using MxEditor and a USB connection
                  by Jon SS
                  I just got a new laptop and need to make come changes to my remote. I bought a USB/serial connector/adapter since my laptop only has USB ports but for some reason it cannot connect to my remote?
                  Am I supposed to make any additional setting changes?
                  Thanks in advance.
                  01 April 2007, 15:00 Sunday
                • P-Dub
                  External CDRW's
                  by P-Dub
                  Anybody have any experience with external USB cdrw's? I'm looking at the HP 8230e, it's a 4x4x6 external CDRW's that connects via the USB.
                  I'd like to have it so we can backup the laptop, my PC, and I can take it to work and transfer files that way. I'm thinking of grabbing large files...
                  30 July 2001, 14:03 Monday
