Audio Alchemy DAC MAN
  • shtali
    • 19
    Does anyone know the DAC MAN?
    Does anyone have this model and can give me details about its quality?
    Shai
  • Kal Rubinson
    • 2109
    Bottom-of-the-line AA DAC. Probably inferior to most modern ones, stand-alone or built-in.
    Kal
    Kal Rubinson
    "Music in the Round"
    • shtali
      • 19
      Follow up question
      Hi Kal,
      Thanks for your answer. It took me a while...
      I have decided to purchase ESI JULI@ and put it in my HTPC.
      I'm using my HTPC as my main source for stereo music with the following gear: Rotel RB-1070 + Rotel RC-1070
      All music is ripped in FLAC / WMA Loseless.
      The ESI is connected (thru its analog Left & Right RCA outputs) with a MONSTER MK400 cable to the PRE and the sound is very good comparing to a very cheap MARANTZ DVD player which I used to listen to music with.
      The question is:
      If I connect the Audio Alchemy DAC MAN with an Optical MONSTER cable from the ESI JULI@ - will it give me a better sound?
      How can I compare between the DAC on the ESI to the ones on the DAC MAN?
      Shai
      • Kal Rubinson
        • 2109
        ?? Who knows? Try it.
        Kal Rubinson
        • shtali
          • 19
          I tried it..
          Just to give you an update:
          I get a much better result using an Optical Monster cable thru the Audio Alchemy DAC MAN using FOOBAR2000 with WASAPI JULI@ SPDIF OUT.
          Shai
          • Kal Rubinson
            • 2109
            Shai
            Good because I find most of that statement indecipherable!
            Kal (mostly ignorant of PC audio)
            Kal Rubinson
            • shtali
              • 19
              Kal,
              Thanks for your thoughts on this matter.
              Have a great day!!
