Question about DAC's/Jitter (for Jon?)
  • Brandon B
    • Jun 2001
    • 2189
    Posted what I thought was a simplified explanation about sound quality in DD/DTS vs. PCM. Curious where I'm off vs. maybe the guy correcting me.
    My post:
    In PCM audio (what CDs use) the bits are sent over the wire, and not only does the value of the bit (1 or 0) determine the signal, but the timing between the bits is part of the equation as well. Since the bits are not actual on/off, but an electrical signal that rises and falls in voltage quickly or sharply, there is some room for error.
    If your digital cable allows interference in, or because of its electrical properties sort of smears out the rise or fall of the voltage over time, the receiving equipment may have difficulty resolving the transition from carrier signal to bit signal at the exact correct instant to interpret the signal without any distortion. In effect this jitter (shifting back or forth in time the arrival of the bit by a small amount) can sort of subtly blur or distort the shape of the analog signal derived from the converted bits. Hence the claim that some digital cables sound "better" than others. You probably need a fairly good system to hear this difference.
    Now Dolby Digital and DTS bitstreams are NOT handled this way. Data is sent in packets, grouped together when the correct number of packets are received and then transformed into an analog signal. Much the way info comes over the internet. So there is no issue with whether the bits arrive at the exact right time, as long as they arrive nearly so, all intact and in the right sequence. When they do not, you get things like loss of digital lock, or dropouts and such, not continuous audio with degraded sound.
    The response:
    There is only ONE source of jitter in the digital (PCM) chain that is relevant: at the digital-to-analog conversion (i.e. the DAC in your receiver, preamp, etc). Jitter anywhere else has no relevance on the sound. As long as the DAC gets it right it makes no difference. If the DAC is dependent upon such timing the designer of the DAC should be taken out and publicly humiliated for such an incredibly stupid design.
    DD/DTS IS in fact handled the same way as PCM. The only relevant difference is DD/DTS is (usually) buffered more heavily due to the variable bit rate (i.e. there may be periods when the incoming data rate is slower than the output).
    Some actual examples of "high end" audio gear that mucked things up despite the fact there were proper implementations DECADES before digital audio was even a wet dream:
    1. Used the incoming bitstream as a reference clock.
    2. Poor mixed signal layout leading to noise coupling to the clock.
    3. And the best example (from Richard D. Pierce):
    quote:
    In the process of testing, I connected a Tascam DA-30 DAT recorder to a "highly regarded and favorably reviewed high-end DAC from a prestigious company. With certain cables, the residual noise floor on the output of the DAC was simply AWFUL. Why?
    The reason was simple: you had two utterly incompetent implementations. The DA-30's SP/DIF output had miserable current drive capability: load it up with capable capacitance, and the output went into slew-rate limiting and failed to meet the rise-time requirement. The DAC, for all of it's thousands of pretentious dollars, had the most MISERABLE design for clocking around. The result was that, given the right cable with enough capacitance, the resulting output had oodles of jitter in it.
    Now, here's the ironic thing: the DAC used was considered by many to be very "transparent" and was one of the few that, it was said, COULD reveal differences in digital cables.
    Well, that's NOT what was really happening. In reality, the idiot who designed the reclocking circuitry in the DAC simply got it wrong in a seriously stupid fashion: the designer simply made a DAC clock recovery circuit that was SO sensitive to small changes in input conditions, that its performance was all over the map.
    Yet, members of the high-end press praised this piece of crap for its "transparency. "It's obvious," it was said, "that anything that DOES show such large differences in cables MUST be transparent and high-resolution," when, in fact, precisely the opposite was the case.
    Far less price- and name-pretentious DACs, those with FAR better clocking circuits did NOT exhibit this ridiculous sensitivity to the cable: they were immune to the variation that the more expensive DAC simply could not handle properly.
    So, if the problem exists, it's not because some of us are using DACs that are immune to these errors, it's because some of you AREN'T :-(.
    Dick Pierce
    Professional Audio Development
    My followup:
    Understand that. But my understanding of PCM was that the signal clock is derived from the arrival timing of the incoming bitstream. Clock data is NOT included in the digital data itself. Is this not so?
    If it is so, would not anything that distorted the electrical signal in the digital cable distort the result of that clock timing calculation the DAC performs? And hence the result of the transform which yields the analog waveform?
    I know some good DACs buffer and reclock the signal for PCM, but these tend to be nicer ones($1K range and up), certainly not the ones in even otherwise very decent receivers.
    "DD/DTS IS in fact handled the same way as PCM. The only relevant difference is DD/DTS is (usually) buffered more heavily due to the variable bit rate (i.e. there may be periods when the incoming data rate is slower than the output). "
    This buffering and reclocking is what should make this type bitstream more immune to this problem. No?
    So are you saying I am incorrect about PCM jitter, or incorrect about DD/DTS immunity to jitter, or both? Or just incorrect that most DAC stages in receivers and CD/DVD players do not buffer and reclock the bitstream for PCM?
    Some more expert insight into my misunderstanding? The other poster is an analog signal engineer, so I am guessing he knows more about this than me.
    Thanks.
    BB
    • 16202
    Both of you are partly correct, and both are overlooking or interpreting in odd ways some of the things that can happen.
    First, with SPDIF outputs, the clock must be "recovered" from the bitstream. Unlike some other digitial interfaces which send the clock separately (and hopefully, differentially), signal quality can be a serious issue for SPIDF and recovered clock jitter. There are ways to attempt to minimize this problem, including using multiple phase locked loops (combing a fast PLL (which locks on quickly and responds to short term timiing errors) with a slow one (for stability of the recovered clock output to the converter. If this sounds a bit like a kluge, it's only because, inherently, it is. The best way is to have a single central clock located very close to the DAC chips which is then also distributed to the transport; this is why really good "one piece" players can ultimately have better performance than any player using SPDIF or the balanced equivalent.
    Now, regarding is statement about the TASCAM DAT recorder, let's get one thing straight. If you have a true 75 ohm source, and if the cable is 75 ohm characteristic impedance, it doesn't matter AT ALL what the cable capacitance is! Longer cable runs merely delay the signal more before it gets to the DAC. This sounds like an example where the source gear was not actually 75 ohm.
    Beyond that, a good transformer isolated receiver should also be carefully implmented to not inject non-linearity into the sending source- for example, many reciever chips need to be buffered instead of driven directly on their RX/TX inputs, because they use schmitt trigger logic to improve noise immunity, but this presents a nonlinear load which distorts the received waveform, and hence the timing, in a signal correlated way. (yes, folks, that's called jitter).
    Now, even through out the DAC itself, you can run into many problems, and with standard logic families, the best solutions I know of is relentless and extensive local bypassing and regulation of every digital power pin. Otherwise, variations in Vdd, which correlate with signals as well as local clocks, cause variations in gate logic threshold, which, guess what, causes jitter.
    You'd be amazed at how much better you can make a cheap Philips CD transport mechanism sound just by going through it and replacing every electrolytic cap with an OSCON or similar low ESR/ESL cap, and bypassing every chip right at the component pins with a low ESR Y5V ceramic cap. Also, place some thin copper foil sheilds over all the IC bodies; these reduces propagation into near by circuitry.
    There are many other factors, but it comes down to good digital design in a more "analog" sense, paying attention to the details, and even terminating some of the high speed digital busses on the PCB properly- somethign which is rarely done.
    • Brandon B
      • Jun 2001
      • 2189
      Thank you sensei.
      BB
      • Brandon B
        PCM, HDMI and jitter
        by Brandon B
        It occurred to me I don't know, and am curious. Is PCM over HDMI (i.e. for lossless codecs on HD disks) packetized and reclocked like DD and DTS such that is immune to jitter? Or is the clock derived from the bitstream as it is on S/PDIF?
        I would assume the former as 8 streams can...
        24 February 2007, 20:02 Saturday
        DACs are DACs are DACs... NOT!
        The Calliope uses the DA25TX; we've used that in several designs. It's a real bargain in the performance/cost ratio; it's drawbacks are mainly the large size and flimsy front plate- I've actually dissembled these on occasion and epoxied two front plates together and re-assembled the tweeter with one...
        14 February 2022, 12:43 Monday
      • Burke Strickland
        Integra Home Theater Announces First Separates
        by Burke Strickland
        Integra Home Theater (not to be confused with Integra Research) :>) has announced the first separates with the Integra name.
        Integra DTC 9.4 Pre/pro
        http://www.integrahometheater.com/press.cfm?id=65
        More details about the pre/pro:...
        17 May 2003, 23:56 Saturday
      • Horacio
        Experience modding an RCD-1072?
        by Horacio
        I'm considering mods for my RCD-1072 and was wondering if anybody has done these, or any others that have worked for you. I'm considering Burson Audio's Opamp, low jitter clock or low noise regulator.
        Also wondering how big a sound improvement any of these would represent, as the alternative...
        06 November 2010, 08:34 Saturday
        New 9.1 channel Dolby Pro Logic IIz
        From a news release I just saw of the first receiver, (Onkyo) with the new Dolby Pro Logic IIz technology that extracts to 9.1 channels. I chased down this technology report on the Dolby website. Very interesting.
        I'm surprised that I hadn't heard of this before! My thoughts in another post...
        12 March 2009, 07:06 Thursday
