Does Length of Interconnect effect quality of sound
  • toledoguy
    • Jul 2008
    • 24
    I'm in the process of purchasing some new interconnects. I've done a fair amount of research and found a brand and particluar "model" that I like. Howver, there is a good chance that I'll be rearranging my system in the near future so exactly what length is needed is a bit up in the air. The pre-amp to amp set up may be as short as a few feet, but it could be a few yards, it just depends upon a few factors beyond my control right now (my wife). So it's got me thinking, I'm aware that as the distance increases resitance in a speaker wire increases and that can effect the ultimate output. So for longer runs a larger guage speaker wire is needed. Is there a similiar concern with interconnects? Specifically is there a length that should not be exceeded? In the alternative as length increases should the interconnect me made of a particular material, or have a particular construction technique? I think the maxium length that I need is 20 feet. Is that distance enough to get worried about the issues I raise here? Any help would be appreciated, and if I'm totally off base here, let me know, or if there is some other concern I've totally missed please let me know. Thanks for the help.
    I usually try and go with the shortest run possible. Especially with interconnects as it's such a low signal level that the slightest amount of capacitance can mess with the signal. Some may notice some may not but that's my .02.
      • 1913
      I've used 20 foot lengths of interconnect, preamp to amp, with no problem. The resistance of the cable is a non factor as it is negligibly small. However, like Doug mentioned, the capacitance may affect the sound if your preamp has an high output impedance, say 1kohms or more. But it's unlikely to have much affect. It needs to be a shielded cable and have twisted leads so it won't pick up noise. I like the DH Labs cables like the BL-1 (DHLABS- 57225), at Parts Connexion (www.partsconnexion.com). Although you'd need to solder your own connectors on. Either RCA or XLR.
      There's lots of options though.
      John unk:
        If your staying around 3-10 feet I doubt you'd notice much of a difference. But everyone is different and some people at least claim they can hear little differences and I suppose that's possible
        • toledoguy
          • Jul 2008
          • 24
          My preamp is an Outlaw 990, the amps are Rotel RB-1050 and a RMB-1066. Checking the outlaw website, it states that the pre out output is 1kohms, 1.0 V. Can you explain what you mean by a capacitance problem? I can if need be, keep the amps close enough to the preamp to keep the interconnedt at no more than 6 feet. I'm a little concerned that 3 feet won't be enough. Thanks for the help
          • Rick Hunter
            Interconnect help!
            by Rick Hunter
            This is a newbie question for sure but I'm looking for a good solid answer all the same. I have a 7.1 channel pre/pro. I have a 5 channel power amp along with 2 mono blocks. I know, ..... well at least I'm pretty sure, that I am supposed to use three "red" colored interconnects for my FR,...
            20 July 2010, 00:09 Tuesday
          • toledoguy
            Cables, Interconnects, and Speaker Wire
            by toledoguy
            I'm sure if I dig deep enough into past entries I can find some discussion on this issue. But I'd like to hear some fresh responses. Here's the deal, after years of ok audio equipment, (Sony Reciver, Sony DVD player, Sony CD player, Sony Tape Deck, Sony TV, Sony Front Channel and Subwoofer (anyone...
            05 November 2008, 16:27 Wednesday
          • terry78
            Long Interconnects and Rotel
            by terry78
            Has anyone used really long interconnects (about 25 feet) with the RSP-1066? I'm thinking of adding an RB-1050 and a pair of center rear speakers to my RSP-1066/RMB-1075 combo to get a full seven channel system. I could put the new amp back by the speakers and use a 12 year old pair of Straight Wire...
            21 May 2003, 16:05 Wednesday
          • hired goon
            Interconnects for Rotel RSP-1068 / RMB-1075 / RCD-1072
            by hired goon
            G'day,
            I'm looking for reasonably-priced interconnects for my new Rotel RSP-1068 pre/pro, RMB-1075 amplifier, and RCD-1072 cd player. As an example of "reasonable", I'm thinking under AUD$100 (or about US$60). For example, QED Qunex 2 seems like a reasonably priced interconnect...
            20 September 2004, 01:08 Monday
            Sonic differences in Interconnect fact or fiction?
            by Andrew Pratt
            This topic often gets the geekers and tweakers all fired up hotly debating the merrits of both sides and inteligent debate can be fun and a learning process for both sides. My point with this post though is to tell you what I've discovered twice now with my IXOS interconnects. Several moons ago I was...
            19 January 2001, 10:56 Friday
