Subwoofer cable questions?
  • nikos
    • 172
    I just purchased a JL Audio F113 subwoofer....
    The Coolcat Subwoofer Cable looks nice... I have few questions though that hopefully Lex or the rest of you can chime in and inform me...
    Would a subwoofer cable benefit from a silver cable vs copper?
    (I listen to strictly electronic music with fast, continuous bass, plus HT)
    My Rotel 1057 does not have a XLR... but the subwoofer does.
    I have seen other manufacturers do a RCA to XLR, which If I understand correctly is not balanced...
    Would there be a benefit from a RCA to XLR ic cable? If so, Lex is this something that you would be interested in doing? I also don't want this to double/triple the budget either....
    Any of you using the Coolcat Subwoofer cable? Is it better to use 2 of them with a Y or is the second unecessary...
    What kind of cable do you guys use to find the sweet spot for the sub before you spend the cash on the right length cable?
    Any other advice on the subwoofer ic is welcome...
    Nikos
    Classe SSP-800, Classe CA-5200, B&W 803D, B&W HTM2D, JL Audio Fathom f113 Subwoofer, Rotel RMB-1077(for sale), Oppo DV-983H, Panasonic PT-AE900U Xbox360, Sony PS3, Samsung 8000 Series 55" LCD, Klipsch promedia 5.1 ultra for PC
    • 27460
    I have heard some people say silver for their sub did increase the dB slightly, it can also optimize transmission so that it sounds a little crisper, cleaner when called upon. Silver can improve bass performance, so it's not just for highs.
    As to splitter to plug both inputs? I used to hear that this was a + gain to plug both inputs, but I am not so sure this is true really... I mean 2 subs playing at same volume vs one is typically only a +3 dB gain, so how much are you realistically going to get varying inputs on 1 sub?
    I have done splitters, but they are a pain, and I have to charge for it.
    CAT
    • DrJRapp
      • Apr 2003
      • 1204
      While on the topic of subwoofer cables..I'd like to hear Doug's opinion on the use of a digital cable for a sub. I've been told by an installer that the two can be used interchangeably.
      Jerry Rappaport
      • Burke Strickland
        • Sep 2001
        • 3159
        I doubt that a digital cable could take the place of a sub. (Or vice versa.) ;>)
        • Kal Rubinson
          • 2109
          I'd like to know what makes a sub cable a sub cable.
          Kal
          Kal Rubinson
          "Music in the Round"
          • Club1820
            • 269
            Kal
            Yes, so would I. What's the difference between a "normal" interconnect and one labeled/sold as for a sub?
            Rotel 1068, Rotel 1060, Rotel 1055, Rotel 1095, Rotel 956, Rotel RLC-1040, M&K VX-860 Sub, Whatmough M30s, Squeezebox 3
              • 4157
              I'm gonna take a WAG and say impedance , and possibly metallurgic composition relating to frequency transmission.
              • Kal Rubinson
                • 2109
                :roll:
                Kal
                Kal Rubinson
                • Nolan B
                  • 1792
                  I could be wrong but im pretty sure a 75 ohm Coax cable can be used for the following and there is nothing "different" about a cable which is "designed" for one or the other:
                  Component Video
                  Sub
                  Digital Coax
                  Interconnect between pre and pro
                  Composite video
                  The list goes on...
                  I think the only different is the way they are marketed. Doug?
                  • Victor
                    • Apr 2002
                    • 338
                    From a purely engineering perspective there is absolutely no way to design a cable that might be specifically designated for subwoofer applications.
                    • chrispy35
                      • 198
                      Kal
                      1 connector at each end instead of 2?? Oh yeah, the writing on the package as well.
                        • 27460
                        ok cable naysayers, no smart piffy comebacks from me on what is a sub cable. I call my sub cable a sub cable, because 1. I sell them individually, 2. We focus on the value side of analog pricing because a sub cable generally is not rocket science, it benefits from good shielding, and a durable cable because people tend to move them around more. End of story.
                        Does that mean you can't benefit from a higher quality cable, not necessarily. I do think a quality interconnect is a positive. At times, our sub cable has been half a pair of Blue Tigers in reality, but if you check, the pricing wasn't far off buying only one cable. A little yes, due to cost of doing business for a single cable rises some.
                        But I have never participated in voodoo marketing for subwoofer cables. It's just good quality cablenomics. (hey, new word, Copyright)
                        • Kal Rubinson
                          • 2109
                          Thanks for the cogent and serious reply.
                          Kal
                          Kal Rubinson
                          • nikos
                            • 172
                            Thanks for everyone's input especially Dougs!
                            One item not touched...
                            "My Rotel 1057 does not have a XLR... but the subwoofer does.
                            I have seen other manufacturers do a RCA to XLR cable, which If I understand correctly is not balanced...
                            Would there be a benefit from a RCA to XLR interconect cable?"
                            Anybody with experience on running a cable that has RCA on one end and XLR on the other? What is the benefit of the XLR to RCA if its not balanced? (not that I REALLY know the difference if it is balanced either ops: )
                            Thanks again,
                            Nikos
                            • NonSense
                              • Nov 2003
                              • 138
                              I believe that a conversion from RCA to XLR requires a transformer, or some other impedance matching network.
                              Cardas used to sell an adaptor, but they were about $50/pr.
                              I don't see the advantage, unless this is your only option.
                              Bruce
                              • Kal Rubinson
                                • 2109
                                Not necessarily. If you are using a typically very low impedance source into a 600ohm load and not using an impedance-specified 600ohm balanced connection all the way, there's probably no need. Just a physical adapter will do. Going from balanced to SE, you might argue that the source should see a balanced 600ohm load, so a transformer might be advantageous there.
                                Yes, the Cardas adapters work fine, as do the Kubala-Sosna ones I had made. It's not magic.
                                Kal Rubinson
                                • Jerm357
                                  Custom RCA to 1/4 mono subwoofer cable ?
                                  by Jerm357
                                  I want to make a subwoofer cable with a RCA connector and a 1/4 mono plug. I am planning to use a old MonsterBass™ 300 Subwoofer cable and use the one of the RCA on it and cut an end off and solider a 1/4 mono plug on the other end. Now the question is what a good 1/4 mono plug that will fit on this...
                                  31 May 2006, 14:05 Wednesday
                                • theMaximus
                                  by theMaximus
                                  Are cables that claim to be "made specially for subwoofers" different than regular analog RCA cables or digital coax? Only difference that I can see is that some of the subwoofer cables use solid core as opposed to multiple copper strands used in regular analog or digital interconnects. ...
                                  16 August 2004, 18:07 Monday
                                • John Kotches
                                  Paw prints to the subwoofer.
                                  by John Kotches
                                  Well folks, I finally broke down and did it, yessirree.
                                  Spoke to our pal Lex, 'cause I was a bit dissatisfied with every subwoofer cable I've ever purchased, Brand M, Brand N, Brand T etc. None of them are made well enough to withstand the routine torturing I do to cables.
                                  31 October 2001, 20:42 Wednesday
                                • david teltschik
                                  High End Subwoofer Cables (RCA or XLR)
                                  by david teltschik
                                  I'm in the process of upgrading my subwoofer and I"m getting a new amp that has unbalanced and balanced inputs and passthroughs. I was wondering who makes good balanced cables in lengths in the 16-25 ft rhealm? I could always go with the simple long RCA subwoofer cable, but Im wanting to with...
                                  27 January 2005, 09:42 Thursday
                                • Nick Danger
                                  RSP 1066, RMB 1095 and Silver Kingcats!
                                  by Nick Danger
                                  I have a much happier tale to bring you all today!
                                  I contacted Doug at Catcable, looking for interconnects for my system. I had been considering and researching alternatives to the cables that I bought when I purchased the Rotel equipment.
                                  Subsequent to buying the Rotel...
                                  13 October 2004, 09:47 Wednesday
