Amp issue
  • dyazdani
    • 7032
    Amp issue
    I'm having an odd problem with a car audio amp. I've got a 4/3/2 Alpine amp in my truck and for some reason the left channel doesn't want to always work. When I first start the vehicle, there is no sound out of the channel, to fix it, I turn the volume way up for a second and then back down - it then starts working and stays working for a while. If it quits again I just repeat the volume thing.
    Any ideas on what might be going on? When I first got the amp, it had a similar issue and I found a broken ground on the input circuitry (RCA connections). I checked again and didn't see any issues.
    Thanks!
    Danish
  • dyazdani
    • 7032
    I was able to help it some today - filter switches seem to be a little dirty maybe. Switched the filter from "off" to "HP" and things cleared up. It's an old amp (circa '92) so I think I'll hit it with a few shots of Caig.
    Danish
    • kurtholz
      B & W alignment filter question
      by kurtholz
      Hey all
      saw one of these on ebay, i guess it hooks up between pre pro and amp, is this a must have, i'm not sure to pull the trigger on this one or not
      thanks
      Kurt
      18 October 2005, 13:16 Tuesday
    • Jaynaldo
      HDCD & 1068 issue
      by Jaynaldo
      I was listening to a Jim Brinkman CD which is recordered in HDCD. The 1068 started to in HDCD format then jumped to PCM 2CH. And the format would jump In between song selections causing the music to stutter. Any suggestions to remedy this issue?
      06 June 2006, 22:29 Tuesday
    • dyazdani
      Sub amp humming issue
      by dyazdani
      I recently sold my Bag End Infrasub 18 and the new owner is reporting a hum coming from the amp. It was not there in my system so I am trying to troubleshoot possible causes.
      He says it is there "even without hooking it up to the preamp."
      I suggested trying...
      14 February 2006, 19:29 Tuesday
    • HuskerInTX
      PreAmp Channel Balance Issue
      by HuskerInTX
      I checked archives and found no items regarding my item. My issue has to do my preamp, RTC-950AX. After replacing the speaker cables, I had a noticeable volume imbalance. I tested using all sources, swapped speaker, amp to preamp cables and narrowed issue to the preamp.
      I turned the...
      20 September 2009, 09:32 Sunday
    • Nolan B
      Fujitsu quits the display business
      by Nolan B
      Sad news. I love my Fujitsu and always thought they produced one of if not the best Plasmas on the market.
      http://www.engadgethd.com/2007/12/27...play-business/
      I guess with HD material now wide spread people just dont see enough of a differene between...
      29 December 2007, 20:04 Saturday
