saw a Mc tube matched with ML summits
  • peterS
    • 1038
    am I confused or is a tube with electrostats a BIG no no
  • Karma
    • 801
    HI Peter,
    Yes, you are confused. SOME tube amps work well with SOME electrostatics. In fact, if you can find the magic combination, tubes are the first choice.
    I have Martin Logan CLSIIA electrostatics being driven off my Audio Research D250 MKII Servo tube power amp. This combo has been together for about 15 years. This amp is very powerful (250W/channel) and stable. The sound is to die for. Really!!
    One must be careful though. Many tube amps cannot drive the cruel high frequency impedance of most stats. However, Audio Research amps seem to have no trouble.
    Sparky
    • gianni
      • Nov 2002
      • 524
      I would think so with all but the stoutest tube amps - not for your garden variety budget tube amp. You saw it but did you hear it?
      • peterS
        • 1038
        my understanding of tube amps is very elementary but from what ive read the do not like much of any impedance change- i was very surprised to see that
        tube amps aesthetics have always interested me but in the few times ive auditioned ive been unable to detect the "sound" probably because there were too many variables
        i few years back i bought books on tube amp design and found that each of the author's was strongly opposed to them and actually preached the merits of tube pre amp stages coupled with solid state amplifier stages- thoughts?
        gianni- there were no salesmen to be found nor was i in the mood to deal with one
        on previous occasions ive found the summits to be the best sounding above 200hz from anything ive heard but the particular set up i've heard seemed to have what i can best describe as phase or time alignment issues below 200hz as the sound stage went to hell - fed by a rotel 1080 i believe
        • NonSense
          • Nov 2003
          • 138
          I would throw out there that the Martin Logans are not typical electrostats. They have the advantage of a powered LF driver. I would expect this reduces the demands on the amplification when compared to a full range panel.
          Bruce
          • twitch54
            • 340
            actually most M/L's DO NOT have a powered bass driver, it's the Summitt's and Vantage's that do.
            Come on over and check us out at www.martinloganowners.com many of the members have and love the Tube possibilities with hybrid electrostatics !!
            Dave
            • Karma
              • 801
              HI twitch,
              Good to talk to you here. I just want to clarify for the other posters that ML CLS series were full range electrostatics with no bass driver or built-in bass amplifier. So, the CLS's present the full bore load to the amp.
              Sparky
              • twitch54
                • 340
                Originally posted by Karma
                HI twitch,
                Sparky
                Hello Spark ! Exactly stated and thats why those models of M/L's present the amplifier challenges that alot of the "Maggie" crowd has to deal with.
                Dave
                • warnerwh
                  • 261
                  Stats are a brutal load but with a tube amp driving the midrange and treble the sound can be to die for just as stated. You have to hear it to understand. Imo it's of the most realistic sound there is. No SS amps driving cone drivers sound anything like it that I've heard. Go listen and you'll be shocked if you've not been exposed to this type of sound before.
                  • Karma
                    • 801
                    HI Peter,
                    Topic 1:
                    An electrostatic speaker presents largely a capacitive load to the amplifier. If you recall your theory, the effective resistance (impedance) of a capacitor is inversely proportional to frequency. This is called capacitive reactance which can be thought of as AC resistance (otherwise known as impedance). Thus, as the audio frequency increases, the impedance decreases. An electrostatic speaker presents to the amp its lowest value at the highest frequencies. Conversely, as the frequency decreases, the impedance increases as the frequency is lowered. In the case of the CLS series, the lowest impedance of 1 to 2 ohms occurs at 20kHz; very difficult for any amplifier. Tube amps must be very stable for this to work. Solid state amps also will have a difficult time of it if they are the slightest bit unstable and many are. Electrostatic speakers usually are happy with only the best amplifiers either tube or solid state.
                    Conventional speakers have an impedance characteristic that's dominated by inductance. Inductance behaves the opposite of capacitance. As frequency increases the impedance increases and reduces as the frequency is lowered. Thus, conventional speakers (including Maggies) present the most difficult load at low frequencies. This is also a challange but a different one.
                    Topic 2:
                    I have tried both high end tube and solid state preamps in combination with tube and solid state power amps of equal quality. Obviously, all the combinations work. But which works best? I have concluded that mixing and matching technologies is not a good idea for the best sound. Rather than getting steak you tend to get stew. The positive qualities of each technology are lost in a general mish-mash of unrelated sonic personalities.
                    I'll take it further. Once you have decided on a sonic personality that you prefer, stick with it and optimize it. I don't even like to mix and match manufacturers within a given technology. I don't like stew.
                    Many audiophiles are attacted to tube pre's paired with solid state power amps. I see only one reason for this. It's cheaper due to reduced amplifier maintenance. There is no doubt that the tube/SS hybrid system is more trouble free. But, ask yourself why we are in this hobby? I can answer. For me, it's the sound. Otherwise, why bother? Thus, I do not mix and match. Clearly, this is a personal decision one must make when considering priorties.
                    Sparky
                    • TomDac
                      • Feb 2007
                      • 4
                      Hey kids.. Daddy's home!
                      MartinLogan Club
                      Click HERE to see my system.
                        • 4157
                        This is relevant because..... :huh:
                        • TomDac
                          • Feb 2007
                          • 4
                          Sorry, I added my signature after the post, thinking it would change on my original post, but it didn't.
                          It's relevant to a couple of the guys here talking about Logans because we're all friends over on the MartinLogan Club ... http://www.martinloganowners.com
                          MartinLogan Club
                          • Karma
                            • 801
                            Hey everyone, Dad's home. We can all eat together tonight.
                            HI Tom. It's a small world.
                            Sparky
                            • twitch54
                              • 340
                              damn, he caught us playing after curfew !!!
                              Dave
                              • TomDac
                                • Feb 2007
                                • 4
                                Just stumbled onto this site searching for information on the Halo C1 and see you guys here.. cool!
                                MartinLogan Club
                                  Yes, there is ALL sorts of cool stuff here in the Guide.
                                  • DrJRapp
                                    • Apr 2003
                                    • 1204
                                    Probably setup. The Summits are bi-polar speakers and any hard surface (such as glass) behind them or even if they are too close to the front wall, can cause exactly what you hear. Get the setup right and nothing can compare at all frequencys.
                                    OBTW, IMHO The Summits sing best with amps better than the Rotel RB1080. It's too grainy.
                                    Jerry Rappaport
                                    • Boombox
                                      Tube or Solid state amp: PrimaLuna ProLogue Two - Rotel RB1070
                                      by Boombox
                                      I am by no means a hi-fi/home theater equipment reviewing journalist. I live in the real world where kit is not delivered to my door from the distributor for the latest issue of hearmystuffissocool.com or hifioverthetopcostnooption magazine. I am a student using all my savings to buy bang-for-buck new,...
                                      08 December 2006, 15:35 Friday
                                    • Jeff Aguilar
                                      My first tube amp!
                                      by Jeff Aguilar
                                      First step into tube amps…
                                      Cayin TA-30
                                      (alt+p)
                                      I have not wire maintenance yet!
                                      I bought a new amp a few weeks ago to try and improve my two channel music experience. About 8 months ago I invested in some Martin Logan speakers. I loved...
                                      29 December 2003, 23:57 Monday
                                    • pedro77
                                      Entry level tube/valve amp advice
                                      by pedro77
                                      I'm interested in getting a tube amp and was hoping someone here may have listened to a couple of the amps I'm considering. I basically got interested when I read some rave reviews about the great value of the Miniwatt S1, which has since been superseded by the N3.
                                      As...
                                      13 May 2010, 20:27 Thursday
                                    • fatcat
                                      Snail Nautilus -- Tube + SS combo
                                      by fatcat
                                      It sounds like there are two of us here (hi Aldo) seriously pondering a Nautilus purchase. And we both already have McIntosh amps in our current system.
                                      I listened to some tube Glass Master amps yesterday at the Dynamic Audio showroom in Tokyo (truly one of the most astounding audiophile...
                                      14 October 2006, 18:32 Saturday
                                    • jclyle
                                      tube amps & B&W's
                                      by jclyle
                                      Hey-
                                      Im thinking about moving up to a tube amp from solid state. I don't do home theater at all, just 2 channel. B&W speakers need lots of juice to perform well. B&W's are also a bright sounding speaker so im hoping a tube amp would help with that as well. So, for those who may use tube...
                                      29 March 2005, 19:27 Tuesday
