KRELL Showcase Amplifier and Processor - Experience?
  • smjc99
    • 28
    Does anyone have any opinions on Krell Showcase Amplifer ( 125 times 5 ) and Showcase Processor ?
    I think krell Amp's are very good at delivering tight Bass but was wondering how musical they are and if they are warm, bright or neutral sounding
  • Audiophiliac
    • 346
    It really depends on your deifinition of "bright" or "neutral". I feel that Krell has always been more on the "neutral" side of things. Their claim to fame, so to speak, has been their natural, deep, "quick", and powerful bass abilities. I find them...."crisp" and "clear" and "precise". Of course, its hard to try and explain that in a way that others would understand.
    Borrow one and listen.
    • smjc99
      • 28
      Thanks Audiophiliac
      I meant bright implying fatigue sounding at high volumes especially when the recording is good to listen at moderate volumes
      • worldys
        • 121
        i ran my b&w nautilus home theater with an HTS 5.1 mkii and a showcase amp, was happy with the match, i thought the showcase processor wasn't as crisp or refined as the hts and since i didn't need a 7 channel processor, i went with the hts
        i am now using a classe ssp75 and cav75, it doesn't have as much power but at low to moderate volumes, i think the classe gear is more nuanced
        • misterdoggy
          • 1418
          The showcase amps are great entry level krell. what speakers are you running them with ?
          I have krell amps, but found mixing them with mark levinson preamps a nice combo
          • smjc99
            • 28
            Me and my cousing audtioned Krell Amp's with the new Sonus Faber Grand Paino Domus speakers
            Krell Showcase is 125 times 5 but I think they have high current and hoping it is plenty for 90DB SF Domus
            • Aussie Geoff
              • Oct 2003
              • 1914
              I'm moving this to the Audio Hideout since it has nothing specific to do with B&W and you will get a widr range of opinions there...
              Geoff
              • grit
                • 580
                I'd reconsider the Showcase amp... 125 x5 doesnt seem like it would be enough power to satisfy for a long period of time. For me, when I spend that sum of money on a showcase amp, I expect it to be around until there's something revolutionary in amps. I'd aim for 200+ watts.
                • Aussie Geoff
                  • Oct 2003
                  • 1914
                  Grit,
                  I agree with you... Now the Krell Theatre Standard (a nice 200-250W a channel) that's a nice amp
                  Scarey the effects it can create...
                  Geoff
                  • smjc99
                    • 28
                    Grit and Aussie,
                    if I get Krell theater Standard Amp can I match it with Krell Showcase Processor?
                    Not sure if I have to upgarde To theater processor, I rather not if Showcase processor is good enough.
                    • kurtholz
                      • 345
                      i use a showcase processor with home theater standard amp with my B & W 802d's, also a KAV 3250 for rear surrounds and rear center,
                      incredible sound, you can't do better i think, though the arcam dv29 dvd/cd player di bring out a lot more in those formats, have a sony 9000 sacd coming, will let you know how that goes
                      good luck
                      Kurt
                      • Aussie Geoff
                        • Oct 2003
                        • 1914
                        SMJ,
                        The two work well together... The Theatre Standard Amp looks very serious and sounds... Well scary... One of my favourite HT amps...
                        Geoff
                        • grit
                          • 580
                          Originally posted by smjc99
                          Grit and Aussie,
                          Absolutely! No problem there whatsoever.
                          • JimmyNeutron
                            • 21
                            I have the SHowcase and absolutely love it - best pre I've had the pleasure of owning. The difference between the Showcase and the 7.1 is two-fold. 1: the 7.1 and the Showcase are identical except for the analog section - it's quieter on the 7.1 (if the Shaocase is any indication then you just won't need anything any quieter). 2: the 7.1 is modular. There's a big price jump from the Showcase to the 7.1 just for a quieter analog section that most no one will use anyway.
                            My website: www.jimmyneutron.org
                            • coxhaus
                              • 10
                              I own the Krell Showcase 5 amp. It is a very nice little amp with lots of current. It will drive almost any small speaker. I use the Krell HTS 5.1 with it. It is the older processor but I bought used and saved a lot. It has almost everything you need for movies. I only use it for movies. I have a separate 2 channel system on the other end of my house. I first used the Krell system with B&W speakers and then switched to Revel speakers. I bought the following Revel speakers M20x4, B15x2, and C30 for center channel. I like the combination for movies but not 2 channel. The subs and system are tuned for movies not music. In my opinion you have to make to many compromises for both.
                              • bimmer528
                                Krell or stick with Rotel.
                                by bimmer528
                                Hey guy, I am in the process of upgrading my processor (rsp-1066). Initially I was going to purchase the 1098 but taking a trip to my local dealer had my inpulses halted upon listening to Krell. Granted, I can't afford new krell or anything above krell's entry level (Kav).
                                I can pick...
                                09 May 2005, 18:30 Monday
                                Krell HTS 7.1/Showcase processor experiences please
                                by ShadowZA
                                I'm on "final approach" with regard to my proccessor upgrade.
                                My shortlist consisted of 3 processors:
                                - Meridian G61
                                - Krell Showcase processor
                                - Krell HTS
                                The Meridian G61 processor is not my favourite at the moment for the following...
                                31 August 2006, 06:14 Thursday
                                New Krell Showcase pieces!
                                by Lex
                                Anybody seen or read up on the new Krell Showcase pre-processor and amplifier? Looks to be a real competitor coming in at 4K for the pre-pro fully decked out with balanced inputs and outputs. Of course, the normal plethora of sound processing is standard, RS-232 for software updates, stainless front,...
                                07 November 2002, 03:45 Thursday
                              • Minardi2
                                Personal findings with Krell and Classe gear
                                by Minardi2
                                Had the opportunity to demo Krell and Classe HT gear in the last three days, specifically the Krell S-1200 and two S-275s, along with the SSP-800 and CT-5300. I had planned to do a big write up but lost interest and will just provide a few comments.
                                Speakers are all B&W: 803s L and...
                                09 March 2010, 17:02 Tuesday
                                Order placed for Krell & Velodyne
                                by ShadowZA
                                Well, decision time is over and I've placed my upgrade order with my supplier. It has been quite a time of decision-making. Tougher than before - waking at night - mind-changing swings. Now it's done. Here are the changes:
                                Processor: Krell Showcase - replacing the Rotel RSP-976
                                07 September 2006, 15:02 Thursday
