pre existing equipment is
denon 2910
rotel 1070 pre amp
rotel 1080 2 channel amp
i am probably going to get the deq for eq/rta duties as it will save me the cash on a pc based set up plus get me an eq... win win
now it seems that i can only feed analog into the dcx which i dont like one bit, even if i cant hear the difference i will think i can
what options are ther for me as i realy only need the x/o to hp the speakers and lp the sub(s)
maybe ill just get a plate amp and be done with it
fyi
the speakers will be the seas "thor" with the lcy 110 ribbons instead of the millenium dome
denon 2910
rotel 1070 pre amp
fyi
