DCX2496 benefited by FBQ2496? how about vs denon 3806/2807?
  • zacjones
    • 57
    I just got a DCX2496. My subs aren't built yet and I've never used it. Apparently there are no feedback destroyer functions built into it (for some reason I thought there were). Would I benefit by adding an FBQ2496 or DSP1124 into the system? How about a DEQ2496?
    I'm trying to set up really sweet home theater (aren't we all), and could use some help from the vets in choosing my equipment.
    It seems like there are at least 2 ways to go with a feedback system, the second being with denon's latest receivers. Is there a preference with this stuff vs the denon 3806 or 2807?
    Right now I've got a Newcastle R-956 receiver that I've been very happy with, but it seems like I might have to let it go to do a pre/power setup here pretty soon, but I'll save that for another thread.
    Ultradrive Pro Digital Crossover System $269
    The page you're looking for doesn't exist or has been moved.
    Feedback Destroyer Pro FBQ2496 $149 (newer model)
    Feedback Destroyer Pro DSP1124P $99
    Ultracurve Pro DEQ2496 $299
  • Mazeroth
    • 422
    The Feedback Destroyers have parametric EQs whereas the DCX2496 has parametrics and shelving filters, which allow you to emulate a LT. Therefore, the DCX2496 has a superior EQ feature set and the added crossover and delay functions are the icing on the cake.
    You made a good choice.
    Sincerely,
    DCX Lover :B
      The DCX is a better unit in every way but it costs more. Another good one, that has some features the DCX lacks, but it doesn't do crossovers, is the DEQ2496. It's strictly 2-in, 2-out, but it adds features like 1/3 octave graphic EQ and 1/6 octave room measurement if you add the optional mic. The feedback destroyers are a good value but they won't do a true LT because they don't have the shelving filters. That said, if price is an issue, the feedback destroyers can be made to work just fine. Down low, room effects dominate, so the thing is to EQ the response as close to flat as you can get, using whatever you have, and ignore a bunch of theory.
      • zacjones
        • 57
        Oops.. it seems I edited my post and added some stuff about the denons after you guys responded.
        Anyway would it make any sense to add a DEQ to the DCX and use both, would that be overkill, or would they get in the way of each other?
          No, choose whichever one suits your needs better.
          • zacjones
            • 57
            good. I have better things do with that $300, but I was just curious. thanks.
              I think you have a little confusion going. Some people have answered already, but I'll add a few comments:
              The Feedback Destroying Functions inside the BFD and FBQ are typically not used by us. They are used by pro sound installs to kill those annoying squeels you sometimes hear. What we do use is the built in Parametric EQ.
              A Parmetric EQ is found in the BFD, FBQ, DEQ, and DCX.
              The Parmetrci EQ in the DCX and DEQ are a step up from the BFD and FBQ, in that they have shelving filters which can be used for LT with a sealed sub to improve the low end response.
              Typcially, the Parametric EQ on the Behringer gear is only used with subs. If you install it on your sub pre-out as most do, you will only be able to use it with your subs.
              Typically, the Parametric EQ on the Behringer gear is NOT recommended for full range speakers, such as your left and right speaker.
              The Denon receiver has an EQ that works on all your channels, and is more to correct the room for the range above the sub. It is somewhat limited, but used for very differnt functions than the Behringer. A lot of people use both.
              I hope that clears some things up for you. I suggest a bit more reading up. If you're still confused, I'm guessing you're reading posts by equally confused people.
              • Paul W
                • Oct 2004
                • 552
                Though the two boxes provide some of the same features, they are for fundamentally different purposes...DEQ is a full range EQ, DCX is a crossover. The DEQ includes the very narrow EQ/Feedback Destroyer functionality sometimes used to address bass problems...the DCX does not provide the really narrow filters. Another handy DEQ feature is the 1/6 octave RTA with peak hold. I often plant the RTA microphone in a different spot in the room for each listening session and then look at the RTA peaks at the end of the session...after a while, it helps you develop a better mental picture of how the speakers are interacting with the room.
                Denon is supposedly releasing the 3808 in late summer. HDMI 1.3 plus the new HD audio formats.
                Paul
                • Mozart
                  703 and Denon AVR-2807 receiver
                  by Mozart
                  I am picking up a pair of 703s this weekend and am deciding on the best receiver for them. Does anyone have any experience in matching the 703s with the Denon AVR-2807? Do they work well together? Alternatively, I am considering the Yamaha HTR5990.
                  Any feedback is appreciated....
                  07 November 2006, 19:56 Tuesday
                • bsmith203
                  Help needed hooking up Behringer FBD!!!
                  by bsmith203
                  I'm a newbie to the forum and have lurked for about a month. I have a very modest Home theater 5.1 set-up in my family room. It consist of Kenwood Sovergn 5080 vr 5.1 reciever,Sonance Fronts, Center channel, And In-wall Rear surrounds. I built a sealed 2.0cu enclosure to fit a ascendant audio atlas...
                  09 April 2006, 09:32 Sunday
                • bleeding ears
                  Why aren't equalisers used much any more?
                  by bleeding ears
                  Hi guys, after contemplating room treatments, feedback destroyers, and using an equaliser in my system, I was thinking back to the days when equalisers were popular in home Hi Fi systems.
                  Equalisers were all the go around the 80's ? and they looked very cool with all those LED's flashing...
                  20 February 2007, 08:31 Tuesday
                  FYI Parts Express Accepting orders
                  by Lex
                  Click the Parts Express banner above so HTG gets credit for the sale. You pay no more when you do that, it just insures they know you came from the Guide. PE was down for a day or so, we had a slight misunderstanding, but they are here now supporting this forum for you guys and more. So, please return...
                  11 March 2008, 16:33 Tuesday
                • dyazdani
                  Denon 2807 Auto Setup (Audyssey)
                  by dyazdani
                  For you techie gurus out there, do you know any specifics about the auto setup/eq features of the Denon receivers, e.g. 2807?
                  There is a thread on my Porsche forum regarding a receiver recommendation, the guy was planning on a 2807 and several of us suggested looking at Rotel, etc. A...
                  18 January 2007, 21:47 Thursday
