SPL meter range
  • Kobus
    • Aug 2005
    • 402
    SPL meter range
    The only SPL meter I can source so far in South Africa has a range of 30hz - 10 khz. Is this OK.
    Are the so called Radioshack models "full range" 20-20.
    Kobus
    The 'range' means the frequencies where they're most accurate.
    The RS meter isn't accurate at lower frequencies either. There are correction tables for the RS meter, but they're not really very useful given the unit to unit variability.
    For accurate measurements a much better choice is something like the Behringer ECM8000 mic with associated gear and software.
    • ToddAnisman
      • 142
      Another choice that I personally dig is the Phonic PAA-3. Also has RTA, RT60, and has software that can be loaded on your PC for gauging the entire room.
      -Todd A.
        My BFD subwoofer EQ thread
        Well, I'm FINALLY getting around to using my BFD to calibrate my two SVS PC-Ultra subwoofers. As expected, I'm running into a few hitches along the way as I'm learning and going through the process. Hopefully there are guys here that can help.
        It took me a while, but I did go around and...
        09 March 2006, 15:33 Thursday
      • NyxOne
        SPL meter and LCR meter questions
        by NyxOne
        Hi everyone,
        I'd like to have your opinions on some measurement product, an SPL meter and LCR meter to be specific.
        SPL Meter : I know alot of people around here have the RatShack SPL meter but unfortunately for me I'm a Canadian and RadioShack only sell his stuff to US...
        04 August 2009, 14:18 Tuesday
      • NateTTU
        Spl Meter
        by NateTTU
        Hey guys,
        I'm looking to purchase a spl meter and thought I would ask you guys which one is pretty decent. I don't want to spend too much, I would prefer around $40 or less if possible. It would be nice if I could get a unit that would be able to hook up to a laptop and plot out a frequency...
        02 October 2008, 12:09 Thursday
        What do you guys use to hold your microphone or SPL meter?
        I'm at the point where I'd like to have a good method to actually hold my Radio Shack analog SPL meter during my home theater calibrations. Also, my Parasound C1 processor has an auto-calbration microphone used for the same purpose...
        06 February 2006, 02:40 Monday
      • boxer82003
        my spl meter a couple of questions
        by boxer82003
        its been a year or so since i last used my meter so i have a couple of question on the setup for my system which is
        RSP-1068
        RMB-1075
        front and rear are B&W 602.5 S3
        center LCR60 S3
        sub ASW650
        here is a link to my spl meter CM-130
        23 January 2009, 22:42 Friday
