Rotel advice
    • 4157
    Rotel advice
    I am currently using a Marantz PM7200 integrated amp and am impressed (a lot) with the quality. I've been thinking about the next step up and could use some advice concerning Rotel. My Marantz has a warm,almost tube-like sound with a lot of punch in the mids and especially vocals. I like the overall sound but want "more". Any input would be greatly appreciated.
  • Joey_V
    • 436
    You looking for 2 channel or HT multichannel amplification? Also, how much are you thinking of spending and what speakers are you trying to power?
      • 4157
      This is purely 2 channel. I am driving Paradigm Studio 60 v3's. I'm pretty happy with the sound/dollar ratio.I've heard some systems that cost a bunch more and don't sound as good,but at higher volume levels the Marantz seems to be straining a bit (25wpc in class A). The Rotel based systems I've heard didn't seem to be working as hard as my amp, but I didn't really care for the sound until I heard the 130wpc Rotel. It didn't seem as bright and really handled the bass well. My source is usually a Marantz SA8260. I'm currently waiting for a Music Hall MMF5-SE turntable as I also have vinyl.
      How is Rotel's build quality/reliability? Hopefully my stereo will improve over the years and I don't want to have to keep replacing amps.I'd rather spend future money on speakers and better pre-amp.Unless I win the lottery-then it's Halcro and Watt Puppies all the way!
        For Purely 2-ch with no intention of HT use later down the line, probably your best combo would be the RC-1070 and RB-1090 if you can can get it, if not, then the RB-1080 is your next best choice.
          • 4157
          thanks. I was thinking the same thing,but $2000 is beyond my budget.(you did ask about that and I neglected to answer-sorry) the biggest hit will be the need for a good preamp. I was lucky enough to hear the Rotel through speakers identical to mine so I'm pretty sure I like the sound of the bigger amps.Shame the smaller(more affordable) ones don't sound quite the same.Gee,better costs more.that should probably not surprise me.
          The RB-1050 sounded very different from the RB-1080;is it just power or do the better/bigger Rotels get other significant circuitry improvements?
          I appreciate the time/input/help.I'm returning to audio after 20 years and losing my Tandberg amp/pre/tuner,NakimichiZX9,ADS L-1530 speakers and much more to an ugly divorce.So much has changed.....Much better quality sound is now available for much less money. Makes it harder! Kid in a candy store syndrome.Thanks again!
          • gd
            • Jan 2003
            • 583
            Your Marantz is no slouch.
            Considering you like the sound, how about keeping it as a pre, and adding only a power amp for now?... best of both worlds -- a signature sound you already like, with more control of it exerted over the speakers... upgrade the pre later.
            Furthermore, power amp is the one component you can buy used and feel good about... there is a marketplace section ('Pawn Shop') on this site, and Audiogon is a pretty good bet as well... a used power amp can be a real bang-for-the-buck purchase... lotsa Rotels on A-gon... you might even see fit to step up a notch.
            Happy hunting.
            greg (gd to you)
            Frank Zappa
              • 4157
              Thanks. Yeah,I really do like the PM7200. It almost has a McIntosh-like sound quality.With the obvious stretch for poetic license! I will indeed check out the pawn shop here.My main worry about buying used is buying another's headache,but there is probably a good chance $2000 amplifiers were loved and respected by their owners.BTW,if anyone is looking at CD players I heartily recommend the Marantz SA8260. For SACD it is the deal of the century. For redbook CDs I did an A/B with a Music Hall Maverick and preferred the Marantz. There are somewhat better sounding CD players but you'll pay upwards of 3X the cost of the SA8260 before sound quality and not preference is the difference. It also plays multi-channel and stereo SACD well enough to be hard to beat regardless of cost. As good as the PM7200 amp is,this CD player finds the areas it comes up a little short.It also points out CDs that are sub-par so audition material you KNOW is well produced and recorded.Thanks, againand I'm sure I'll be back for advice&input on potential bargains on used amps.Maybe an RB-1090.... :T
              • Joey_V
                • 436
                I bought my RB1070 used from ebay about 7 months ago and it's been fine ever since. I was about to jump on a forum deal with a 1090 but something took me out financially out of the audio game for a month and it wasnt meant to be. The Rotel 1090 used @ about $1300 shipped is a very good deal. A used 1080, I would be a little leary since many have posted about fuse problems down at the Club Rotel forum. The 1070 hasnt had any recurring problems that I've experienced or read about.
                I also bought my RC1070 used and it's an awesome preamp. Probably not as good as the 1090, but I wanted something simple.
                • BTB
                  • 198
                  Hi Alaric
                  I sold my PM 7200 about three months ago and after a short wait took delivery of Rotel RC 1070 and RB 1070 seperates. Like you I enjoyed the sound of the Marantz but also wanted "more". Specifically, better bass control and perhaps even a bit more headroom in the volume dept. when I felt like it. One of my biggest gripes with the Marantz was it's very limited "grunt" and the early onset of hardness characteristic of the early stages of clipping.
                  I've been pleased with the changes that the Rotel has made to a modest set up consisting of an Arcam CD73T and B&W 704's. The sound is alot less "fuzzy" definitely more a transistor sound than the "valve" sound you refer to. Bass is tighter,leaner and quicker, which I've come to prefer over the thick, slower sounding bass I had with the 7200.
                  BUT. I'm currently on the verge of selling the power amp. Maybe all in the mind, but I reckon the bigger 1080 power will do a better job with the B&W's. I guess I didn't realise that the jump (in loudness specifically) between the 95w rated Marantz and the 130w rated Rotel would not be all that impressive. If increased loudness is of no concern to you and the changes/improvements I've mentioned are what you're after then you could do alot worse than Rotel seperates.
                  • whoaru99
                    • 639
                    Yes, this is a point that is often mis-understood. When using the same set of speakers (or others of like efficiency), it will require an amp of 10X power increase to sound twice as loud. So, in the case of the Marantz, if it's 95wpc, it will require 950wpc to sound twice as loud.
                    Of course, you will see benefits from increased headroom at "normal" playing levels from an amp with less than 10x power increase, but purely from a volume perspective, that's what it takes.
                    Just my .02, but I probably would not upgrade purely based on "watts" unless you go at least twice what you have. Again, just my .02...
                    ----JAFFE'S PRECEPT
                    • grit
                      • 580
                      Watts really mean one thing : power to drive the speaker. No matter how good the amp, if it does not have enough power to drive the speaker (based on the speaker's efficiency), it'll sound thin. Once you reach enough power to drive your speakers, the next thing you'll notice is how various brands of amps control the speakers and what signature they impart on the sound. Classe's 100 wpc sounds more detailed than Rotels 125 wpc, but both amps drive a given speaker about as well.
                        • 4157
                        BTB,glad you experienced my amp!
                        Yeah,watts look good on paper,but the hard numbers are about as useful as going by THD percentages (within reason).I stated my perceptions poorly.It is indeed headroom differences I noticed between the bigger Rotels and my amp.At low to medium volume levels I prefer my PM7200 over most everything until we get into BIG money.The efficiency of the Paradigms also allows the 25wpc Class A circuit to really "sing",providing detail and a remarkably "black" background. The slightly harsh response at higher line output levels is the only drawback I've found. The performance of my budget system with material like Natalie Merchant's remastered Break Your Heart (horns especially) is about as good as it's gonna get for $3200,including CD player and a little extra for the cherry finish on the speakers.I won't include the cost of the Silvercat interconnects because they became a necessity 30 seconds after hooking them up. The remastered "Jealousy" (also NM) is also a good bet with my current set-up.
                        You notice the amp likes female vocals (and Ozzy Osbourne!)? The snare drums are crisp,the guitar riffs are clean,and the Paradigms deliver pretty decent clarity.I also have to be careful about volume-clean sound doesn't sound "loud" until the neighbors come over to ask what I'm playing!
                        It seems the bigger Rotels carry the bass and lower mids better at higher line output levels.Again,at low to moderate volume levels this amp really does a great job. If I take it out of Class A (25wpc to 95wpc) I get a tad more headroom but lose some of the definition-the "edges" don't sound quite as clean.Does that make sense? Anyway,I'm not chained to Rotel,just the only "affordable" alternative I've heard so far.I'm open to suggestions...I just want to be able to audition amps with my speakers.Not everything likes Paradigms,and a marginally "bright" amp makes them sound like a 5000 watt mono system.Since convincing the wife that $1600.00 worth of speakers need to be upgraded will be a large job (she's tone deaf-literally) I'm looking for an amp w/the same "type" sound that will work w/a speaker upgrade down the road.Gee,I don't want much,do I? All I need is one winning lottery ticket........then it's von Schweikerts and Halcro....or Wilson Alexandrias....
                        Thanks for all the input,folks.I really appreciate the friendly attitude of this forum.Thanks to Lex and the moderators for keeping it that way.
                          • 4157
                          BTB,I forgot to ask-what speakers are you driving with the Rotel (previously the Marantz?)Thanks again!
                          • BTB
                            • 198
                            Post re-written
                            Hi Alaric...
                            To answer your last question... I use B&W 704's. Pretty power hungry despite good rated sensitivity (90dB 1w, recommended power handling 50-150w). Sound really good and beautifully built. And by all accounts a good match for Rotel amps considering that B&W uses Rotels (amongst other brands [like Classe]) in their R&D.
                            I know EXACTLY what you mean about the "edges" of sounds being a bit poorly defined at volume, one of the things I prefer about these Rotels I've bought... a bit less "soft focus". Like you said though, Rotels are good value for money in what is essentially a difficult price range to shop in... for this kind of money it's clearly a toss up between high powered "mid-fi" (like Rotel) or entry level offerings from more heavyweight contenders... for instance Naim, Primare or Arcam. One thing all those entry level amps have in common though is low(er) power output and therefore become tricky to use with speakers like mine, in a big room, like mine.
                            If your speakers a really efficient, try out something like the Naim Nait 5i integrated, pretty grunty and sounds fantastic... very forthright, tightly focussed and really involving to listen to. I would've bought one if not for my chosen speaker constraints, I am a bit of a (hooked) B&W fan I'm afraid. But I don't feel like I'm missing out too badly at the moment. I can't think of anything that sounds as "analogue" as that Marantz, maybe check out something from the Arcam Diva range. Might well sound a bit more "focussed" while retaining some of the Marantz charms.
                            Let me know how things turn out if you try them out.
                            Good luck. :P
                            Last edited by BTB; 10 February 2006, 00:54 Friday. Reason: wanted to re-write reply
                            • gizmo
                              Rotel 991 thx deception ???
                              by gizmo
                              Hi...purchased a Rotel rb 991 Thx, to amplify my Marantz SR 7400(as pre).
                              Not noticed beter sound...loike other people said. It´s posible that cable conexion betwen marantz (preouts)----->Rotel in....down quality to Rotel?
                              I play Dynaudio 42 Speakers directly to marantz.....and...
                              04 February 2005, 16:43 Friday
                            • jrh
                              Rotel Advice Needed! Sorry so long...
                              by jrh
                              Hello everyone. I need your advice. I'm a new Rotel user...I purchased a 1056 Receiver July 25. I just got my system set up and unpacked the receiver, to find that one of the "doors" on one of the Optical Inputs was missing. The door is what locks the Optical cable into the receiver, so...
                              19 August 2005, 09:41 Friday
                            • vtwinaholic
                              Need Rotel Advice
                              by vtwinaholic
                              I had a fire a while back and I need to replace the gear I had - gear that is no longer made... So, here's what I had... What should I replace it with?... I'd like to stick with Rotel and B&W...
                              Rotel RB1090
                              Rotel preamp (can't remember the model number!)
                              B&W CDM9NT...
                              10 June 2009, 07:10 Wednesday
                            • Number9
                              Newbie needs some Rotel advice...
                              by Number9
                              Hi all, I just joined today & I'm so happy that there's a Rotel Club! I'm also kind of new to HIFI, so I don't know too much. I'm very interested in the RCD-1072, although I have not auditioned it yet. Due to space limitations I would also like to get one of their integrated amps. I was leaning...
                              26 August 2004, 15:01 Thursday
                            • mrkiko
                              Rotel - afterall the best value
                              by mrkiko
                              Hi Everybody
                              I started this thread on the B&W club, but since i'd like to ask some questions about Rotel, i think it's better to go on here.
                              I would appreciate if you guys with Rotel experience would give me some advice on how to move on.
                              I currently have a...
                              30 November 2004, 16:29 Tuesday
