Paradigm ADP 470's or Ref 20's for surrounds?
  • MattCXII
    • 90
    Hey,
    Im debating between the two above mentioned speakers for my surrounds but Im not sure which speaker will better suit my needs. I plan on listening to multi channel music and HT... of course.
    Is one better or worse for multi-channel music? I have heard that there are problems with running Dipoles for your surrounds when you want to listen to 5.1 music.
    i appreciate all your responses.
    Matt
  • mtodde
    • 66
    I'm using Studio 20s for my surrounds and really like them. They are great for music and movies. I did listening test with both the ADP and the 20 and preferred the 20s for music by a wide margin. They also fit my room better than a wall mount speaker would.
    • ht_addict
      • Dec 2002
      • 509
      My preference is exact opposite of mtodde. I had the 20's for rears but due to the room layout going with the ADP's made everything much better. My seating area is up against a wall so the 20's sat on stands to the sides directed in. With the ADP's I have them mounted on the wall above my head. The surround experience is that much better. To each his own.
      • MattCXII
        • 90
        I appreciate your comments but since I cannot hear these speakers I need to go largely on comments from you fine folks. Anymore comments that can push me to either "speaker team" would be much appreciated.
        My room is going to be 10.5 feet wide if that helps out a bit. Im a little confused as to placement as well. Should the surrounds go right beside my couch or behind it?
        • wildfire99
          • Aug 2005
          • 257
          I felt the ADP's were better for music (where you really should only have diffuse ambiance back there), whereas the monitors were far and above preferred for movies (where the rear channels will actually convey directional information).
          If I could only have one, I'd take the 20's easily. Your room is kind of small, so you'd want to mount them above the listener's heads pointing towards the ceiling I think, which kind of negates a bit of that directional effect. Your dealer should be able to set up a demo between the two.
          - Patrick
          • ht_addict
            • Dec 2002
            • 509
            If your using the 20's you'll want them behind the couch. Thats the problem I ran into since my seating area was right next to the back wall. I had to have my 20's on stands at the sides pointing in. Now if I was watching a movie by myself it was okay but for those seated on the outer edges, it was a problem. With the ADP's I made up some platforms that I mounted onthe wall above the seating area and the surround sound is that much better.
            • Leef DaLucky
              • May 2003
              • 185
              I put the 20's in as well.
              I tried out the ADP's but didn't really like the timber matching.
              Mine are toed-in, on the back wall (like Addict's old setup).
              I'll eventually have a dedicated room that the couch will be away from the back wall, and i can properly mount them.
              They're both fine, but i'd (personally) lean towards the 20's more for HT and multichannel music.
              Yes, it's true that when you have a lot of people over someone sitting right beside it might have a problem with it. But, hey, it's your system. YOU listen to it everyday and have gatherings maybe once/month? Screw the guests
              cheers,
              mikey
              "...Because Good is Dumb...!"
              -Dark Helmet
              • ajpoe
                Rotel 1068 vs. B&K Ref 50
                by ajpoe
                I've got the upgrade bug... I currently have an Onkyo TX-SR800 running my Paradigm system. I have Studio 60s v3 for fronts, CC-470 and ADP-470s for surrounds. I am looking at the Rotel vs. the B&K and my local dealer said that for the extra $300 MSRP the B&K was a no brainer. I also know some...
                13 July 2004, 20:18 Tuesday
              • ajpoe
                Setup suggestions
                by ajpoe
                I had a disappointing experience last night watching a movie. It was Hellboy and it didn't sound as good as I hoped or have experience with other movies. If a movie sounds great, it somewhat makes up for it not being such a great movie.
                What I'd like to do here is list all my equipment...
                23 May 2005, 14:56 Monday
              • Allen M
                Parasound Amps
                by Allen M
                I am in the process of evaluating new amplifiers for use in my home theater. My current set up includes a C-2 processor, Paradigm Studio 60 v3s, CC-570 and ADP-470s.
                As for use, my best estimate is about 60% HT and 40% tereo/mutichannel music.
                Anyway I've been reading...
                16 January 2004, 17:52 Friday
              • ajpoe
                B&K Ref 50
                by ajpoe
                I see that there isn't much activity here so I thought I'd throw this out there and see if may be some different readers have some opinions to offer. I posted a similar thread on the general HT forum prior to doing as much research. I've read in previous posts about the issues with the popping and clicking....
                15 July 2004, 10:57 Thursday
              • slarson
                CineNova or RMB-1095?
                by slarson
                Has anyone ever compared the CineNova Grande to the RMB-1095?
                I'm currently using a Pioneer Elite VSX-39TX with Paradigm Studio 100s v.3, CC570 and, ADP-470s v.3
                12 December 2005, 21:55 Monday
