What's a reasonable budget for fronts using RSX 1056 and RB-1080?
  • DUCKY
    • 23
    Gents,
    I am looking to upgrade my stereo speakers. I am currently using a self made Seas Scanspeak set (called 'the standard'). They are quite good and have awesome lows but I am looking for more refinement in the highs. I have very sensitive hearing (I hear high pitched sounds very well that my friend and colleagues can't hear at all). The 'standard' set me back about 750 USD in materials.
    Although I am building a 5.1 set, my main priority for quality of sound is for music which I listen to in stereo.
    My current total set are 'the standard' fronts, a self made VIFA center speaker and I just added two Monitor Audio RS1 speakers as rears. I was blown away by the sound from these little speakers, certainly at the price.
    Now for the question. Whilst listening to several speakers and reading reviews. I am tempted to go higher and higher into the high end speakers. For me spending anything up from 2500 USD on speakers is still very frightening.
    I used to think it made sense to spend around the same amount on speakers as on your amp. So that would give me a budget of around 1600 USD only counting the 1080 and a little over 3000 USD if I include the cost of the 1056. What sounds fair to you guys? What would you consider a balanced cost of amp and speakers and can you recommend speakers with very refined highs in that budget?
    Thanks for any suggestions!
    Lennart
  • Kevin D
    • 4601
    Moved here since it's more speaker related.
    I personally don't think you can make any associations with price. Today you have amps that perform as well as higher priced ones and speakers that perform worse than lower priced ones. Hopefully you will get some recommendations and let your ears decide.
    Kevin D.
    • csuzor
      • 413
      I asked a similar question here http://www.htguide.com/forum/showthread.php4?t=16190
      and would now simplistically conclude, speakers should be about 60% of total cost of an Audio system, and about 40% for an A/V system.
        Twin Moderator Emeritus
        • 16706
        I'd say anywhere from $1500-$2500 (and up if you have the $$ ) for you would be good.
        I like models from B&W, Energy, PSB, Paradigm, Totem an Vienna Acoustics myself
        • Bob
          • Jul 2000
          • 800
          Kevin is right, price doesn't always translate to what sounds best to you. I was prepared to spend up to double what my speakers cost. Just couldn't find any that sounded better to me in the price range I was looking at.
          I don't think you can think in terms of percentages in regards to what part of your system costs what. I have a simple two channel system(see profile), one turntable, a moderate CD player, a preamp, amps, and speakers. No surround sound or multiple speakers and my speakers only represent about 30% of the total cost, less if you throw in room treatments. It seems to sound o'k to me.
          In choosing your speakers you should decide what you can afford and then go listen to speakers in that price range, and below. If you have friends that have speakers that you like but, are out of your price range, consider used. Although, I would be reluctant to buy from anyone so far away that you can't drive there to pick them up.
          Also, in regards to buying used. Please don't go to a dealer and waste his time showing you speakers that you intend to buy used over the internet. Unless, you at least purchase other items from him.
          If you ask here what to buy in a certain price range, everybody will tell you to buy whatever they already own. Including me, so buy Vandersteen. You can get new 2ce's in your price range or used 3A's
          • thyname
            • 358
            .. so am I: buy Axioms. I own Axiom M60s with Rotel RB-1080, RC-1070 and RCD-1072 in a stereo setup. I love my system! It would be great if you can find somebody in your area to audition the Axiom (they are a Canadian internet company), so did I , and was sold. You can go to www.axiomaudio.com/boards to find somebody for audition under "Hearing things" thread. Or you can get them shipped free to your house, to audition them with your own gear. The only thing you pay is the shipping back if you are not satisfied. They cost USD 900 shipped free. Now, if you have the money get B&W 703s for around USD 3,000 or Paradigm Studio 100 for around USD 2,300.
              • 16706
              OK... Buy Energy's! :lol:
              • soundhound
                • Mar 2004
                • 816
                Klipsch
                • gd
                  • Jan 2003
                  • 583
                  Monitor Audio... esp since you already have positive experience with the brand.
                  Totem Acoustic is also a cut above.
                  And yet another shoutout for Vandersteen.
                  Is there a sub in your setup?
                  greg (gd to you)
                  Frank Zappa
                  • theMaximus
                    • 179
                    I would highly recommend B&W 704s ($2200 US MSRP). You would probably able to get them for about $2000. I have RSX-1056 and RMB 1070 with 704s, and I absolutely love how they sound.
                    Victory Shall Be Mine!!! :heh:
                    • Bob
                      • Jul 2000
                      • 800
                      See, I told you everyone would start reccomending whatever their present speaker was.
                      • thyname
                        • 358
                        Yes, it is true, but I actually recommended speakers other than mine in addition to my Axioms However I felt that the difference in price between those two models and my Axioms was much higher than the difference in quality. It is all about budget, best bang for the buck, and that's always individual.
                        • audiofan
                          • 272
                          I have Totem Forrest which paired pretty well with Rotel RC-1070, RB-1080. However, i will soon move to Musical Fidelity integrated Amp A5.
                          • RebelMan
                            • 3139
                            Have you heard Bryston with the Totem Forests??? I can't say that I have heard the MF's but I have the Brystons. I couldn't believe how good they were. In fact they put my 803S's with the Arcam FMJ
                            's to shame. I almost regreted getting the 803S's until I realized the power behind that sweetness was all about the Brystons. Listen to them if you can.
                            • RebelMan
                              • 3139
                              Jason didn't and I second every one of his suggestions.
                              • DUCKY
                                • 23
                                There is no sub yet, because currently both my fronts and center have very good lows.
                                I auditioned a couple of speakers yesterday, among others the MA reference 60 and the B&W 804s. I must say the MA's didn't really float my boat. There seemed to be a hint of echo in the vocals. Nice clean sound though, but since I love vocal (jazz) music (Ella Fitzgerald, Harry Connick, Norah Jones, Diana Krall etc) this worries me a bit. The vocals in the tiny RS1 seem better somehow. The 804s's sounded right to me. Crisp high and decent lows but somehow I am still hoping to be pleasantly shocked by a set of speakers. Somehow I feel the extra 3500 USD (compared to my current set) should give me a bigger increase in sound quality. Damn my homemade speakers
                                If only they sounded much worse, the choise would be so much easier.
                                Thanks for the suggestions! I will have to try the Vandersteen, Axioms and Klipsch....
                                I will keep you guys posted.
                                Lennart
                                • thyname
                                  • 358
                                  Are you giving up your Rotels??? Do you think that an integrated amp would sound better for 2 channel music than your Rotel separates?!
                                  • Bob
                                    • Jul 2000
                                    • 800
                                    Be careful of any speakers that really grab your attention by sounding different from the rest at first listen. Go back several times and really listen for the characteristics that you want from a speaker, and listen for at least a hour.
                                    Speakers that really sound like music (i.e. the piano sounds like a piano, the stand up bass sounds like a stand up bass, etc.) often sound a little bland at first listen compared to speakers that are made to be overly bright or with unrealistic sounding bass.
                                      • 16706
                                      Good advice there :T I agree, all "good" speakers will sound "good". You just have do decide which brand/model of "good" you prefer for the money... that's the tricky part! :lol:
                                      • audiofan
                                        • 272
                                        I have never heard of Bryston, but MF
                                        MF integrated amp A5 is basically two monobocks in one box. I wish i could go with separate MF, but my budget is limited. So, i will stick with integrated amp until i have enough budget for MF separate.
                                          • 16706
                                          NEVER HEARD OF BRYSTON??!?!?!?! :E :scratchhead:
                                          • philly boy
                                            • 26
                                            I ditto the recommendation of Vandersteen. Very natural sounding, lets you hear the recording without coloration. They take time to break in, but the wait is well worth it. I live in Vandersteen heaven.---Philip
                                            • audiofan
                                              • 272
                                              I mean i haven't listened to Bryston yet...
                                              • alebonau
                                                • 992
                                                The mf integrated is in a completely differnt league to the rotel combo your talking about. Improved clarity/definition, sound stage, openess and a lot more slam & bite. Very differnt sounding though than the rotels I would have thought. Make sure you demo with the speakers in question to ensure its what your after.
                                                I had a listen to the a5 integrated and then I made the mistake of listenign to the mf A5 separates - theyre on a whole different level again !
                                                you might want to check some posts in the club mf section
                                                • alebonau
                                                  • 992
                                                  http://www.htguide.com/forum/showthr...1&page=1&pp=35
                                                  re speakers to go with the mf I heard them with pmc fb1 and ob1 both very special speakers and not sure if available where you are. A very natural sound and good match to the mf's.
                                                  • Bob
                                                    • Jul 2000
                                                    • 800
                                                    Now that we have "informed" you with all our prejudicial, and pretty much worthless advice, let us know what you decide to do. Especially, do you still think that there is a formula for how much you should spend on any particular peice of audio gear.
                                                    • Tarheel72
                                                      Rotel 1056 or 1058? Help me out here.
                                                      by Tarheel72
                                                      My trusty Harman Kardon AVR635 seems to have given up the ghost. I am looking at these two older model Rotel's as potential replacements but think I might have some issues. I currently run all video direct to the display (BR, Cable, xBox) and use digital audio inputs for the cable and xBox and analog...
                                                      18 May 2011, 09:40 Wednesday
                                                    • Highroller
                                                      Ground loop problem to my 802di fronts and HTM2di center
                                                      by Highroller
                                                      I have a hum in all three of my front speakers.
                                                      The two fronts and center are connect to seperate MC501s connect to their own dedicated circuits.
                                                      The MC501s are connected to an MX120.
                                                      I have an MC207 connected 803S's in the back. The MC207 is connected...
                                                      06 March 2011, 23:09 Sunday
                                                    • windshear
                                                      Surround Speakers
                                                      by windshear
                                                      I have just changed my front speakers B&W 801 SIII and HTM1 to an 802D and HTM1D. Now my problem is as follows. My side speakers are a pair of Dm604S3 and my rears are Dm640i's. I have always preferred the idea of full range speakers even as surrounds as there is no compromise in terms of sound....
                                                      06 March 2010, 04:05 Saturday
                                                    • wackii
                                                      surround speakers
                                                      by wackii
                                                      Summer is near...it's time for some projects. I want to build a pair of surround speakers. My budget is around $120 for the pair, drivers + crossover components. I will build my own cabinets. I don't want the cabinet too deep as I need to hang them up on the back wall where my sofa is pushed back...
                                                      07 April 2011, 02:49 Thursday
                                                    • Brewer
                                                      Wireing Speakers
                                                      by Brewer
                                                      I liked to explore all options on hooking up my speakers .I have a Kenwood 504 HT ,What im thinking of doing is wireing the book self speakers togeather and make them the center speaker then use my loud speakers as my fronts.
                                                      10 March 2002, 13:09 Sunday
