Wireing Speakers
  • Brewer
    • Feb 2002
    • 14
    Wireing Speakers
    I liked to explore all options on hooking up my speakers .I have a Kenwood 504 HT ,What im thinking of doing is wireing the book self speakers togeather and make them the center speaker then use my loud speakers as my fronts.
    What are you doing when your not do something else :roll:
    Kevin A Brewer
    Kevin A Brewer
    • 27461
    Brewer, just be aware that if you wire those speakers "together", you may be presenting your receiver with a "halved load". That means, if they are 8 ohm speakers, you will then be running at 4 ohms. This could be dangerous over the long haul to your receiver.
    As to the loudspeakers, depending upon where the volume is set, is that true of any speaker?
    Goodluck,
    Lex
    • Kevin P
      • 10809
      You will probably be better off hooking just one of the bookshelves up as a center and then positioning it over the TV.
      What kind of speakers do you have? If your fronts and center are poorly matched (sound quality/timbre wise), you might be better off without a center at all, until you can get matched speakers. If you're in the "sweet spot" you don't need a center at all; it's more to benefit those who are off center relative to the fronts.
      KJP
      My HT Site
