Ground loop problem to my 802di fronts and HTM2di center
  • Highroller
    • Jan 2010
    • 27
    I have a hum in all three of my front speakers.
    The two fronts and center are connect to seperate MC501s connect to their own dedicated circuits.
    The MC501s are connected to an MX120.
    I have an MC207 connected 803S's in the back. The MC207 is connected to the MX120.
    I have three source systems connected to the MX120. A direct TV receiver, and Oppo 83 Nuforce and an MR88.
    The hum only comes of the fronts and center.
    The hum also only happens when going from 0 to 1 on the MX120 and then stays constant as I increase volume.
    I have disconnected the direct TV from the MX120.
    I would really appreciate any thoughts on how to best isolate this issue. Not sure where to go next.
    Many thanks
  • emig5m
    • Aug 2008
    • 646
    I was going nuts trying to figure out a hum problem that only seemed to come out of some of the channels and it turned out to actually be the patch cables going from the pre/pro to the power amp. I replaced them with higher quality cables and the hum went away. I did verify the faulty cables by switching them to other channels. They where cheapy Monoprice cables so I just threw them out. The cables I replaced them with was Bluejeans... no more hum (actually it was more like a "buzz")
    • stuofsci02
      • 1241
      Sounds like a groundloop issue. I believe it is because your MC501s are on a different circuit then the pre/pro. If the amps have a three prong plug they will be grounded to their circuit. Same thing with the Pre/Pro, but it will be grounded to a different circuit. Then once you connect them together with RCA or XLR they will be grounded to each other and the loop is born.
      You can test this theory by connecting your Pre/Pro to the same circuit as your 501s. This will likely cause a hum out of your rear speakers if the 207 was on the same circuit as the pre/pro.
      If this is the case it can be fixed...
      Cheers!
      Main System:
      B&W 801D
      Emotiva USP-1 Pre-Amp
      Chord SPM-650 Stereo Amp
      Oppo BDP-105
      Squeezebox Touch
      Second System:
      B&W CM7
      Emotiva UMC-1
      Emotiva UPA-2
      Oppo BDP-83SE
      Grant Fidelity DAC-09
      • Highroller
        • Jan 2010
        • 27
        Thanks. I will try that later this evening.
        fyi... each of the MC501 are on there own seperate circuit... 3 MC501s/3 separate circuits..
        so, I am not sure how to correct the problem if you theory proves out.
        I will try it later this evening and let you know.
        Many thanks
        • Highroller
          • Jan 2010
          • 27
          I tried connecting the pre amp to the same circuit as the MC501 circuit that powers the left front. the hum was still there in the left front.
          So, I am not sure where to head next..
          Thanks for the suggestion..
            Please confirm that your interconnects are separated from your power cables.
            • aarsoe
              • 795
              Start by turning everything on to be certain that the hum is still there. Then either mute or turn of the power amps and unplug one source and then un mute or turn your amps back on to see if the hum is still there. If it is then leave the source unplugged and repeat with the next source etc..
              If all sources can be removed without any reduction in hum then remove the back channel amplifiers. If there is still hum then disconnect the front amplifiers one at a time to see when then hum disappears.
              When you find the unit doing it the first try to change the cable you are using to see if it is defect. Alternatively if you based in Europe (your profile does not state where you are) see if you can turn the power plug 180 degrees to ensure that is not the issue. Normally that will not be an issue in the US.
              As a general word of advice I suggest buying a cable tester. Behringer makes a nice cheap one that can test RCA, XLR and jacks for headphones. Have too many cables that have been pulled from the pile with a bit more force that they where designed to deal with. Now if only they had a version with HDMI testing as well then that would really be something.. :-)
              • jericho
                • 280
                I had the same problem in the beginning with my setup.I have 3 McIntosh 1201's, two 501's and two 252's.
                I had a lot of hum in my fronts and was told I had to disconnect the ground cable in the electricity plug.I did and everything was ok!!!Just give it a try
                • style
                  • 1562
                  @jericho,
                  yes is you go "cut" the ground from your power cord the hum will be no more present ..but 8O is not so good for your system.
                  I understand why the power souplly/ power conditioner are so used in Usa!!!
                  dont have the ground is a "risiko" for your gears!!
                  this is the last card to play. you muss try to reconnect all your units . a single unit or a cable make the ground noise in your front speakers. maybe without a player, a source (and reconnect it after) you can have a better solution.....
                  style
                  • Highroller
                    • Jan 2010
                    • 27
                    Not sure I fully understand you question... but I will try to describe in more detail..
                    The three MC501s are connected to different 20 amp circuits in the wall. The MC501s are then connected to the 2 fronts and 1 center.
                    The MX120 is connected via blue jean balanced interconnects to each of the MC501s.
                    The MX120 is also connected to a MC207 powering the 803s in the back.
                    The 803s have no hum. The fronts and center have the hum.
                    Hope that answers you question
                    • Highroller
                      • Jan 2010
                      • 27
                      Would it be okay to unplug the cables at the source rather than at the pre amp? It is much easier for me to do it this way but I want make sure that i have a valid test.
                      Also of note, the MC207 has a hum with the unit itself. I wonder if that would indicate it is the culprit?? I will certainly try it..
                      Is a ground loop just and irritation or does it hurt your system?
                      • jericho
                        • 280
                        I'm using the amps without ground connection now for a few years, no hum, never had a problem. Don't use power conditioners with larger amps because you will use dynamics.
                        Just give it a try, only for a few minutes, and connect it again, you'll notice the difference
                        Regards
                        Jericho
                        By the way, we have 220-240 volt here in Belgium
                        style[/QUOTE]
                        • style
                          • 1562
                          sorry jericho,
                          not see that you are in Belgium.
                          +100 for dynamic loss with power supplly....
                          when I had a Mc207 my left speaker have a hum too: with the "supressing" from the ground all work very fine like in your system.....
                          I understand your mean but the ground if is present is for a reason are present or?
                          (an electrician can give you technical answers ...)
                          you have a dedicat line ?
                          style
                          • Rod#S
                            • Oct 2010
                            • 474
                            Regards
                            Jericho
                            style
                            [/QUOTE]
                            I find this depends on the power conditioner and shouldn't be said in such a way as to be a blanket statement. I use 3 relatively high output amps, 2 Bryston 4B-SSTs and a 6B-SST and all 3 are plugged into a Furman IT-Reference and I have never been able to notice a difference in performance when I have plugged them into the wall for comparison. The amps are all spec'd at beween 330-340 watts per channel. Before I had the 3 amps, just one 4B-SST I had that plugged into a power bar and indeed there was a noticeable effect on dynamics in that scenario when the amp was plugged into the wall. I noticed the same thing with my previous 5 channel Anthem MCA-50 amp. No noticeable difference between the wall and Furman but a definite difference between the power bar and wall.
                            Now having said that, would I notice a difference between the wall and Furman with say Bryston's 14B-SST stereo amp or their 7B-SST or 28B-SST mono blocks, possibly as those put out a lot more power, 600 watts per channel for the 14B-SST/7B-SST and 1000 watts for the 28B-SST. It would be an interesting experiment.
                            Rod
                            • jericho
                              • 280
                              Rod[/QUOTE]
                              I didn't mean you have to take it as a blank statement my expression about those conditioners, but in my case, using McIntosh 1.2Kw amps and 501 amps, I can tell you there is a lot of loss in dynamics
                              Regards
                              Jericho
                              • Rod#S
                                • Oct 2010
                                • 474
                                Wow, so you are running 2 1.2Kw amps and what, 3 or 5 501 amps? Man that is some serious power. Do you have dedicated circuits? Your speakers must truly sign with that kind of juice. Is that a picture of your front end in your avatar, 800D and HTM1D? What are you using for surrounds, subs (they look like B&W) and SSP?
                                Rod
                                • jericho
                                  • 280
                                  Rod
                                  The system is more or less like the avator but there is al lot more :
                                  2x 1.2 Kw McIntosh on 800D as front
                                  1x 1.2 Kw McIntosh on center HTM-1D
                                  2x 501 McIntosh on surrounds 802D
                                  2x 252 McIntosh in bridged mode on back surrounds 803D
                                  2x sub ASW855
                                  1x sub ASW825
                                  2x sub DB1 (will arrive next month)
                                  Processor MX150 McIntosh
                                  Blu ray McIntosh MVP881
                                  DVD McIntosh MVP871
                                  MCD/MDA 1000 combo McIntosh
                                  MS300 & MS750 Music Server McIntosh
                                  Wadia 171i
                                  Sonos system
                                  • Rod#S
                                    • Oct 2010
                                    • 474
                                    2x sub ASW855
                                    1x sub ASW825
                                    DVD McIntosh MVP871
                                    Wadia 171i
                                    Sonos system
                                    8O ;x( OMG! That is one SERIOUS setup. Are you adding 2 DB1's for a total of 5 subs or are the DB1's replacing the 2 ASW855's?
                                    • wettou
                                      • 3389
                                      2x sub ASW855
                                      1x sub ASW825
                                      DVD McIntosh MVP871
                                      Wadia 171i
                                      Sonos system
                                      Sweet :B Pictures please
                                      • dukester
                                        • Sep 2010
                                        • 198
                                        2x sub ASW855
                                        1x sub ASW825
                                        DVD McIntosh MVP871
                                        Wadia 171i
                                        Sonos system
                                        Wicked set-up...amazing that you disconnected the gnd wire. Not because i'm an electical expert but bec i've always been told to never do that. Someone in this forum has got to be an expert on this topic and will hopefully chime in.
                                        Off topic
                                        Jericho: I have a 171i on order...w/c DAC are you using? How is your 171i connected, and how is the sound quality through your 800D's?
                                        McIntosh C2300/MC302, NAD T785, Oppo 83se & 105, Squeezebox Touch, AppleTV, B&W 803Di/HTM2Di/M1, REL G1, Sony XBR9, PS3
                                        • scanido
                                          • 548
                                          2x sub ASW855
                                          1x sub ASW825
                                          DVD McIntosh MVP871
                                          Wadia 171i
                                          Sonos system
                                          unbelievable awesome setup!!
                                          • jericho
                                            • 280
                                            Off topic
                                            It's connected with a digital Wireworld cable to the MDA1000 Dac.Using the iphone or the ipod with ALAC files it give's a pretty result, I can not hear the difference with the original cd.
                                            • Rod#S
                                              • Oct 2010
                                              • 474
                                              I second this motion! :B
                                              • wettou
                                                • 3389
                                                The best way to resolve ground loop issues is to have a dedicated line and poof the ground loop issues go away :T :B
