I will not be able due to the layout of my room put the surrounds to the sides of my listening/viewing area. I can however put them behind my listening/viewing area 3ft above ear level along the back wall,will this be just as good sound wise as having them to the sides or will this take away from experiencing surround sound the way it is meant to be.
surround placement question
Can you suspend them from the ceiling and angle them downward so that they point at the listening position from above and to the side?.
I can essentially put them on the side but they will be unevenly spaced from my viewing area.For example the right surround will be 4ft from my L.V area and the left surround will be about 6ft.Would this work better than having them on the back wall?Originally posted by David MeekCan you suspend them from the ceiling and angle them downward so that they point at the listening position from above and to the side?
My main problem is do i go with perfectly placed back surrounds with no side surrounds or go with side surrounds that are not perfectly placed they will be somewhat close but not ideal the backsurrounds will be positioned perfectly.Whats your thoughts?- Bottom
look for alternate solutions
Can you put in delays in each surround channel seperately for side placement ??
Can you shift your seating a bit so that in case of side channels, so that the distance is same ???.
Can you put floor Stands on both side within equal distance ????
Can you find a wall mount which can be fixed with an extended arm so as to bring the distance to similar levels at both sides. ???
If you cant answer "Yes" to any of the above, I suggest you try placing them on the floor on the back or side of your seating facing up and see the results, otherwise put them on the back wall.
"Need is the mother of all Inventions"Need is the mother of all Inventions.....I am needy- Bottom
Guess I'll start with my setup so far and what I plan to do. So far I have a pair of RP6000F's run by a Denon X3500H(7.2 / 5.2.2). I ran audyssey XT32 room calibration. Kept the XT32 room Eq. But disabled the dynamic stuff, dont really need volume control. I planned on getting pair or rp500m for surround...-
by owl1I have a desire to go to a 7.2 setup with currently comprising 803S mains HTM3S center and SCMS rear surrounds as well as a velodyne DD15 sub and Cambridge soundworks sub. I just picked up over Christmas holiday the Pioneer Elite Rcvr 94 and BD95 Elite Bluray disc player so I can hear the latest surround...-
Channel: Club B & W Speakers
by buzzyngI am moving to a new house that is going to provide some challenges for the home theater setup. I am new to this and been reading alot of past posts but still am not sure the best config so I thought someone might be able to assist.
The room has walls on the front, right side, and rear...-
by russforrestI am thinking of making surround speakers for my home theater. It is a 5.1 system and the couch is up against the back wall based on space in the room. The design I was thinking of was a rectangular box maybe in the 8"w, 8"d, and 11" - 12" tall range. Could be slightly larger...-
Channel: Mission Possible DIY
by jakermcI finally got around to adding rear surround speakers to bring the system up to 7.1 and I have a few questions:
How has everyone gone about setting the speaker levels for proper playback levels. I remember hearing somewhere that adding the rear speakers doubles the volume output in reference... - Loading...
- No more items.
