Looking for some subwoofer advice
  • springer49
    • Oct 2004
    • 82
    I am currently looking at a few different subs and would like some advice from those that own any of these.
    On my immediate list are the Sunfire Signature EQ, B&W ASW-800, and the Velodyne SPL1200 series 11.
    I listen to 50- 50 music,HT and the sub would be matching up with B&W804's,805's,HTM-1. I have considered the SVS subs but I think they are just to large for the space.
    Thanks in advance for any wisdom that you can relay.
  • springer49
    • Oct 2004
    • 82
    sorry, meant to put this in Audio Hideout. Can you please move me there. Thanks
      Twin Moderator Emeritus
      • 16706
      Have you considered HSU Research or a DIY sub? Of the ones you listed I'd likely go for the Velodyne. You should look in to their Digital Drive units as well :P :T
      • springer49
        • Oct 2004
        • 82
        I have heard about HSU but haven't read up on them. DIY is probably out of the question because I don't have the tools necessary.I can get the Velodyne for about half the cost of the Sunfire and the B&W so that may be the way to go.
        • Spookyslow
          • Oct 2004
          • 54
          I don't mean to make your decision any more difficult, but I've got a Sunfire EQ and love it. Once I found a nice spot in my room and tuned it correctly it's really pretty amazing. There are points in movies whenwe don't hear anything but just feel a rumble in your chest--from a 13x13 cube!
          I opted for the Sunfire for it's performance and size. My wife wasn't too excited about having large black monolith in the room. If you look, you may even find one on Audiogon for a real deal.
            Thread moved per request.
              • 16478
              How large a box can you deal with?
              • springer49
                • Oct 2004
                • 82
                I have an old velodyne now that is probably a 16in. cube so I guess something a little larger. What I am looking for is the best musical sounding sub for the buck.
                  • 16478
                  If you really want to stay small I'd suggest trying one of these units out.
                  If you can go with a little larger box and a higher priced sub there's little out there that will sound as good as the kilimanjaro. Both of these are sealed designs which will suit your music requirements and the kilimanjaro unit will excel at Home Theater as well. The kilimanjaro is essentially what I run in my room for pretty much the same reasons you're looking for a musical sub.
                  • springer49
                    • Oct 2004
                    • 82
                    Andrew, Thanks for the info on some subs that I am not familiar with, of course this just makes my decision that much tougher. But that's what makes this hobby so much fun.
                    I will let you know what I end up with after I get my tax return back.
                    • Patt
                      • 922
                      Whoa boy! those Acoustic Vision subs suuure look good...makes me want to trade in my big black cylinder
                      ......Pat
                      • vaa
                        • 15
                        Hey Andrew,
                        What made you go with that sub? have you had any other ones? how well does it wotk for movies and music?
                        • Bent
                          • Sep 2003
                          • 1573
                          Andrew is sorta "new" to the subwoofer world... :rofl: :rofl: :rofl: :rofl: :lol:
                          oh wait....
                          :rofl: :rofl: :rofl: :rofl: :rofl:
                            • 16478
                            Hey Andrew,
                            To answer your questions I've actually never owned a comercial subwoofer as I've always built my own. I've built over a dozen subs using everything from 10" to 15" drivers in various configs (Ported, Sealed and IB) with each having things I liked about them. This recent version was more or less a desire to try out the new XBL motors in the Tumult driver to see if it lived up to the hype...and it does
                            • brian p
                              • 5
                              i'm confused on subs too, thinking i might go with the diy subs from p.e. either 1 12",
                              or two 10's. i dunno. i'm in a large basement. maybe i'll be able to turn them up enough so i won't hear the wife pounding on the floor when she gets mad. did you here somethin' bud? nah...have another, rack em up.
                                • 16478
                                I wouldn't use a 10" driver if you have the choice...they'll bottom out to easily. Actually given the minimal cost differences get a single 15"...it'll be a much better long term investment.
                                • mduke
                                  • 9
                                  Try the JM labs SW900. Can put out some SPL and is very misical. Retail is $2000
                                  • denverdoc
                                    • 66
                                    Or the Definitive Tech Ref super cube--but appreciate in advance that even with 4kWatts as in 4000, your 16 inch cube will be blown away by bigger, well designed competitors. Its a compromise--want a small footprint, get a Sunfire or Definitive, want take no prisoners bass then bigger box will win. Best big box is no box at all as in Infinite Baffle. There the prince and scholar of bass presides,
                                    John
                                    • RobP
                                      • 4747
                                      Try out the B&W ASW850, Yeah I know they ARE overpriced, but they do sound great. You can pick them up for around $2000 right now pre-owned or demos.
                                      Robert P. 8)
                                      AKA "Soundgravy"
                                      • slowrey
                                        How much power do I really need?
                                        by slowrey
                                        Hi everyone, I am quite a newbie to this world but I've always been a home theater enthusiast. The receivers I've owned were Sansui, Sony ES, Pioneer Elite and Integra Research.
                                        I'm at a dilemma, I currently have a RSX-1057 in my house running NHT SB3's for fronts, SC2 for center and...
                                        08 August 2006, 22:28 Tuesday
                                      • bandit788
                                        Which of Three Subs???
                                        by bandit788
                                        After reading reviews, I am still not sure which of these three subs would give me the most bang for my little sub budget:
                                        Velodyne DPS-10 $450.00
                                        SVS PB10-ISD $429.00
                                        HSU VTF-2 MK2 $499.00
                                        They are comparably priced. The only one I have been able to...
                                        20 November 2004, 05:43 Saturday
                                      • Tallen2_34
                                        New HT Matching Question: Rotel & Paradigms
                                        by Tallen2_34
                                        A buddy of mine contacted one of those home theater specialists who pieced together a package for him:
                                        Receiver
                                        Rotel RSP-1068
                                        Amp
                                        Rotel RMB-1095
                                        Front Speakers
                                        Pradigm Reference Stuido 100
                                        Paradigm cc-570 Center
                                        25 July 2004, 11:50 Sunday
                                      • monkeyboy69
                                        802D crossover
                                        by monkeyboy69
                                        Ive recently obtained a couple of these that now sit proudly as my front pair with some 805 in the rear and a htm4 at centre (hopefully to be changed ). Anyhoo in my previous setup i was using a velodyne spl1200 sub for all low end film effects and was now wondering 2 things
                                        a) whether i should...
                                        07 May 2009, 10:17 Thursday
                                      • weijst
                                        RSP-1068 replacement...
                                        by weijst
                                        Hi guys,
                                        It's been a while since I've posted on the Rotel forum. Nice to see the club is still alive and kicking!
                                        I'm considering a pre/pro replacement, on which I'm hoping to receive some feedback.
                                        I'm being offered a nice deal on a matching Classe SSP-...
                                        06 December 2009, 18:45 Sunday
