Rear surround in ceiling options
  • Scareurpasenger
    • Jan 2017
    • 157
    So, we took on a major remodeling of the living room and removed an entire wall. This also means the drywall is open and ready for running wires for in-ceiling speakers as rear surrounds. We don't really have space for ear-level surrounds with the way the room is connected to the other spaces.
    Given the DIY high end route, I am headed in, what would make sense for the ceiling, and could I make them work as the rear surrounds?
  • BW4me
    Adding rear surrounds advice needed
    by BW4me
    I currently have a pair of CDM7NT's for my speakers with the matching CDMCNT center. I'm now trying to decide what to ad as my rear surrounds. I've been temporarily using my old paradigm bookshelfs some of the time because I have to set them up on a counter behind seating and run the wire across the...
    18 April 2006, 23:46 Tuesday
  • BlazeMaster
    DS6/DM600 as rear surrounds?
    by BlazeMaster
    As title says it all, which should I go with to use as rear surrounds? I have the Denon 2805 which is compatible with DPLIIx and will be using the DS6 as side surrounds for sure at about 2 feet above ear level when sitting down. The saving of $$ by going to DM600 can apply to my upgrade of fronts...
    10 October 2004, 20:56 Sunday
  • happy
    Rear surrounds and center channel size vs quality
    by happy
    I have a pretty small living room - 12 x 12 - in which I now use a pair of Natalie P's in a two channel system which sound wonderful, but I am wanting to switch to a 5.1 HT setup to expand my movie listening. I will use the Natalie's as my main/front channels and was thinking of using a pair of cr...
    20 December 2007, 22:07 Thursday
  • mskvarenina
    Location of rear surrounds
    by mskvarenina
    In a 21 x 14 sized room I can easily mount rear surrounds (in a 5.1 system) on the rear wall (14') but how mad is this compared to moving them to the sides?
    23 October 2011, 22:30 Sunday
  • Doug S
    Receiver connectios/rear surrounds??
    by Doug S
    Hello...I have a couple questions for you guys and wodering if you can help me out here....I have a yamaha 5280 receiver...I have it hooked via my digital output coming out of my PC to digital imput in on receiver is this the best source or am I better off going analog signal???
    29 January 2005, 11:23 Saturday
