Surround Placement Question
  • SurferJoe
    • Oct 2011
    If somebody could shed some light on the best position for surround speakers in my room (please see diagram) I would be forever grateful. I'm not sure whether I should go with an in-wall in the column, a bipolar that could also be used as a dual mono for 7.1 or an in-ceiling speaker. Also what height would be best. The listening area is very close to the back wall in-fact only 3 ft. Or would a stand based book shelf speaker be best. I'm hoping one of you theater geniuses can help. Also I might want to do 7.1 or even 9.1 using in-ceiling speakers at some point. Side walls are not an option for me (nowhere to mount them).
    Joe
Name:	surround diagram.jpg
    Last edited by theSven; 26 March 2023, 11:21 Sunday. Reason: Update image location
  • fbov
    • Jun 2008
    • 479
    Here's a fairly complete answer.
    • SurferJoe
      • Oct 2011
      Thanks, This looks like an interesting document.
      • Paul W
        • Oct 2004
        • 552
        With no sidewall locations, you have a very tough situation. IMO, the front "wides" and side surrounds are even more important than rears. If you can't change the room, I'd go for the highest quality ceiling speakers at the front and side surrounds. Add rears as you can.
        Paul
        • brent_s
          • 89
          For more pictures, less words ;-) Straight from the horse's mouth, so to speak.
          If properly placed surrounds to the side are not possible, the best option shown is probably the inwalls, but moved to the outer columns. Better, IMO, would be bookshelf speakers on adjustable speaker mounts or speaker stands at the outer columns so you could get closer to Dolby's recommend angles for the side surrounds by toeing them in. Without proper side placement, 7/9.1 or more with side and back surrounds would not be recommended.
          -Brent
          • Travis
            Statement Mini and Center/Surround Speaker placement.
            by Travis
            Hoping someone will help me with this dilemma.
            I plan to eventually build the Mini Statements for my mains, Mini Statement center channel (Center) and have read that the center channel can also be used as surround (side) and surround (rear) speakers?? This will be for a 7.1 system.
            Question...
            24 January 2012, 13:11 Tuesday
          • saurabh
            Direction of Surround Speakers and other placement
            by saurabh
            hi,
            Pls see my room layout attchd with dimensions. The height of my room is 9.5 ft and I cannot change the layout much except for bringing the TV to the left slightly so that its more in line of sight with the Sofa. I will leave 20%(as suggested by an acoustic engineer) of the total length...
            24 March 2005, 00:57 Thursday
          • Clive
            Diffused? Confused!!
            by Clive
            I have 2 questions
            (1) I was reading the May copy Of AVI about surround speaker placement. When I joined this forum I was given advice to elevate my surround speakers and re-do placement. This I have done, thanks to you guys with great results. I had my rears removed from immediately beside the...
            23 March 2002, 02:10 Saturday
          • Stoopalini
            7.1 Speaker Placement ?
            by Stoopalini
            Now that I have enough speakers for 7.1, I would like some advice on where to place them.
            I now have a NHT Supercenter, 4 NHT Superone's, a home built 12" Shiva sonosub, and 2 Sound Dynamic RTS-1's.
            I'd like to know the optimal placement of these speakers in my room....
            06 April 2008, 08:50 Sunday
          • geointl
            CCM80 surround placement help
            by geointl
            I am ready to install my in-ceiling ccm80 b&W's rear surrounds. Does anyone have a recommendation for placement? Here is the info:
            My ceilings are 7' 8" high. I will need to install them in a drop ceiling and can do this at either 1 ' , 3' or 5' behind the listening area....
            16 February 2005, 19:17 Wednesday
