[DIY]-Sound Obsorption Project
  • Hi-5
    • 12
    Since my stereo room has no carpet and the paint on the wall is pretty hard, i decided to make something cheap to absorpt sound.
    Material:
    1 piece of foam(about 2"x96"x24"), $7.79 from HxxxDepot.
    1 piece of soft cotton, $2.38 from WxxMart.
    1 piece of cloth, $7.59 from WxxMart
    all the above were cut into 4 equally.
    Step 1: cover the foam with a piece of soft cotton to increase the efficiency of sound absorption.
    Step 2: then cover with the other layer, cloth.
    Last edited by theSven; 06 May 2023, 21:15 Saturday. Reason: Update image location
    Diy sound obsorption:
    https://www.htguide.com/forum/showthread.php?t=28880
  • Hi-5
    • 12
    Step 3: put them on the wall opposite to where my speakers are.
      A rather unique approach to this task.
      Did you check the absorption coefficient of styrofoam before deciding to use it?
      • Hi-5
        • 12
        no. i chose it just because it is cheap and i did hold it near my left ear and i can feel there is a huge difference of sound volume between my ears.
        • joecarrow
          • 754
          It'd be interesting to see measurements of how effective it is- but it's hard to argue with how nice it looks for the price! It's probably quite nice for high frequencies, maybe less so for bass. Still, sitting so close to the back wall has a way of evening out the bass on its own.
          -Joe Carrow
            Absorption is a function of the energy in the air being turned into heat when the particles in the absorber vibrate. This is why fibrous materials like fiberglass batting, thick dacron/polyfill or similar materials are used.
            Styrofoam isn't fibrous nor does it contain flexible materials, so when you place it between your ear and a sound source it's blocking certain frequencies not absorbing them.
              Hate to be a party pooper, but that would be my guess too. You're only getting absorption from that thin piece of cotton and the fabric. I would guess it does nothing for the bass and likely even midrange. But, if there is little to no absorption in the room, it probably does make a noticeable difference. I always refer back to Bob Golds' site for anything acustical treatment wise:
              I wonder if an easy mod you could do that may help some would be to core out the foam in the middle or in some areas to let the sound through to the wall. As you can see from Bob's charts, insulation held 16" off the wall is significantly more effective then on wall placement. Even 4" off the wall is much better. The suggested mod won't get you there, but I wonder if it would help. You could even try stuffing the holes created with more of that cotton fabric.
              • jkrutke
                • 590
                I use DIY 2x4 panels. I got the 4" thick, 12" square tiles from foambymail.com. They are glued to a board which is glued inside a wood frame. They work really well. I once took a measurement of a speaker 6" away from a wall, (ewww, ugly) then slid this panel behind and took another measurement. Wow, much better. The reflection nulls and peaks were greatly minimized. Someday I may do fabric cover versions that look better. These are pretty much functional only. (read: ugly)
                When I do infinite baffle measurements, I lay one of these panels on the floor in front of the baffle.
                Last edited by theSven; 06 May 2023, 21:20 Saturday. Reason: Update image location
                Zaph|Audio
                  I think that stuff looks neat :B
                    I think Ryan has the right idea. Without tearing them apart, you could cut a big hole in the middle, from the back, removing all the foam there but leaving the cotton and fabric. Then cut a piece of soft foam like a mattress pad or whatever and slip it into the hole. Your styrofoam would then just act as the frame.
                    • looneybomber
                      Anyone use recycled cotton, aka. acoustic cotton?
                      by looneybomber
                      I've looked into using this as opposed to fiberglass (OC703 in particular) in my speaker build due to, well it's "greener" and appears to have nice acoustical properties.
                      Has anyone used it? Is it worth pursuing?
                      http://www.soundaway.com/Acoustic_Cotton_Panel...
                      29 May 2010, 10:37 Saturday
                      Fed-up with break-in delays? Tired of having cloth ears?
                      by bigburner
                      Have you ever wondered why Boeing can put a brand new 777 into the air and it lands at the right airport without any break-in of the electronics and wiring?
                      Have you ever wondered why an AIM-120D air-to-air missile can hit its target in all weathers 130 miles away without any break-in...
                      07 October 2009, 03:53 Wednesday
                    • Mazeroth
                      Sound absorption for windows?
                      by Mazeroth
                      The house we just purchased has windows facing the direction of a major highway (I-70), which is 7 houses down from us plus behind some trees. However, you can still hear the highway from inside the house if you're in one of the rooms that has windows that face the highway. It's not very loud but...
                      24 September 2007, 21:26 Monday
                    • kgveteran
                      Grill cloth
                      by kgveteran
                      While i think my speakers look great, it's time to find a grill to protect those aluminum drivers.
                      What would be the best choice for grill cloth that is acoustically transparent.
                      30 April 2006, 17:47 Sunday
                    • echo
                      metal grill to cloth
                      by echo
                      I'm considering buying a pair of 8NTs to put in a room that is mostly decorated with authentic art deco pieces, an era that predates metal grills! Anyone have any success in replacing the metal grills with acoustic cloth? Advice appreciated
                      21 July 2006, 22:09 Friday
