A New Adventure
    • 2142
    #226
    That looks great! I like that look and think the Ardent D’s with a baffle like that would look irresistible for me. Would this also make assembling easier?
    Thanks Sven .... mounting of the baffle would be similar, though there should be no hole drilling like you had in the Calliope's. Since this style baffle would also sit on the front of the ribs rather than in a pocket as it were, it should also be easier to line up. Your also looking at reducing diffraction issues as well .... not sure if that will be audible or not?
      Just to let folks know, early tests on an actually 3D sculpted baffle looks rather promising. This has been on my list of things to figure out and was prompted by on going work into center channel designs by Jon.
      Here are some pictures from the test run. This is essentially the same size baffle as what's on the Calliope MT.
      [ATTACH=CONFIG]30429[/ATTACH]
      [ATTACH=CONFIG]30430[/ATTACH]
      [ATTACH=CONFIG]30431[/ATTACH]
      [ATTACH=CONFIG]30432[/ATTACH]
      [ATTACH=CONFIG]30433[/ATTACH]
      Ah, yes, I see that Steve had raised the quality of his photo realistic renders by a quantum order, no doubt now using AR to superposition them within his own domicile...
      I similarly previewed an Apple XDR display in my personal computing environment using the same technique before making that commitment...
      Either that, or he actually has overcome some vexing programming and fixturing issue to actually fabricate the baffle displayed in this point...
      • Norm
        • Mar 2011
        • 62
        #228
        Oh so very fine.
        Steve is further advancing his already considerable skills in 3D modeling, G code creation, bits selection, and fixtures.
          • 2142
          #229
          Next Step .....
          Continuing with curved baffle tests. Parameters had to be adjusted some from the earlier mdf test ..... bamboo is a tad harder. :W
          By the way, the baffle has not been sanded yet .... not 320 grit smooth, but very nice none the less.
          Next to the mdf version.
            Master of None
            • Jan 2014
            • 1665
            #230
            They look really good and I like the way the grains look too. Would look really great with a few coats of the emtech clear!
            Painter in training
              There is much effort that goes into the ability to fabricate this relatively simple looking artifact....
                • 698
                #232
                Bamboo version looks superb. I would keep that with some transparent finish for sure and would like the look of it for sure.
                Steve,out of curiosity - how long did it take for one of such bamboo panels on the CNC. You get such a good finish out of machine, so it should mean very small step size and thus quite a long machining time ?
                  • 2142
                  #233
                  Thanks Ergo ..... I was hoping to be able to use this as an actual part, but timing did not work out and I needed to determine how well the process would work with bamboo. I'll probably sand it and throw some finish it to show customers.
                  Time wise for this is ~75 minutes actual machine run time. I have a few tweaks I need to do that might shave a few minutes off. Of course you have time involved in tool changes and all that as well. The biggest chunk of that time goes to creating the curve which is an even split between the roughing and finishing passes at ~30 minutes each. Step over on the finishing pass is 0.040".
                  Now this is for a 20" tall baffle ..... an Ardent size, which is on the way, will be considerably longer.
                  Steve
                    • 16205
                    #234
                    As Dr. Jeno Tihanji, the inventor of Siemens SIPMOS would say (and did say about many things), slow work takes time...
                    But, imagine trying to get the same result manually...
                    There are many reasons that YG Acoustics and Magico speakers are as pricey as they are; this is one of them.
                      • 2142
                      #235
                      Ardent D prep work
                      While getting some parts ready for an Ardent D build, it gave me the opportunity to fit up the recently cut curved test baffle. No spacers and rough edges, but you get the idea of where the design is going.
                        Master of None
                        • Jan 2014
                        • 1665
                        #236
                        The profile looks awesome! It all flows nicely and the bamboo is stunning.
                        Painter in training
                          • 1044
                          #237
                          That would be fun to play with some tints on the center racing stripe. Take it a bit darker than it is already to pop the contrast. Great work, as always.
                            • 2142
                            #238
                            Thanks guys. Yeah that bamboo gives a ton of options for staining or not. Would be an interesting trick to get just the center strip without bleed over into the surrounding area though.
                              • 16205
                              #239
                              as Willy the Shake said in one of his plays, "There's many a slip twixt the cup and the lip"
                              And wow, does November 2019 ever seem like a long time ago...
                              But I like the way this is evolving.
                                by ---k---
                              • dyazdani
                                1st DIY Adventure
                                by dyazdani
                                I've been keeping up with this forum for a while, trying to decide which project to start. I'm looking for a budget monitor in the $200 range (+/- 25% or so).
                                I thought for a relatively small investment that this might fit the bill.
                                Has anyone had experience with that...
                                03 November 2005, 23:03 Thursday
                              • Thooms
                                Cone materials and 2/3-way designs
                                by Thooms
                                Hi guys,
                                Since building my sub a couple of months back the bug has really bitten me (seems to be a common story lol) - I'm now looking to build a pair of speakers.
                                I'm still firmly in the throwing ideas around stage - there are currently a couple of issues I'm trying to...
                                08 June 2010, 09:56 Tuesday
                                What does Santa do if you have been bad - he fries your amp on xmas eve
                                by Briz vegas
                                I'm not a happy camper Santa.
                                Christmas eve and Massive Attack is playing at about 70-75 db in the other room. I notice I slight burny smell as I pass the stereo on the way down the hall, then buzz fart and a channel drops out.
                                A quick check under the hood reveals that...
                                25 December 2006, 04:01 Monday
                              • Valorum
                                Help with my 1st sub design adventure
                                by Valorum
                                Total newbie here trying to build his first sub. Did lots of reading here and on AVSForum, and got some questions answered there already and some suggestions for plans. I figured I'd come over here with my plans this far and see what you guys have to say about it before i start cutting.
                                30 March 2006, 18:04 Thursday
