  • DIYDUGG
    • Dec 2013
    • 35
    #316
    Thanks Knowledgebass - We are in a parallel situation then, okay, will go for the smaller one also.
    Many years of collecting large coils/caps etc.
    amp: I was fortunate to find a Luxman M-117 years ago, it's been wrapped in bubble wrap for year (seriously) until the DIY community said it was good amp. It's very warm sounding as advertised, it does tend to make everything sound good; for a while anyway.
    So chipping away at the xo while building boxes:
    The tweeter is not difficult. Also a lot of folks just separate the two, which is less confusing.
Name:	xo cdj  III.jpg
    Last edited by theSven; 14 March 2023, 20:06 Tuesday. Reason: Update image location
    • DIYDUGG
      • Dec 2013
      • 35
      #317
      Shifted gears a bit - laminated 1/2 mdf with 1/2 ply; some others said its not a bad idea and step up from either one.
      Cut up some mdf 1", thinking I'll use that for internal bracing now.
      Tweeters arrived in record time, even with the holiday rush.
        Clamps! I like it.
        • DIYDUGG
          • Dec 2013
          • 35
          #319
          These are neat - never saw them before: http://www.amazon.com/gp/product/B0000DD1QW/ref=pe_64730_102081870_em_1p_0_ti
          (Going to order a pair soon)
          Working on boxes now.............
          Last edited by theSven; 14 March 2023, 20:09 Tuesday. Reason: Update image location
          • DIYDUGG
            • Dec 2013
            • 35
            #320
            Going okay here - made the boxes 36" tall with slot ports (rounded them over with large bit)
            Went with a square version - other than that - it's the same box.
            ID is 13" x 32" x 7.5" which is 1.8Sf3 without any bracing.
            • DIYDUGG
              • Dec 2013
              • 35
              #321
              Trimmed back: ID is now 12.5" x 32" x 7.5" which is 1.74Ft3 (49liters)
              • DIYDUGG
                • Dec 2013
                • 35
                #322
                Question and apogees for being late to the party.
                Was there a modification to the tweeter?
                I.e. pulling the back off the tweeter and using the wood baffle as a chamber?
Name:	Tweeter question.jpg
                Last edited by theSven; 14 March 2023, 20:10 Tuesday. Reason: Update image location
                  No modification to the tweeter - I just like being sure it's isolated from woofer pressures - especially since these go pretty low.
                  • DIYDUGG
                    • Dec 2013
                    • 35
                    #324
                    Will do then.
                    new pic
                      Shoot. Just noticed this with the other pic, but that screws up the driver alignment on the z-axis so summing won't be quite the same on-axis...
                      • knowledgebass
                        • May 2013
                        • 159
                        #326
                        Also, with the 1.5" baffle the tweeter backing fits without modification. From memory, you'll need about 1/4" - 3/8" clearance for the tweeter backing on your 1" baffle.
                        • DIYDUGG
                          • Dec 2013
                          • 35
                          #327
                          Ut oh ...I guess I should have mentioned a square box sooner.
                          The driver spacing? I laid it out several times; think I got pretty close.
                          • DIYDUGG
                            • Dec 2013
                            • 35
                            #328
                            I did think if that is a problem - could make a tilting stand //
                            Thanks Knowedgebass, will cut up some disk spacers.
                            New pic
                            • DIYDUGG
                              • Dec 2013
                              • 35
                              #329
                              Is my Goose Cooked? :thud:
                              Starting to like these boxes:
                              Last edited by theSven; 14 March 2023, 20:11 Tuesday. Reason: Update image location
                                Ahh, progress!
                                I'm not sure it's going to be a huge problem with the time domain change, but it's worth experimenting with blocks under the speakers to tilt them, see if you can hear a difference. I think you'll mostly find a soundstage improvement.
                                I'm in that "waiting for parts to see how bad the first pass at a crossover is" stage, while also slowly doing finishing layers (Nebbiolo). I'll have to wait for it to warm up outside to be able to do the final finish coats though.
                                • DIYDUGG
                                  • Dec 2013
                                  • 35
                                  #331
                                  Whew...that's a relief. Not a speaker connoisseur, but looking for a high level of "good enough".
                                  No paint for a while I'm afraid, cold, cold and/or rain here on the east coast.
                                  This has a little umph by tapping on cone and no boom/box resonance.
                                  I'll check tuning after a while.........
                                  Thank much for posting the plans, xo and advice!
                                  • DIYDUGG
                                    • Dec 2013
                                    • 35
                                    #332
                                    Did some old school testing with HP generator & load resistor; came up with 26hz box tuning (with a pair of wires in the slot).
                                    Was getting very strong bass in the high 20's: speaker was in middle of room, so had to walk around to find the bass nodes.
                                      That's about right - crossovers in place? I targeted 28Hz IIRC.
                                      • DIYDUGG
                                        • Dec 2013
                                        • 35
                                        #334
                                        I'm better at carpentry work than electrical engineering lol I know it should take an hour or two, but will take me longer than that :-/
                                        Have large and small coils here, so the parallel version is looking good.
                                        I would never be able to clip lead one together no, no, no......
                                        Two points is not bad, 26 vs. 28hz, the gen is very, very old. I did throw in a small amount of poly stuffing, but don't think that is restricted the air flow.
                                        There's also a plastic grill over the internal port end, bent around like a "J". I pick that material up at the local Walmart store - needle-point mesh in craft section.
                                        E.G. http://www.amazon.com/Darice-Plastic-Canvas-33900-1-Sheets/dp/B001H83B9Q/ref=sr_1_2?ie=UTF8&qid=1388397313&sr=8-2&keywords=needlepoint+mesh
                                        Last edited by theSven; 14 March 2023, 20:13 Tuesday. Reason: Update image location
                                        • DIYDUGG
                                          • Dec 2013
                                          • 35
                                          #335
                                          Tried a second gen - same result 26ish; could always cut 1" off the port on the inside, wouldn't be the first time.
                                          I've seen some folks add liner paper for a smooth surface, that might have helped here.
                                            When the crossover is in place it'll change things a little due to the added series impedance on the woofers. You can try running the same gen with the inductor in front of the Anarchy.
                                            26Hz is fine, FWIW. It's an EBS alignment so will unload more quickly below tuning, but the drivers are pretty tough...
                                            • DIYDUGG
                                              • Dec 2013
                                              • 35
                                              #337
                                              EBS, yes did goggle that today, hence, going at this a little backwards - but I saw this project months ago and wanted to build it.
                                              Really liking the box size, not too big, easy to carry.
                                              So sorted though parts today, here's what I had on hand. The 3.7mh is 14gauge so may have to swap that out.
                                              The 8ohm resistor - does that need to be higher watts?
                                              The 12" cork board fits on side of box - but thinking three smaller boards might be better. side-back-side
                                              I plan on making one large order to PE, so filling my shopping cart to save on shipping.
                                                14ga is fine on the 3.7, just don't want higher impedance.
                                                8ohm, 10W is fine - it's in a zobel so is fine. Even on the tweeter 10W should be fine (I tend to use Mills which are 12ohm but...)
                                                • DIYDUGG
                                                  • Dec 2013
                                                  • 35
                                                  #339
                                                  I have some of the 2.5 & 4.0 mills resistors in the shopping cart.
                                                  Only have one 18gauge 3.6mh for tweeter - have several of those nice Jantzen's 20gauge I can unwind to 3.6mh.
                                                  So here is the 3 board xo - I think it will fit if it is attached to both sides and back.
                                                  Working with huge coils is not easy to fit & place.
                                                  A question about grounding (common), I can ground the three drivers anywhere, front end, back end, at the terminal cup?
                                                  Last edited by theSven; 14 March 2023, 20:14 Tuesday. Reason: Update image location
                                                    I always like to run +/- to the boards and mark the input polarity, and then also run each driver directly to the crossover board and again mark polarity. This is extra helpful when some drivers are reversed polarity. However, the (-) input and all ground can be tied just about any way you find useful.
                                                    • DIYDUGG
                                                      • Dec 2013
                                                      • 35
                                                      #341
                                                      Chris (yes?) Happy New Year!
                                                      Working on several things here, including packing up holiday decorations.
                                                      With that and more; still should have one box together later today.
                                                      Was there info on damping material? Been using PE's wool, (which needs a lot of teasing) is there a recommendation on ounces needed?
                                                        I lined the walls with Sonic Barrier (3 layer) - I may have stuffed as well, I don't recall. I probably didn't if it's not in the notes... then again... Also, managing reflections off the side walls at the woofers.
                                                        Wool (real wool) is awesome, but pricey. Fiberglass is also awesome but sucks to work with. Polyfill is good. Deadening wall resonances was my intent with the sonic barrier, and it does the job. Stuff to taste.
                                                        By the way, you may have something approaching an aperiodic vent with the needlepoint mesh completely in the port airflow, which will also tweak tuning. Just fiddle with it, stuffing, and whatnot to taste.
                                                        • DIYDUGG
                                                          • Dec 2013
                                                          • 35
                                                          #343
                                                          Thanks Chris.
                                                          I did use a full piece of mesh -ripped 7" turned and flipped it like a J.
                                                          So a little bit of floundering and had to make some of the wires longer, but xo is in and can be removed easily.
                                                          (the wires were wayyy too short on the 1st attempt :M)
                                                          Al that mdf is dampening the box, so probably won't need much damping wool.
                                                            You'd be surprised just how bad MDF is. That said, bad isn't bad in the end - it's all relative.
                                                            • DIYDUGG
                                                              • Dec 2013
                                                              • 35
                                                              #345
                                                              mdf is great for fast prototypes - I don't mind working with BB ply and can always re-do them.
                                                              Will slant the next set (o;
        I just hate working with the stuff - MDF dust is nasty. I've had to clean out the power switch on my router due to MDF dust!
        • DIYDUGG
        • Dec 2013
        • 35
        #347
        The white shelving is a little better
        Ready for lift off!
        • knowledgebass
        • May 2013
        • 159
        #348
        Jealous of the pace you set for this project! I'll look forward to some comments on listening impressions at some point.
        What screws did you end up using (source and or size)? I have some to use, but feel like I settled because I could not find any that would fit in the counterbore in the frames.
        • DIYDUGG
        • Dec 2013
        • 35
        #349
        #6 speaker screws, 1" long http://www.parts-express.com/6-x-1-d...0-pcs--081-440
        Always good to start off small.
        I really hate starting-stopping, bad mojo and/or bad memory - just easier get it done, less (or no) mistakes.
        The xo took longer than the boxes, but had to take apart other boards and sort, measure.
        Might have some old U shape metal stands with a slight angle that might just work here.
        • DIYDUGG
        • Dec 2013
        • 35
        #350
        Okay...off to a great start!! They sound very nice/natural/balanced.
        The bass is nice, smooth and extended.
        The imaging is good, not getting much on to the left/right outside the speakers, but tweeters are brand new, and just sat them on the floor for now, vertical.
        Didn't use much fill; some poly (junk) on the bottom, but that holds the better wool behind the woofers. Only had 10oz of the better wool, so 5oz each.
        btw, added pieces of cork near the woofers cutouts.
        btw II 70lbs each
        • DIYDUGG
        • Dec 2013
        • 35
        #351
        Knowledgebass - the inductor that is hard to find is the 3.6mh .7dcr
        This may be the closest:
        • knowledgebass
        • May 2013
        • 159
        #352
        I ordered mine from Solen. I may have gotten their last in stock parts at the time. I've had everything (but screws) to finish my build since September. I'm just slow!
        Edit: here's the one
        • DIYDUGG
        • Dec 2013
        • 35
        #353
        Thanks was going to ask.
        So they are in Canada - shipping might run the price back up.
        You'll like the SB tweeter - I have had others in that price range that don't sound anything like the SB29RDC.
        MS said it's a popular seller.
        Now I had a pair of SB29RDCN, but didn't think they would work here.
        I may have sourced from Madisound or Erse directly.
        • DIYDUGG
        • Dec 2013
        • 35
        #355
        So again very nice; had to lift them off the floor, which sacrificed some the bass but lifted the high end.
        They will make you look twice - some of the sounds are so life like they will draw you in.
        Excellent sound stage also.
        • knowledgebass
        • May 2013
        • 159
        #356
        Yeah, I'm in Canada so ordering from Solen is actually cheaper for me in the grand scheme of things. I had looked at some other kits from Madisound and Meniscus and shipping to Canada easily added another 30%+ (hundreds of dollars for a multi-driver kit) to the total cost.
        Your assessment is encouraging. Did you experiment with leaning them back? I believe that the angle baffle helped with time alignment, and also simulate (I think?) a taller cabinet. Anyway, thought I caught that on one of my read throughs but might have been on another angled baffle thread.
        What's your final height? How much space below your cabinet? I think I'm on target to be ~36" once I have ~1" feet in place (which I'm still not sure what I'll use, thinking about carving some totem inspired 'claw' feet and using screw adjustment feet).
        Update from me. I have facets cut on both boxes. Starting to sand. It's going to take a while. Wish I had a better sander. Using a hard maple [guitar] neck blank lined with sand paper to keep everything as level as I can, hand pane where I can to make it go faster, and a little detail 'mouse' style random orbit sander on the facets (and I'll give everything a go over with it once it's level). I have a 1/3 sheet sander but it's not random orbit and I find it scours some if not really careful - the advantage of random orbit sanders. So about half done the first one. And then one to go... Better figure out my finishes soon.
        Oh, and it's cold in my garage. Sweater, toque (winter cap), respirator and gloves helping to keep me warm. Also have a ceiling mounted heater that keeps a little area warmish that I try to keep under so maybe >0°C where I'm working, but almost certainly <0°C in the rest of the garage.
        I'm planning a light seal with shellac before I stain, then apply stain, and then do some filling on the baffle with epoxy (plywood is surprisingly soft). I've had some cracks form in the baffle, not along a glue joint, but through the wood plys. I mentioned earlier that I've seen some movement in the baffles, well this is probably one result. The first crack occurred while applying clamps, the other (between woofers on the other box) occurred some time after glue-up, but wasn't there immediately after. If you're doing translaminated baffles, plan on filling some cracks. I plan on feeding some thin epoxy into the gaps, let it harder, and then I'll mix a small batch that I'll try to tint (maybe?) and use some dust as filler to span the cracks after I've stained. That's the plan anyway. Still have some glue to remove before I can do that.
        Last edited by knowledgebass; 06 January 2014, 10:25 Monday. Reason: sentence fragment
        Yeah, I'm staying indoors today. Windchill here is low enough it would be warmer at the same number in celcius. Warmed up now so windchill is only -38F, standing temps -15F. And beautifully sunny. I want to go skiing or snowshoeing. Instead I get to work.
        My baffles (actually the tops) have split slightly, I think due to some water spilled on them. Soon as the Nebbiolo is completed I'll be pulling these apart to finish finally.
        • DIYDUGG
        • Dec 2013
        • 35
        #358
        The cold is on the way down here, they are counting it down like a clock here - Canada plz keep the cold air up there brrrrrrr
        I found more stands that fit nicely, and still vertical, but we are enjoying them. The'll knock you out in minutes if you are not careful; that's the acid test for me anyway and an example of a easy to listen to sound.
        That went by fast and didn't even need to tweak anything, but trust me, it's been a long hard road to find a pair that meets all this criteria.
        • knowledgebass
        • May 2013
        • 159
        #359
        In my experience, once it hits -20°F (~-30°C), anything colder is just a numerical bonus. -60°F (-50°C) feels the same to your skin and mucous membranes as -20°F (that's before windchill). Officially I would describe that feeling as, "not good." Normally I experience an involuntary cough when first exposed to those conditions. The frigid air is currently making it's way to me from the U.S. midwest, I probably won't be getting any work done once it parks over us, but I still have some cross over work to finish up.
        • knowledgebass
        • May 2013
        • 159
        #360
        Just a quick update. Progress has slowed due to the aforementioned cold. The really cold spell has broken but my garage is still below freezing. Hopefully we're done with that for the year. That said I've been sanding. Lot's of sanding and then running in to warm up my hands. I've just about got all the inconsistencies out of the baffle. Currently working through the grits to smooth it up. I have a couple areas to patch on the sides and some minor dents where I may try to steam the grain back out. We'll see how picky I remain the closer these get to being done!
        Click image for larger version  Name:	11936159734_ac63c31897.jpg Views:	104 Size:	35.9 KB ID:	929696
        Click image for larger version  Name:	11935991553_0e81ceb1df.jpg Views:	103 Size:	37.3 KB ID:	929697
        Get close to being ready to stain. I'll be finalizing colour choice this week and maybe start the staining process in another week.
        Oh and I finally found some screws. I picked up the #7-1" Kreg pan head coarse screw which is a perfect fit for the Anarchy counter-bore. Unfortunately they are silver so I'll need to paint them.
        Last edited by theSven; 20 April 2024, 13:57 Saturday. Reason: Remove URLs on images
