New project: Usher 8137a, T-B W3-1335SB, SEAS 27TAFN. WMTM, open baffle mids.
  • augerpro
    • 1871
    Good stuff Javier! I've been silently watching all these OB threads to learn what I can before tackling my own. You might find Rudolph's posts helpful because if I remember right he posted this horizontal polar effect and there was some discussion on how to fix it.
    ~Brandon 8O
    DriverVault
    Soma Sonus
    • fjhuerta
      • 1140
      Yes Bob.. you were right! The hump was there, in all its glory.
      Ryan, yes, I did move the speaker away from the walls. Unfortunately, my room is not perfectly symmetrical. You can notice in my RTA measurements that one speaker is basically completely flat from, say, 180 Hz on up. The other is a lot more ragged. The flat one is near a corner, the other one isn't. I moved the speakers around until I had the flattest response (on average) from both, and then I started fixing the crossover. That's why I also think the speaker, as designed, can only work correctly in the room I tuned it in. I may be dead wrong (I hope I am), but the experience I've had seems to be that an open baffle needs a combination of careful positioning and slight crossover tuning for the specific room it'll be used in.
      Brandon, I'll try to find Rudoplh's posts. What's the name of his design? I can't recall :s Thanks!
      Javier Huerta
      • augerpro
        • 1871
        I think he made some comments in Saurav's thread, and some similar posts at diyaudio, on a speaker he was working on. Sorry, that's all I remember.
        ~Brandon 8O
        DriverVault
        Soma Sonus
        • BOBinGA
          • 303
          Rudolf (he posts as "Rudolf") has web site that has a lot of good information for dipoles. It's in German, so start up Google translator:
          I used a parallel LRC in series with the mid to take out the extra energy. I thought this might be safer since it increases the circuit impedance at that point instead of reducing it like a series LRC across the speaker terminals would. Since your two mids in parallel are already 4 ohms, a series notch filter across them would reduce the impedance into the 2 ohm range, which would be challenge for a lot of amplifiers (although I do see you have a series filter across the mids who's purpose I don't quite understand). Your solution with the added resistance looks like it worked just as well since your peak is centered on your mid's bandwidth. In my case, my peak was a little off center and a little higher Q, so the notch filter worked best to exactly hit the peak.
          -Bob
          -Bob
          The PEDS 2.1 mini system
          • fjhuerta
            Usher 8137A vs. Dayton RS225 - which one would you choose?
            by fjhuerta
            Here's the scenario....
            I want to build a 3 way: WMTM. T = Seas 27TAFN. M = Tang Band W3-1335.
            The W3's aren't very sensitive. 86 dB/W. I could probably get away with using only one of them, but I haven't measured its distortion (yet) and I'd rather be safe than sorry....
            10 March 2009, 18:34 Tuesday
            Duelund meets Dunlavy (aka Duelund meets transient perfect)
            by Dennis H
            I was sitting around today, wishing I was at RMAF with the gang, and doing my usual multitasking thing -- watching the ballgame on TV and fiddling around on the computer. I was thinking about the old Dunlavy speakers where he uses lots of drivers with 1st order acoustic crossovers to get so-called 'transient...
            03 October 2009, 17:57 Saturday
          • madisonears
            Open baffle: single piece baffle or mids/highs separated?
            by madisonears
            I am building a 3 way open baffle system with mids/tweets OB but bass in a closed box. Should the baffle that holds the mids/tweets be separate from the baffle that holds the woofers? I see many designs that use a single piece for the entire baffle, even in hybrid systems like mine. I also see designs...
            11 December 2008, 00:12 Thursday
            Duelund XO: the Big Concept
            by Dennis H
            The big concept of the Duelund XO can be summarized as "all drivers in phase at all frequencies." To do that, he stacks LR2 filters when using 3 or more drivers. For example:
            Woofer: LR2-400 lowpass, LR2-2500 lowpass
            Midrange: LR2-400 highpass, LR2-2500 lowpass
            Tweeter:...
            03 April 2009, 16:05 Friday
          • fjhuerta
            ZDT3.5 (sort of): Duelund crossover design (I hope)
            by fjhuerta
            Hi all,
            Maybe some of you remember I built the ZDT3.5 some time ago, but I used the Vifa DQ25 tweeter instead of the small Neo dome. There was a reason for it - I had the Vifas, and I thought I could manage to fix the crossover as needed to use them.
            Indeed, the little...
            04 June 2009, 21:35 Thursday
