CNC Translam Bookshelf Build
  • cncfun
    • Mar 2021
    • 4
    I have a CNC machine and I am interested in building some nice speakers. I am looking for ideas and designs for some nice bookshelves. I've seen lots of cool designs and builds out there, but nothing with cad files. I am still learning and I am not great at CAD. I know just enough to edit existing files, create my toolpaths, etc.
    Is anyone aware of any available design with cad drawings? I want to try a translam build but I am not sure where to start. I was considering buying a kit from Mensiscus or diysg, but I would need a cabinet design. I am hoping to find something with some curves not just the traditional rectangular design.
    Thanks!
  • 1Michael
    • 295
    Generally people choose a speaker project based upon various criteria such as cost, size, sound, etc. Then they create a CAD file for that project. There is not a lot of people with CNC machines, so I suggest you decide on a project that fits first...
    Michael
    Chesapeake Va.
      • 2142
      Like Michael was saying, pick a design first and then look into if you can make the cabinet design your own. You don't get many folks that have a CNC to do their speaker projects and those of us that do have one have to learn the CAD as well as the CAM side of things for project creation. Out of curiosity, what type of machine and software do you have?
      • cncfun
        • Mar 2021
        • 4
        I have a Shapeoko 3 XXL. For software, I have fusion 360 and Vectric Aspire. As far as designs, I am looking for something I can eventually turn into a 5.1 system. My price range is fairly flexible but trying to keep it under $1000/pr. In the past, I built a 5.1 system using blues MTM towers and blues MT for surrounds. Whatever I build will eventually replace that. I want to start with bookshelves that will eventually become surrounds. The biggest challenge always seems to be finding a design that has a center channel. I was considering the ER18MTM, but I don't know what I would use for surrounds as I only see the tower configuration. I've always wanted to try statement II's, but I need a design that can be placed near a wall. I will be powering them with a Denon Receiver, so 6-8ohm would be best. I have my doubts with using this receiver to power 4-ohm speakers.
        The reason I was asking if anyone had any CAD files they were willing to share is so I could use them as a starting point. I'm fairly decent at editing existing files, I'm just not great at creating them from scratch.
          • 1044
          A center channel could be a small bookshelf -- if you have the height for it. In fact, a 15cm or 18cm woofer plus a tweeter make a better center channel than most WT/MW designs due to the lack of inherent cancellations in the layout. You can avoid these cancellations, but then the design needs to have some form of built-in phase coherency. For the design superstars, that's something like a Duelund topology. For mere mortals, you can work to keep the wing woofers within a quarter wavelength of each other, but this makes for a very low crossover point (200 - 300 Hz, at most) to the midrange. IF you strip off the woofers, and turn that midrange into a midwoofer, you find yourself landing back at a small-ish bookshelf.
            This is a commendable direction for development you have chosen- there is no way to avoid the down payment in learning the necessary tools and development techniques.
            If you haven't already read this thread, I suggest a thorough perusal...
            And this one may be of interest and use also...
            Last edited by theSven; 09 April 2023, 02:51 Sunday. Reason: Update image location and htguide url
            • gmed
              My new translam Project
              by gmed
              Thanks to Keith Kidder, He motivated me to start a translam project of my own. Using a CAD drawing software, I made few sketches and had a local shop cut a few templates using a CNC router. For me to have all the pieces cut using the CNC router, it is gonna cost me a fortune so I have decided to use...
              24 December 2006, 03:25 Sunday
            • gmed
              CNC Router services in LA?
              by gmed
              Anyone know someone in the LA area that would do CNC router services? Im trying to finish my translam project, and I just cant do it manually anymore. Im really needing help with this. I would greatly appreciate your help.
              G
              02 September 2007, 20:01 Sunday
            • gmed
              New Project Semi Translam
              by gmed
              This is a new project I started since my last completef project in 2007, my first translam project with Seas drivers.
              I'll post details about the drivers later. Mainly I'm displaying the cabinet building process.
              Sent from my iPhone using Tapatalk...
              16 May 2015, 07:35 Saturday
              2015 Burning Amp International Loudspeaker Crossover Design Contest
              Announcing the 2015 Burning Amp International Loudspeaker Crossover Design Contest!
              Your goal is to design a passive or active crossover for a 2-way mini-monitor using any freeware design software. The winning design will be awarded the drivers and cabinet for the project - design the best...
              16 September 2015, 18:24 Wednesday
            • dpg
              Tritrix translam build
              by dpg
              18 January 2010, 06:15 Monday
