New Project Semi Translam
  • gmed
    • 207
    This is a new project I started since my last completef project in 2007, my first translam project with Seas drivers.
    I'll post details about the drivers later. Mainly I'm displaying the cabinet building process.
  • gmed
    • 207
    • gmed
      • 207
      • gmed
        • 207
        The side panels are left over hard wood flooring which actually match the translam theme. It is hard wood bonded to plywood. They had to be planed gown as they were contoured. It was finished with sanding sealer 2 coats, sanded down, then smoothed down with a scraper. Then rub on polyurethane was applied.
          • 5202
          Very pretty. I really enjoy the translam look.
            • 1891
            Very nice gmed, I like the contrast with the flooring you used for the sides.
              Very well thought out and meticulously constructed. Looks to remain stable for a long time, I need to try one of these builds. Great job. :T
              What did you finish the cabs with? Did you epoxy lam layers or wood glue?
              • gmed
                • 207
                Wood glue
                • Carl V
                  • 269
                  Originally posted by gmed
                  Wood glue
                  Very nicely done.8)
                  1. template used to go from Round Woofer thru hole
                  to the flat sided rebate recess?
                  2. could you have used your Ply on the top the same
                  way as you did the face...to better align the ply pattern?
                  I see that you cut many vertical sections. Perhaps cutting
                  those longer & then making a second longitudinal cut, similar
                  to tapping & book matching veneer. I am just thinking out loud
                  and mentally planing a similar construction. I know when I
                  was aligning Zebrano veneer it was a pain in the ass., and as you
                  can see the Tineo veneer I used has differing grain patterns & staining.
                  which is inevitable when projects are spaced apart.
                  And I once again think you did a great job on this & you previous design.
                  looking forward to your followup thoughts about drivers & sound.
                  • gmed
                    • 207
                    Originally posted by Carl V
                    Very nicely done.8)
                    Thank you.
                    I used the router to cut the template. You can see the process in this thread that I just found, much easier than if I try to explain without images. I have couple of images attached but not complete.
                    as far as the top laters, I wasn't very particular. I realized afterwards. Im sure if I flipped it around, I would find the matching lines. I had bunch of precut pieces which I tried to use up. I didn't want to waste. this is why I just went with what I had. I wasn't planning it to be prefect. Otherwise I would have done a true translam like my previous mode. I particularly do not like veneers. thats just me. there is no point in doing translam if Im going to use a veneer. I like the pattern of BBply. the face usually has nice grains that I can leave natural. Except it doesn't take stain well and has to be conditioned a lot. I was planning to use black dye or stain, but since I used left over hard wood flooring which has ply, I went with the natural color.
                    This was something that I had to get out of my system, before I say goodbye to speaker building for a long time. Dont know where Im going to use them!!! I have another project incomplete, which I plan to paint Ferrari red.
ID:	859763Click image for larger version
ID:	859764Click image for larger version
                    • gmed
                      • 207
                      If you are using an 1/8" bit, you have to use a 3/8" bushing.
                      1/4, you have to use a 3/4 bushing. 3x the diameter of the bit. IMO, smaller the bit, the nicer the corners.
                      • gmed
                        • 207
ID:	859766Click image for larger version
ID:	859767Click image for larger version
                        • JeanM
                          • Apr 2015
                          • 27
                          Nicely done!
                          Thank you.
                          [ATTACH=CONFIG]24099[/ATTACH][ATTACH=CONFIG]24100[/ATTACH][ATTACH=CONFIG]24101[/ATTACH]
                            • 1671
                            Nice looking design, those Peerless HDS drivers don't get enough good rep around here they are very solid performers for the price. I guess this is what happens when you've got the RS series to compare to!
                            • gmed
                              • 207
                              You're right. I think they are worth so much more than what they cost these days. Very solid driver.
                              • JeanM
                                • Apr 2015
                                • 27
                                It's their pita frame
                                • fish fingers
                                  • Apr 2015
                                  • 189
                                  I have the ALU version; yes a pain in the rear to cut the rebate. Bloody good value tho
                                  • gmed
                                    • 207
ID:	863298Click image for larger version
ID:	863299Click image for larger version
ID:	863300Click image for larger version
                                    I have been busy with life and work, I haven't been here for a while. I finally completed these speakers about 6 months ago after a long break. here is the finished product.
                                    • gmed
                                      • 207
ID:	863302Click image for larger version
                                        • 1891
                                        As always very nice work gmed
                                        • Carl V
                                          • 269
                                          Agree, Nice work.
                                          Stands are Unique & industrial looking.
                                          • gmed
                                            • 207
                                            Thank you Steve.
                                            • gmed
                                              • 207
                                              Agree, Nice work.
                                              Thank you, Carl. The stands are very similar to my audio racks that I build few years back for my listening room.
                                              • gmed
                                                • 207
ID:	863304Click image for larger version
ID:	863305Click image for larger version
ID:	863306Click image for larger version
ID:	863307Click image for larger version
                                                • Carl V
                                                  • 269
                                                  Nice, very nice.
                                                  Sound wise how do the two speakers Compare?
                                                  • bbe22
                                                    • 7
                                                    congrats with the new build
                                                    pity about the discontinuity in grain pattern between the baffle and top
                                                    [IMG][/IMG]
