DIY Boat Speakers!
  • juliovideo
    • 63
    DIY Boat Speakers!
    Hi ,I'm a newbie......................and I pulled on an adventure to built the Sonus Faber Diy . 8O
    Ben jij de eigenaar van dit domein? Pas de DNS-instellingen aan. Weet je niet hoe dit moet? Vraag gerust om hulp.
    Here are some DIY photos of my creation at my apartment in Florida. :T
    materials.
    Oak wood
    MDF
    48" H x 12"-1/4 W (at front) x 21" D .
    Images not available
    I have not finished the structure, I think for next week to start putting the side panels.
    I thought to put these speakers .........................
    I did something about the crossover using this website below...
    Design a 3-Way All Pass Crossover for your next Speaker Project.
    And with my little knowledge that i have about this, It led to this...
    3200 Hertz / 400 Hertz
    8 Ohm Tweeter / 8 Ohm Mid / two of 8 Ohm Woofer
    Recommendations, comments and suggestions.
    Thanks Guys =]
    Last edited by theSven; 20 June 2023, 20:46 Tuesday. Reason: Remove broken image links
    "Liberty is the right of every man to be honest, to think and to speak without hypocrisy.."
    José Martí (1853 to 1895)
    • 1913
    It's obvious you're a newbie from the shotty cabinet work ..... NOT!!!
    Very nice work. :T However as I understand it crossover calculators will give a very rough crossover design. You really need to take some measurements of the individual drivers in the cabinet, using some speaker design software and a microphone.
    I have yet to do this, but I've seen how other members on this site design high quality speakers.
    Also the driver you chose for the tweeter is a compression driver, I think, and is to be used with a horn.
    John unk:
      Hi Jose,
      Cabinetry is impressive. Choice of drivers is bizarre and use of a generic crossover calculator is disappointing and problematic.
      Drivers are chosen after evaluating their individual performance characteristics. Crossovers are designed by measuring the impedance and frequency response characteristics of the drivers mounted in the baffle where the drivers will be used. Those measurements are then imported into a crossover modeling program.
      • juliovideo
        • 63
        Thank you Johnloudb :T
        • juliovideo
          • 63
          Originally posted by ThomasW
          Hi Jose,
          thanks ............. in fact these are the originals and too expensive.
          http://www.soton.ac.uk/~apm3/diyaudio/Amaticlones.html
          Tweeter: Scan-Speak D2905-9900 or 990000 Revelator
          Midrange: Scan-Speak 18W8545 carbon/paper (with custom dustcap)
          Woofers: Scan-Speak 21W8555-01 carbon/paper
            • 1913
            Your box looks like it might accommodate Jed's Dynamic 4T or Dynamic 2T. Jed's been an awesome contributor to this forum and builds excellent loudspeakers. I build his very good Lineup R44 design in the Mission Accomplished section of the forum. Very happy with it.
            He sells kits (driver and crossovers) ... see the "Clearwave Loudspeaker Design" advertisement above. And they're very reasonably priced for what you get. So, you might contact him, and see if it would work with your box.
            I'm not trying to discourage you from you own design, but when just starting out it's often best to start with a kit. Then when you learn more on how to design speakers/crossovers and have the software needed you can try a speaker from scratch.
            John unk:
              Yeah a lot of the software can cost half as much as the speakers you are building And then there is the equipment that goes with it. Good measurement microphone is 50 bucks and the to get it calibrated is another 50. Mic pre is going to be 100-200 bucks (may be able to find cheaper) so yes this all adds up to a good bit but it's what's required to make a good design.
              Those drivers in your first post don't look like they'd make anything to enjoyable Could be wrong but just my honest opinion.
                No one is suggesting buying the drivers used in the SF. But the question remains, why chose such pedestrian drivers as the Eminence when there are better drivers available?
                As was previously stated the Eminence compression driver can't be used without a horn.
                All in all it appears you better find guidance from someone knowledgeable regarding speaker design rather than waste money guessing about what drivers should be used.
                • juliovideo
                  • 63
                  I do not know, I think that the idea in use speakers Pro for Hi-Fi is rejected, and you can find things there ......sweet and good to a unless price.
                  • juliovideo
                    • 63
                    Thanks for the recommendation and see interesting things :T
                    I am a newbie in DIY audio but I have some DIY for ReefTank , also in my house my wife and daughters speak English very well but the my is bad, I have to use an online translator mostly.
                    translator. http://www.google.com/language_tools
                    My DIY Record Cleaning Machine ......in spanish
                    Parts .............
                    Turntable $ 5.00 dollar in ebay
                    wood $ 4.00 dollar
                    Motor DC $ 12.95 dollar
                    Switch Polarity Reverse DC $ 9.95 dollar
                    SwitchDC on-off $ 4.95 dollar
                    Switch AC on-off $ 4.95 dollar
                    total $ 41.80 dollar
                    My DIY ReefTank in English
                    Reef Central is dedicated to the marine reef aquarium hobby. Learn about reef aquarium setup and maintenance, and view coral and marine fish photos. Visit our online community and discuss and chat with hobbyists of all levels from beginner to advanced.
                    My DIY in Spanish
                    http://www.all-reefs.com/inicio/showthread.php?t=3956
                    http://www.all-reefs.com/inicio/showthread.php?t=4555
                    http://www.all-reefs.com/inicio/showthread.php?t=4372
                    http://www.all-reefs.com/inicio/showthread.php?t=4133
                    http://www.all-reefs.com/inicio/showthread.php?t=3962
                    http://www.all-reefs.com/inicio/showthread.php?t=2949
                    My reeftank winner september 2008
                    http://www.all-reefs.com/inicio/showthread.php?t=4896
                    I was given an Award for the best theme of the 2008 in All-Reefs
                    thread 620 Answers,visits 20,754
                    http://www.all-reefs.com/inicio/showthread.php?t=4928
                    :W
                      • 1913
                      Some Ideas
                      Jose, the coral reef you built is very beautiful. You definitely have some serious skills. Certainly, there's nothing stopping you from designing and building your own speaker. But, you'll need to learn some more about speaker measurements and crossover design to build a successful speaker. And you'll need to get some speaker design software. Speaker Workshop design software is free but I've never used it.
                      Pro drivers are usually designed for high sensitivity and high SPL, and not so much for really low distortion. Here are some drivers I'd suggest for a three way speaker and aren't too much more than the ones you chose. The Tweeter an Mids need to be more sensitive than the woofers so you can tailor the response. I'm not sure that the Aurum Cantus is sensitive enough at 90dB for a midrange. Though the RS52 should be and it's a very well liked driver. And the 8" woofers would be wired in parallel.
                      Vifa XT25TG30-04 1" Dual Concentric Dome Tweeter
                      Dayton RS52AN-8 2" Dome Midrange
                      Aurum Cantus AC-130MKII 5-1/4" Carbon Fiber/Kevlar Woofer
                      2 woofers:
                      Usher 8137A 8" Kevlar/Carbon Fiber Woofer
                      These are just my suggestions, for low distortion drivers that might work well together. There's a lot of possibilities.
                      John unk:
                      • lunchmoney
                        • Jul 2008
                        • 152
                        Beautiful cabinets!
                        Now PLEASE do yourself a favor and listen to what these guys are telling you...
                        You really need to use an existing configuration of drivers and crossover that have been designed by an experienced builder... find an existing design out there that uses the same internal volume and baffle width as your cabinets... hopefully there's something out there that will fit.
                        Cabinets are the easy part... getting the drivers and crossover right are infinitely trickier...success by blindly guessing at drivers and a crossover design is equivalent to winning the lottery.
                        Do it right. Don't waste those beautiful cabinets!
                        • juliovideo
                          • 63
                          Originally posted by lunchmoney
                          Beautiful cabinets!
                          Inteligent analogy and excellent advice............................thanks
                          • juliovideo
                            • 63
                            Thanks :T
                            • juliovideo
                              • 63
                              2 woofers:
                              Thanks Johnloudb .................
                              .............. Why put a tweeter 4 ohms ? , and how to solve the total impedance ?
                              Thanks for advance
                                Unless you want to go through learning to scratch build a system, (something not all that easy) I recommend you find a design from out Missions Accomplished section or Zaph Audio that fits your baffle and box. That way you'll have a proven design that works.
                                FWIW, The Dayton RS TMWW and Zaph's ZDT3.5 would probably work in your box...
                                The impedance of the drivers don't need to be the same...
                                For all intents and purposes the impedance of the woofer section is the 'nominal' impedance of the entire loudspeaker.
                                • juliovideo
                                  • 63
                                  Thanks interesting; I saw a thread here in this forum, where you demonstrate to all his knowledge, impressed me ! :T
                                  Can you do me a favor and set up 3 or 4 elections between tweeters, Midrange and woofer....I will be grateful .................The speakers no more than $ 120.00 dollar each .
                                  thanks.
                                    Are you talking total cost of each tower being 120? Or each driver can be up to 120?
                                    I'm not sure your dimensions but you should really look into see if these will fit the cabinets as they are fantastic I own a pair of these.
                                    http://clearwaveloudspeaker.googlepages.com/home I have the 4T's at the top and if your cabinet is close it might work.
                                    • juliovideo
                                      • 63
                                      Each driver can have up to between $ 0.00 and $ 120.00 dollar .
                                      The dimensions of my cabinet are 48" H x 12"-1/4 W (at front) x 21" D .
                                        Hmm, yeah then probably something based around the PE cabinets or something. They are like 10" wide. The 4T's are 8" wide so pretty big difference.
                                          Creating a design from scratch isn't a trivial undertaking. The investment in testing hardware and modeling software alone is several hundred dollars. Then one needs to learn how to use it, which is reasonably difficult and complicated.
                                          So my recommendation remains, use an existing proven design.
                                            • 1913
                                            Thanks for advance
                                            Well, I was looking for a driver with decent sensitivity and a nice flat response. It has a low Fs of 500Hz which will help in crossing over to the mid of your choice with low distortion. Vifa makes real nice drivers in general, and I think this on is well liked.
                                            A 4 ohm load shouldn't be a problem. Any most amplifiers you'd use with this speaker could drive it.
                                            You might also consider a ribbon tweeter, like the one used in Jim's Statements (see "Mission Accomplished" section) . But they have to be crossed over at a higher frequency.
                                            Thomas, is right about that. There is just a ton of stuff to learn.
                                            You should start off with box modeling software pick the woofers, and I wouldn't buy any expensive drivers before learning the software your going to use and testing a few cheap drivers on a test baffle. Just to make sure you've got the measurement and design details worked out.
                                            John unk:
                                            • Undefinition
                                              • 577
                                              here. This project will fit your cabinet and has lots of happy owners
                                              Or, this, which is a close relative, and again, has a lot of satisfied customers.
                                              and as to why everyone insists on building a proven design...
                                              • juliovideo
                                                • 63
                                                http://www.speakerbuilder.net/web_fi...a/lyramain.htm
                                                http://undefinition.googlepages.com/...-provendesigns
                                                Thanks, and now I understand your help from the beginning by all,and I appreciate this. :T
                                                I will consider all views and recommendations, I think in the end I stay with an existing proven design.................. before I jump into the abyss lol
                                                sincerely Julio V
                                                • juliovideo
                                                  • 63
                                                  I see some patterns that do not equal the total impedance in the woofers and it worries me
                                                  this, I maybe wrong but ...............
                                                  "Damping factor"
                                                  We could set the damping factor of an amplifier as its ability to control the movement of the coil of a loudspeaker. A high damping factor is desirable to obtain a dry sound at low frequencies, which would play "loose" and "loose."
                                                  An ideal amplifier has an infinitely high damping factor. In practice, here on planet earth at least, the amplifiers exhibit some output impedance, which leads to typical damping factors between 300 and 600 for an 8 ohm load.
                                                  The damping factor is calculated as the ratio of the impedance (designated with the letter Z) load and output impedance:
                                                  For example, an output impedance of 0.02 ohm to 8 ohm load
                                                  results in a buffer 400. As the factor is
                                                  directly proportional to the load impedance, when the lower
                                                  impedance, the worse will be the damping factor. In this example the
                                                  buffer would be 200 for 4 ohm, 2 ohm to 100, and following the
                                                  Similarly, 16 to 800 ohm.
                                                  So far so good. Normally we recommend a factor of
                                                  buffer above 50, with a minimum of 25. As we have commented
                                                  before, this is particularly important for low frequencies.
                                                  Things are complicated when we add a certain length of cable. The
                                                  impedance of the cable is directly proportional to its length. E
                                                  inversely proportional to its section, that is, the more coarse
                                                  lower its impedance.
                                                  English http://translate.google.com/translat...hl=en&ie=UTF-8
                                                  Spanish http://www.doctorproaudio.com/doctor/temas/cable.htm
                                                    I see some patterns that do not equal the total impedance and it worries me
                                                    The impedance of the tweeter is fundamentally irrevelevent to the load the amp 'sees'.
                                                    The impedance of the tweeter and the woofer don't need to be the same.
                                                    The impedance of the woofer determines the impedance of the system
                                                    • juliovideo
                                                      • 63
                                                      Thommas..........Then, when will connect two woofer in parallel of 8 ohms each,is equal to 4 ohms...........For the best performance between amplifier and speakers,in the woofer crossover should match the impedance total to 8 ohms ?
                                                      • GMorris
                                                        • 37
                                                        The low-distortion Dayton RS TMWW and ZDT3.5 designs that Thomas mentioned earlier can be found here:
                                                        RS TMWW
                                                        ZDT3.5
                                                        • Mike B
                                                          • Aug 2008
                                                          • 79
                                                          DIY boat speakers
                                                          Man, did that thread title ever get me confused -
                                                          Last edited by theSven; 20 June 2023, 20:47 Tuesday. Reason: Remove broken image link
                                                            • 1913
                                                            "Damping factor"
                                                            Most amps have a sufficiently high damping factor. I like amps with a fairly high damping factor 500+ into 8 ohms, to control the low frequencies. Some people don't care (i.e. tube amp lovers), but that's not a big design consideration for speakers, unless you like single ended tube designs.
                                                            You're looking for a specified frequency response (basically a flat response) for a given input voltage.
                                                            John unk:
                                                            • vinceb
                                                              • 55
                                                              12 1/4" wide? Sealed Statements , add a sub if you want more bass. Better yet add three small subs and move them around until you find bass nirvana.
                                                              • juliovideo
        • 63
        Thanks John
        • juliovideo
        • 63
        Wait till to finish it and you will see something different .................... a sailboat speaker !! :T
        :amen:
        Jose, you're getting a lot of good advice but it's probably hard to make sense of it all. Here's what you really need to know.
        - The crossover is more important than the driver selection.
        - It's really hard to design a good crossover without a lot of experience and some expensive hardware and software.
        - You should pick an existing design complete with drivers and crossover.
        - Baffle width affects the high frequency response so you should pick a design with width close to the boxes you are building. Otherwise you will need to modify the crossover.
        - Box volume affects the low frequency response so you should pick a design with similar box volume. That said, it's not too hard to adjust for a different box volume and we can help you with that.
        • 1913
        :amen:
        I look forward to seeing your completed sailboat speaker!! :T Whether you decide to go with an existing design or design your own, there are many very knowledgeable speaker designers on this forum who are happy to give advice and point you in the right direction.
        If designing your own, definitely get some speaker design software since it's a great learning tool and you can test different ideas without it costing you much. The software simulations won't solve all your problems and you need to take driver measurements and listen to finalize a crossover design.
        Definitely, take some measurements of some cheap drivers, to practice, before investing a lot in drivers. Like I should talk ... I've spent a boat load of money on drivers for a speaker design, which I hope to build soon. I'm hardly novice in audio electronics design but this will be my first speaker design. I think I know what I'm doing .... we will see. :B
        John unk:
        • juliovideo
        • 63
        Good luck with your project ! ........................... for that reason I love DIY ( Do it yourself ) it's exciting .
        • juliovideo
        • 63
        Thanks Dennis , interesting tips ................I do not understand what you are referring to this;Excuse my clumsy.
        "Baffle width affects the high frequency response so you should pick a design with width close to the boxes you are building. Otherwise you will need to modify the crossover."
        Greetings
        • 1913
        Greetings
        The baffle is the front of the speaker where all the drivers are mounted. So if you chose a speaker design with a different width than the speaker enclosures you have, it could change the frequency response of that design. It's called baffle step.
        John unk:
        • juliovideo
        • 63
        Thanks John .................
        • juliovideo
        • 63
        One question , .........Active Crossovers are an alternative to Hi-Fi ?; I have not seen that mentioned here much........Why ?
        Thanks for advance.
        Last edited by theSven; 20 June 2023, 20:49 Tuesday. Reason: Update image location
        • lunchmoney
        • Jul 2008
        • 152
        Active crossovers are an alternative to passive crossovers.
        This forum contains dozens and dozens of posts about the DCX2496, and numerous references to the DriveRack. There are also many references to other active crossovers such as those from Marchand and the Behringer CX2300 and 3400.
        • juliovideo
        • 63
        Thank you Thomas ! ,.............. I was watching the endless struggle to achieve the linearity of a response by a crossover. If set in a simple First Order and use the system with an equalizer..........
        .....This produces the same result.?
        • juliovideo
        • 63
        Thanks, I'm in the 9th inning 1 to 0, bases full,count 3 and 2........and 2 outs.
        • 1913
        Interesting link. I haven't compared active versus passive crossovers myself, but passive crossovers I'm sure, present more of a challenge. Though, passives can be done very well. You also need to consider what type of speaker you want. A three way speaker with a 3 way active crossover would require 3 amplifier channels per side. Do they make 3 channel amps anymore?
        :T Yep, they do here's one:
        Welcome to Emotiva Audio Corporation. Home Audio Systems, Speakers & Accessories and more. We use science to evoke the true emotion behind every note.
        The Behringer DCX2496 I think would do a three way crossover and allow you to correct the frequency response. But, I've never used one, so I'm not sure on that.
        John unk:
        • 123Toid
        How to Design a Crossover from Scratch
        by 123Toid
        For years, I wanted to design my own speakers, but didn't understand the intricacies that went into it. For all I knew, you bought a 2500 hz crossover from parts express, picked a woofer and tweeter that looked cool and went at it. It wasn't until i really got into DIY speaker building that I understood...
        04 July 2017, 13:15 Tuesday
        • TheWaveCarver
        How to Learn Passive Crossover Design?
        by TheWaveCarver
        What are some good sources online to learn about passive crossover design? Right when I think I'm beginning to figure it all out, I learn something new (Baffle step diffraction, driver impedance matching). I'm just beginning to understand the purpose of L-Pads and Zobels but have no idea how to calculate...
        21 April 2016, 10:01 Thursday
        • parodielin
        New Dayton Drivers - 8 ohm non-shielded
        by parodielin
        Good news! OK, semi-good news...
        PE has the RS 8 ohm non-shielded version AND all shielded version are on sale. I picked up four RS225s.
        Are non-shielded version better than the shielded?
        Are these drop replacements?
        05 October 2010, 20:19 Tuesday
        • Mark HT
        My first attempt at passive crossover design. Comments welcomed (VituixCAD)
        by Mark HT
        This is my very first attempt at a passive crossover. Drivers are Bliesma T25B and M74B with data taken from Bliesma datasheets.
        I have these drivers on order and intend to cross them actively to a pair of woofers.
        Any comments? I have a few months until the drivers arrive and...
        06 December 2021, 19:00 Monday
        • Stitches
        DIY Two Way Towers (HELP!)
        by Stitches
        Hi guys!
        I am in the design stage for a pair of two way tower speakers. This will be my first DIY so I would really appreciate some help along the way!
        I have chosen these two drivers:
        SB Acoustics SB26STCN-C000-4 (Tweeter)
        Silver Flute W20RC38-04 (Woofer)...
        20 June 2015, 15:55 Saturday
