Dolby Atmos ??
  • aarsoe
    • 795
    Dolby Atmos ??
    The obvious question after the announcement of Dolby Atmos in the consumer space is if there are any plans to implement a software update to the SSP-800 to allow for Atmos processing. According to some of the other manufacturers press releases there will be units that will allow for this only by firmware update. Rumor is that license is included in the Dolby license so no added payment - but I could be wrong..
    Anybody heard anything?
  • Kal Rubinson
    • 2109
    I strongly doubt that ANY current AVRs or processors will be updatable because ATMOS demands substantial DSP resources and commercial products rarely have any more than suits current needs.
    Kal Rubinson
    "Music in the Round"
    • TomScrut
      • Nov 2013
      • 532
      Yeah the only stuff with firmware updates to enable it are new models which have been designed with it in mind but not there on the initial release, as far as I am aware. The SSP has a lot of DSP power but I suspect it won't be enough.
      Music: Intel NUC -> Antelope Zodiac Platinum -> Classe CA-2300 -> B&W 802 Diamonds & 2x SVS SB13U
      • aarsoe
        • 795
        Kal - Seems like the units with programmable DSP's and enough MIPS can do it. Thinking of Trinnov.
        Pioneer will also unlock it via firmware but unsure if are not just using pre-configured DSP's that cannot freely be programmed so the firmware only acts like a switch.
        • TomScrut
          • Nov 2013
          • 532
          Does it have enough MIPS? I don't know how much they require for Atmos but the SSP is getting on a bit in the AV world isn't it? It doesn't even have an automatic eq system, which atmos requires something similar to calibrate against the room AFAIK. The Sigma SSP might have it when it comes out
          • Kal Rubinson
            • 2109
            Trinnov on what? Only the >20K processors like the Theta have enough MIPS as shipped.
            Kal Rubinson
            • aarsoe
              • 795
              Price and processor performance in the audio world is not related. Sorry.
              • TomScrut
                • Nov 2013
                • 532
                It kind of is, why put more processing power on there than is needed? I did hear the SSP had a lot of processing power on board but it's maybe still nowhere near what atmos requires.
                I aren't sure what you want us to say, yes it has enough power and there will be an update? If you are so certain it has enough power why don't you back it up with evidence? As I have already said I aren't sure but can't see it having enough, but how do you know it has enough and that Kal is not speaking the truth?
                • aarsoe
                  • 795
                  Most companies buy a turn-key solution with everything programmed and only the interaction is different. A DSP is anyway only as good as it's programming.
                  Tom: I was not looking for you to say anything, but rather someone with connections to Classe to make a comment..
                  If you want to compare DSP's and mips performance then go back to this old thread:
                  "The Gathering Place". General discussion, and I mean general! Just watch the political and religious type posts, those will be watched closely. New members: Tell us about yourself in the "Get Acquainted with HTG thread" or start your own thread and say hello to all of us!
                  • TomScrut
                    • Nov 2013
                    • 532
                    http://www.htguide.com/forum/showthr...re-differences
                    Why don't you email them then rather than ask on a forum?
                    • TomScrut
                      • Nov 2013
                      • 532
                      Also a thread from 2009 is hardly relevant to the developments since then.
                      • mjb
                        • 1485
                        I can't help with whether or not its enough grunt for Atmos, but an SSP-800 has "two DSPs, each rated at 2800 MIPS (Million Instructions per Second)". Which is about 10% of current PC's per core!
                        - Mike
                        Main System:
                        B&W 802D, HTM2D, SCMS
                        • aarsoe
                          • 795
                          MJB - which CPU are you referring to? Just for fun
                          • mjb
                            • 1485
                            I am NOT an SME (subject master expert), and happy to be proven wrong because a) processor performance is a complicated thing and b) probably not even comparable with DSP performance... However, an Intel Core i7 3770k (quad core) achieves 106,924 Dhrystone MIPS at 3.9 GHz = 26,731 MIPs per core. Source: http://en.wikipedia.org/wiki/Instructions_per_second
                            - Mike
                            Main System:
                            • aarsoe
                              • 795
                              Instead of creating a long thread just remember that there are more than one "kind" of MIPS and what is being compared is apples and oranges. In fact almost no-one in the industry still uses MIPS as a reference. Also the chart is not very precise.
                              And before someone start screaming all I can say is that after almost a decade at Intel working with this I should know..
                              Guess the conclusion is that we will not get Atmos. Only question for me know is if the new long overdue processor from Classe (forgive me for not remembering the name/number) will have Atmos.
                              Can't wait to see the really extreme people trying to install B&W 802's in their ceilings in order for all speakers to sound the same... :-)
                                • 4158
                                :rf +1
                                • crytklmass
                                  • 145
                                  Time to upgrade your receiver. Im sure Classe will offer an SSP900 with Atmos.. lol As you know, every few years they release new technology and its time to upgrade. That's why AVR's and receiver's lose so much value after a coupe years. My MX-136 was $12,000 new. 3 years later it's value was $3,000 on A-Gon. I stopped spending my money on Hi-End receivers for that reason. Now my limit is $3,000. It doen't hurt so much when its time to upgrade.
                                  BOB
                                  • punks123
                                    Please help me with DSP firmware update for rotel 1560
                                    by punks123
                                    Can someone please help me with updating the DSP firmware for the rotel 1560? I was able to flash the main board and video to the lastest firmware on the bwgroupsupport. I checked the version on the audio firmware it show 00.00000000. I got this receiver from some one and was not aware if the sound...
                                    27 September 2013, 08:08 Friday
                                  • Aussie Geoff
                                    RSP 1098 Wish List V2.0
                                    by Aussie Geoff
                                    John Wick on Blu Ray with Dolby Atmos
                                    If you haven't heard about this one yet in the HT community, stop and pay attention.
                                    The film itself is a check-your-brain-at-the-door, guys' night out, shoot 'em up action film. Keanu Reeves actually does a very decent job as the title character super killer, maybe the most convincing...
                                    11 March 2015, 09:32 Wednesday
                                    Firmware revision documention
                                    by Andrew Pratt
                                    Guess what Rotel sent me this morning!
                                    Note that the HD units indicates the newer models running the modified chipsets. If your machine is using these different chipsets please do not flash your firmware unless you've obtained the correct file directly from Rotel.
                                    RSP 1066 Software...
                                    30 October 2002, 13:14 Wednesday
                                    Firmware update changes.
                                    by Andrew Pratt
                                    RSP 1098 Software Updates Release Notes
                                    V1.0.0 to V1.1.0 - Allowed a press of the function knob on front panel to power unit on from Standby. - Software relating to the MP3 decoding was changed. - Test Tone level reduced from -23dbfs to -30dbfs per Dolby spec. - Fixed lack of video output...
                                    22 February 2005, 15:07 Tuesday
