Crossover Components Feedback Sought
  • Landspeeder
    • 273
    Good day Crew,
    Any substitutions you fine folks feel should be made for my sphere speakers before I press purchase?
    Thanks!
    Capacitors
    C1 – 5.6 uF $6.15 Jantzen Audio Z-Standard Metalized Poly 5.6 uF
    C2 – 8.2 uF $8.42 Jantzen Audio Z-Standard Metalized Poly 8.2 uF
    C3 – 0.11 uF $8.26 AudioCap Film & Foil 0.1 uF
    Run in parallel with a $6.28 AudioCap Film & Foil 0.01 uF
    C4 – 4.7 uF $4.83 Jantzen Audio CrossCap Metal Film 4.7 uF
    Resistors
    R1 – 4.7 Ohms $1.38 Dayton Audio DNR 4.7 Ohm 10W DNR
    R2 – 8.0 Ohms $4.25 Mills Non-Inductive 8 Ohm 12W
    Inductors
    L1 – 0.25 mH $6.54 Jantzen Audio 18 AWG Air Core
    L2 – 1.5 mH$1 $12.50 Jantzen Audio 18 AWG Air Core
    Last edited by theSven; 03 May 2023, 18:49 Wednesday. Reason: Update image location
    My Builds: https://www.htguide.com/forum/showth...731#post593731
  • Wayne1
    • Dec 2016
    • 12
    Take a look at https://www.audiohobby.eu/en/
    The site may take some time to go through, but the prices are much better than Parts Express.
    Not quite as quick to ship, but the cost difference may mean you might be able to go to the Audio Supreme caps.
    • Landspeeder
      • 273
      WOW! Thanks for that site @Wayne1. Many of the components are, literally, half the price! SO… I upgraded the components Based on http://www.humblehomemadehifi.com/Cap.html
      Audiohobby.eu/en
      Capacitors
      C1 – 5.6 uF $20.35 Jantzen Superior Z-Cap
      C2 – 8.2 uF $26.76 Jantzen Superior Z-Cap
      C3 – 0.11 * 0.1 uF $5.76 Mundorf MCap EVO Oil axial
      Run in parallel with a 0.01 uf $5.57 Mundorf MCap EVO Oil axial
      C4 – 4.7 uF $16.94 Jantzen Superior Z-Cap
      Inductors
      L1 – 0.25 mH $2.67 Jantzen Audio 18 AWG Air Core
      L2 – 1.5 mH $6.13 Jantzen Audio 18 AWG Air Core
      Resistors
      R1 – 4.7 Ohms $11.44 MOX Mundorf Supreme 20W
        In my experience, parts from audiohobby arrive faster than those from Parts Express - an added benefit.
        • Landspeeder
          • 273
          Awesome!
          An item is on backorder... So fingers crossed
          • wolf_teeth
            • Feb 2011
            • 230
            Whereabouts in NW Indiana? I'm in NE Indiana.
            Wolf
            • Landspeeder
              • 273
              (see pm)
              • ligonk
                Issues with C-Coil inductors from Jantzen
                by ligonk
                I am using some C-Coil inductors from Jantzen for my Modula TMM build. Them, along with every other inductor and part get measured prior to using them in my crossover. Every other inductor i have measured in the past ends up being ever so slightly above the stated inductance, which is great because...
                16 August 2014, 23:20 Saturday
              • TNRRClassic
                Solen 10 and 12 awg inductors
                by TNRRClassic
                Does anyone have experience with the 10 awg or 12 awg air core inductors from Solen? I am wondering if they are a good substitute for foil inductors, as the resistance is about the same. Also, they are a little cheaper. I've personally iused an air core inductor larger than 14 awg. I've always used...
                13 July 2016, 06:01 Wednesday
              • bd1000
                Joining DIY crew - Natalie P build
                by bd1000
                I have been reading a lot lately and wanting to build a set of front speakers for the beginning of my HT setup. Well I was thinking about starting off with the Modula MTs for practice and then I could use those as surrounds later when I upgrade the fronts. But, I decided might as well go with the NatPs...
                12 December 2009, 00:04 Saturday
              • jebcamaro
                Noob here starting a DIY project with a ?
                by jebcamaro
                I am new here and new to home theater all together or for that matter DIY speakers. I have built several car audio systems in my day, but never crossed over to the HT realm. I currently have been using an ancient Onkyo Dolby Prologic 1st Gen surround sound amp with some Cerwin Vega 12`s and Infinity...
                21 July 2007, 13:34 Saturday
              • renton
                NatalieP - suggestion for out of stock XO components?
                by renton
                hey again,
                Trying to order all of the parts for my XO's. I am using this BOM :https://www.htguide.com/forum/attach...achmentid=6899
                Some of the items are out of stock at PE or Madisound. Can anyone give input on whether the replacements I have found are a good option,...
                23 May 2007, 20:25 Wednesday
