large monitor/bookshelf...
  • mph33
    • Jul 2012
    • 44
    My room is 11(w) 19(l) 8(h)... floors are hardwood and there is an opening to the dinning room in the rear. looking for a DIY kit for 70% music, 29% ht, and 1% rediculous sound effects LOL. I want these speakers to be able to take some abuse but... sound good doing it. I was looking pi speakers but, the owner can't seem to keep AE and JBL drivers in stock. I'm thinking a dual mid and tweet. something elegant looking but has some balls. don't wanna spend over $1200 for the kit. wish I could build the cabinets but I live in a big city... no shop. ill probably ask a cabinet shop to do the box build. everything is fresh. going solid state for amps. would like this kit to have crossovers. any suggestions would be awesome. fir music... I listen to mostly metal. a sub will be in the design as well. still would like good midbass punch from the monitors.
    Statement monitors?
    Those would be good, as others, but you'll good advice from members here. I'm suggesting you consider the Parts Express cabinets, which will cost you less than custom-made cabinets with a similar finish. Here's an example: http://www.parts-express.com/pe/show...number=302-750
    • mph33
      • Jul 2012
      • 44
      I can build the cabs... all I would need is someone to build the baffles. I.don't have routers. Is the statement monitor worth the build? I don't want a bookshelf that lacks bass
      • mph33
        • Jul 2012
        • 44
        I see some if the drivers used in the statements are no long available. That's a real bummer. Are the mini statements too big for my room? I don't want to compromise bass in 2ch mode. For ht I will use a sub
        • BeerParty
          • 475
          The Statements are excellent, but they need proper positioning. If you have the room to place the speakers so they are out into the room (rear baffle ~18 inches from the wall, so front of speaker ~30 inches into the room) they are highly recommended. If you only have room so that the front of the speaker is ~24 inches into the room (12 inches of clear space behind the rear baffle) the Statement Monitors have an alternate crossover that will work that way. If you need them any closer to the wall I would NOT suggest the Statements.
          Just so you know, alternate drivers for the full sized Statements are available.
          I do not know if anyone sells built crossovers for any of the Statement series. If someone knows where to find them, I am sure they will chime in.
          If you are looking for a kit with pre-built crossovers, you may want to check out the Madisound Speaker Kits.
          My Statement Monitors Build
          My AviaTrix Build
          • Silver1omo
            • Sep 2010
            • 430
            If you are referring to the shielded RS woofers, you should be able to use the unshielded ones with no problems.
            You can also buy a full kit from meniscus
            We are doing some work on our site. Please come back later. We'll be up and running in no time.
            I built a pair of statement monitors and they sound great, if you go with the statements series make sure you have the space they need behind them (18", or 12" the monitor with near wall XO).
            If you plan to add a sub, then you probably don't need that much bass extension and if you plan to go loud, take a look at the stentorians:
            Ivan.
            My Statement monitors
            • mph33
              • Jul 2012
              • 44
              So... I guess some of your are not to fond of the mini statements? Its either the monitors or the full size statements? I think the stenorians and the statements are too big for my living room. Trust me... I love big and loud.
              • NPE
                • Sep 2008
                • 57
                Built statements monitor, love them... BUT, getting the double front baffle cuts, the rear for the port, it'll probably cost you.. Cabinets aren't that easy to make either.
                Madisound has the baffles for some of the speakers, ex: http://www.madisoundspeakerstore.com..._str=ZRT+2-Way These look to be right in your $$$, and 20$ for baffles is incredibly cheap... Locally, It would probably cost me 20x that to cut me the Monitor baffles... That with the crossovers already made, should be a good starter kit
                • mph33
                  • Jul 2012
                  • 44
                  That's a very nice speaker component but I'm a little concerned with frying those drivers. They seem to designed more for easy listening stuff... not metal lol
                  • Silver1omo
                    • Sep 2010
                    • 430
                    I went with monitors because I don't have the 18" needed for the minis or full size.
                    If you want to go very loud then probably a PA solution:
                    Perhaps a econowave http://audiokarma.org/forums/showthread.php?t=150939
                    Or a BFM design http://www.billfitzmaurice.com/ a pair of TLAH and a THT should be loud.
                    Ivan.
                    • Silver1omo
                      • Sep 2010
                      • 430
                      What are you going to use to power them?
                      Ivan.
                      • mph33
                        • Jul 2012
                        • 44
                        An onkyo 5.1reciever(not sure which model yet) fir processing, and power the mains with an emotiva
                        • fbov
                          • Jun 2008
                          • 479
                          My room is 11(w) 19(l) 8(h)... floors are hardwood and there is an opening to the dinning room in the rear. ... I was looking pi speakers but, ...I'm thinking a dual mid and tweet. ...don't wanna spend over $1200 for the kit. ...would like this kit to have crossovers. ...a sub will be in the design as well....
                          A word on kits...
                          There are true kits (drive a few screws and listen):
                          This page has been removed, but Madisound has thousands of loudspeaker parts. Contact us today at info@madisound.com.
                          And there are parts-only, no soldering kits (you build the box):
                          ZA5.2 TM 2-Way from the Zaph|Audio ZA5 FamilyPrice shown is for a PAIR This is the 2-Way offering from the ZA5 family of kits. You can build this kit in either a ported or sealed box design. This design also has a crossover variation for In-Wall use which you can select from the drop down menu. The Zaph Audio ZA5 Family is a collection of speaker kits using the ZA14W08 woofer and the Vifa DQ25SC16-04 tweeter. These drivers and subsequent kits represent fantastic performance at a very attractive price. Detailed information on the Zaph ZA14W08 woofer and ZA5 kits can be found on the Zaph Audio website. There are several designs to choose from to meet your speaker building goals. Consider the ZA5 kits for anything from small monitors to floor standing towers, from stand mounted MTM stereo to a complete surround sound masterpiece. The variety of kits in the ZA5 family affords you the choices to specifically fit your project needs. Madisound is offering these kits as a combination of the ZA14W08 woofers and DQ25SC16-04 tweeters along with the associated crossovers. These high quality crossovers come professionally assembled on a printed circuit board for easy installation and hookup. All crossover parts hold to the exact values of the crossover design.  You may also choose to purchase your choice of optional accessories packages. These accessories packages are available at a discounted price, and will provide you with the miscellaneous speaker building parts that you need to complete your kit. Detailed parts list can be found below. In response to customer feedback, binding posts/input cups are not included in the accessories package. However, you may also select your choice of binding posts or input cups at a discounted price. Both the accessories package and binding post/input cup options can be purchased along with this kit by selecting from the drop down menus at the top of this page. Included: (2) ZA14W08 Aluminum Cone Midbass Woofers (2) DQ25SC16-04 Titanium Dome Tweeters (2) Professionally Assembled Crossovers - for schematic click here.  Ported Version Information: .36 cubic feet (10 liters) 8” wide, 14” tall, and 9.5” deep 1.5” diameter, 4” long port tube Frequency response 52Hz – 20Khz For cabinet drawing click here. Ported Version Optional Accessories Package: (select from drop down menu above to purchase) (8ft) Supra Classic 1.6 (15AWG) internal speaker wire (2) 1.5" x 4" PT-F415 port tubes (1) 36” x 36” x 1/4” Wool Felt for lining the internal walls (2) QC110R for + tweeter tabs (4) QC110B Quick Connects for – tweeter & - woofer tabs (10) QC205R Quick Connects for + woofer, + crossover & + binding post tabs (8) QC205B Quick Connects for – crossover & - binding post tabs (16) #8x1 Black Ox & Wax Socket Head screws for mounting drivers to baffle Sealed Version Information: .25 cubic feet (7 liters) 8” wide, 12” tall, and 9” deep Filled with Acousta-Stuf Mate with subwoofer or use as rear surrounds For cabinet drawing click here. Sealed Version Optional Accessories Package: (select from drop down menu above to purchase) (6ft) Supra Classic 1.6 (15AWG) internal speaker wire (0.25lb) Acousta-Stuf to fluff and fill the cabinet (2) QC110R for + tweeter tabs (4) QC110B Quick Connects for – tweeter & - woofer tabs (10) QC205R Quick Connects for + woofer, + crossover & + binding post tabs (8) QC205B Quick Connects for – crossover & - binding post tabs (16) #8x1 Black Ox & Wax Socket Head screws for mounting drivers to baffle Crossover Options (select from drop down menu above): Original Crossover Design In-Wall Version of Crossover Reduced BSC Version of Crossover (for near wall, on-wall, in-shelf applications) Upgrade Series Tweeter Capacitor Crossovers Only - No Drivers Kit pricing shown includes a discount on all drivers and accessories package. Need a single speaker or an odd number? No problem, singles are simply 1/2 the price of the stereo pair. Please leave us a note with your request in the "comments" section of your order. We will ship your order with the total number of speakers that you request, and charge accordingly.
                          And there are KD kits (glue and paint, then drive screws and listen)
                          And there are components only kits (you solder XO and build box)
                          And finally, there are "DIY kits" where you take someone else's design and XO circuit, work up your own bill of material and build from there. Those are listed here:
                          My questions to you are: How many speakers for $1200? and What kind of sound do you like?
                          I ask because you hint at two design approaches - MTM and compression driver (CD) - which are both well suited to your application, but which will sound very different from one another in your room. Both design approaches modify the sound field to limit energy based on direction. Both have reduced floor/ceiling output, and the CD limits lateral output as well, but that's where the similarity ends. The CD-based speaker will be louder, but in my opinion, the MTM will sound lots better. It all depends what your ears like. (Statements are WMTMW, and so behave like MTMs.)
                          Note that if you are building only two, I'd suggest neither approach. I find the stereo imaging to be poor with MTMs due to the same reduced room interaction that was a prime feature above. I've not tested CD-based designs in this respect, but I suspect the same lack of envelopment from them as from MTMs, compared with a simple, small TM sitting well away from all the walls, that simply disappears into an immense reverberant sound field. But that's stereo; in multichannel, MTMs are excellent (and I expect CD would be too, if you like their sound).
                          HAve fun,
                          Frank
                          • mph33
                            • Jul 2012
                            • 44
                            [QUOTE=fbov]A word on kits...
                            Note that if you are building only two, I'd suggest neither approach. I find the stereo imaging to be poor with MTMs due to the same reduced room interaction that was a prime feature above. I've not tested CD-based designs in this respect, but I suspect the same lack of envelopment from them as from MTMs, compared with a simple, small TM sitting well away from all the walls, that simply disappears into an immense reverberant sound field. But that's stereo; in multichannel, MTMs are excellent (and I expect CD would be too, if you like their sound). [\quote]
                            I figured my room was a Tad on the small side to run a high efficient system with pa drivers... CD's and what not. I owned some klipsch rf-83's and wasn't that impressed. Way too bright and they lacked midbass. I would love a two-way... 8" mid with a large format tweet that can play low. I like a lively sound with good kick-drum... an airy tweeter but not too revealing. We all know some metal music isn't recorded the best. Here's a mid I would live to use in a two-way... large bookshelf design.
                            Di WDBOS, WD bukan sekadar tujuan, itu adalah tradisi yang kami banggakan. Setiap permainan dirancang untuk memberikan kamu peluang terbaik, di mana para pemain seperti kamu terus mencetak WD demi WD. Bergabunglah dengan WDBOS, di mana WD adalah bagian dari budaya, dan rasakan sendiri apa yang belum pernah kamu dapatkan di tempat lain.
                            • mph33
                              • Jul 2012
                              • 44
                              • mph33
                                • Jul 2012
                                • 44
                                The $1200 is for the mains... possibly squeeze in a center channel
                                  http://www.europe-audio.com/Product.asp?Product_ID=6948
                                  Some thoughts.
                                  1st of all, the Statements (all versions) will be extremely revealing. If you listen to poorly recorded metal at high volumes, you won't be happy. Metal drivers and ribbon tweeters are NOT forgiving! 8O
                                  2nd, the Monitors shouldn't be played over 104 db which I suspect will be a bit low in volume for you based on your previous posts.
                                  The Statements series speakers sound great on well recorded music when played within the limits they were designed for.
                                  • mph33
                                    • Jul 2012
                                    • 44
                                    Sounds to me the statements are for hifi snobs. I've always heard metal drivers were more suitable for faster aggressive music.... kick-drum and snare blast beats. I guess I was wrong
                                      So tactful. So full of information and knowledge to share!
                                      Metal drivers are absolutely suitable for such things. They can render them amazingly well.
                                      That same amazing rendering ability means they let out all the warts.
                                      A great many hifi snobs do indeed like the Statements. I'm sure folks that aren't hifi snobs like them too - I know a few of those folks, though I suspect most of us here would self-identify as a hifi snob. I've not heard the Statements, but I've met Jim and trust his ear. If he says that's not the speaker for you, trust him on that.
                                      Metal, as a genre, doesn't take as much in a speaker to render without you knowing when it's right or when it's just adding because it's already using a lot of distortion; pushing mics to their limits, etc. However, if "metal" includes "going deaf in a few months" loud, yes - you do have to pick your system with a little more care.
                                      I've pushed metal-driver systems to levels that were too loud even with 30dB over-ear protection + foam plugs; I have no idea how they sounded, nor truthfully how long they might pull that off. Far too revealing to be pleasing on crap recordings, but still capable.
                                      If you just want "blast it stupid loud" I'll second the recommendation for something based on pro drivers.
                                      • craigk
                                        • Dec 2007
                                        • 59
                                        if you want loud go get some klipsch horns that are 100 db efficent speakers and play them so loud your head explodes :T and be happy.
                                        • mph33
                                          • Jul 2012
                                          • 44
                                          For all the mini statement owners... listen to this drum recording at decent high level... not crazy loud but... enough to make your pants leg shake a little. If it sounds good... be honest and let me know. Thanx
                                          Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
                                          • NPE
                                            • Sep 2008
                                            • 57
                                            http://m.youtube.com/watch?v=3Mtp3W0nqM4
                                            I'm on crap JVC speakers and the audio quality and recording sucks balls, sounds like utter shit 8O Not bothering to play that on the Statements... So if that's the kind of crap recordings you listen to skip the statements and go for not revealing cheapo hifi speakers you can buy at bestbuy for instance... :lol:
                                            Listen to a good drum recording and it'll sound sweet on Statements though...
                                            • mph33
                                              • Jul 2012
                                              • 44
                                              Wow... are you serious? Thanx for pissing me off
                                                Youtube=Low Res.
                                                • mph33
                                                  • Jul 2012
                                                  • 44
                                                  Originally posted by Face
                                                  Youtube=Low Res.
                                                  I don't know of any other way to get people to listen... I guess download it in loss-less format
                                                  • NPE
                                                    • Sep 2008
                                                    • 57
                                                    Youtube=Low Res.
                                                    Not just that, that particular vid is at 240p, which is worst than 128 kbps mp3... Really sounded like tin garbage can...
                                                    To be fair, there was another vid of that same track that sounded drastically better, but since statements were for audio-snobs I thought I'd give a audio snob reply... :T
                                                    • mph33
                                                      • Jul 2012
                                                      • 44
                                                      I think I came off the wrong way. I wasn't being.disrespectful when I said hifi snob... it was actually a compliment. Sorry, my father is British... are humor is a little dry.
                                                      So... did you listen to the tract on your statements? There's another band that I enjoy listening to that has recorded tracts.for each instrument on the album. Its like a double me CD feature. The drum tracts are recorded very well and the sound is amazing! Band is called Lamb of god. I would love to hear those drum tracts.on very nice hifi system
                                                      • mph33
                                                        • Jul 2012
                                                        • 44
                                                        • Squidspeak
                                                          • Jun 2012
                                                          • 35
                                                          At our last IRA meeting we were trying to decide between the Statement
                                                          Monitors or the Mini's while listening to the Drop kick Murphy's and could
                                                          not choose one over the other. AOH
                                                            • 3815
                                                            I hate to disagree with Jim at all as he is the man on them but I built four of the Statements Monitors and while I do listen to plenty of hifi "snob" stuff I definitely also jam out with some loud rock/metal music on occasion too and must say they do very well, and with plenty of bass. I speak from the perspective of not building anything else, and not to mention not having the ideal room setup. I do, however have four of them along with the Statement Center hooked up to an Emotiva XPA-5 and listen to pretty much every genre of music and very loud sometimes. Just my $0.02 (and yeah it's only worth $0.02 :P)
                                                            By the way, what components are no longer available??!?
                                                            -Chuck
                                                            • mph33
                                                              • Jul 2012
                                                              • 44
                                                              Very good to hear! Im still torn between the monitors and the minis. I do like being able.to place the monitors next to the wall, but... if the sound stage and bass is stronger with the minis... I have to go that route. I don't want to compromise with this system.
                                                              As far as drivers not being available... I just checked. Their all available. I'm ready to pull the plug with this deal. I need to start on this ASAP!
        • 3815
        Well keep in mind there may be a much better design for what you're wanting. I just wanted to throw it out there that the Statements Monitors can rock the house pretty well as far as my experience has been with them (had them about three years).
        -Chuck
        • mph33
        • Jul 2012
        • 44
        I think the minis are set in stone... anyother suggestions before I pull the plug?
        • Silver1omo
        • Sep 2010
        • 430
        The tarkus look good:
        Ivan.
        • mph33
        • Jul 2012
        • 44
        that's pretty nice! wonder what would be a good center to match up with that beast. I imagine an emotiva xpa5 would powering those towers biamped would work well... along with a center
        • kmibb
        • Apr 2010
        • 24
        No need to buy a multi-channel amp just to bi-amp. Just get an XPA-2 or a couple XPA-1 monoblocks and you'll be better off.
        • Mr.Ed
        • Apr 2012
        • 55
        You have a PM.
        -Ed
        I also have an XPA-2 for sale if. You're interested.
        • rj45
        • 31
        well, a contrarian
        I've built the mini-statements several years ago, and they are a true reference speaker for me - able to reproduce the finest nuances as well as pump some pretty hard hitting bass and drum action.
        That said, I turned them up real loud (14 x 16 x 8 living room), and they seemed to run out of steam around 106 dB according to my RatShack SPL meter. Maybe not quite the sound volume you're looking for.
        If you want to get down with some metal, I'd suggest either the MagnaCumLaudes or the Stentorians:
        http://speakerdesignworks.com/NS6project_1.html
        The Stents will need a sub, they roll off around 70 Hz.
        http://stories.parts-express.com/stories/2444-en_us/category/Speaker/story/16649/redirect.htm
        regards,
        don
        • mph33
        • Jul 2012
        • 44
        regards,
        don
        Man... both if those links don't work
        • Silver1omo
        • Sep 2010
        • 430
        Ivan.
        • rj45
        • 31
        sorry, looks like someone fixed them for me.
        • mph33
        • Jul 2012
        • 44
        and the second link doesn't work... just goes to the partsexpress projects page
        • BeerParty
        • 475
        It works for me, it takes me directly to the MagnaCumLaudes project. What browser are you using? I'm using Firefox.
        My AviaTrix Build
        • mlammert
        Mark's Statements to Statement IIs Build Thread
        by mlammert
        In 2008, I can't believe it has been that long, I took the long and rewarding journey of building a very modified set of Statements.
        https://www.htguide.com/forum/showth...s-Build-Thread
        After much research and contemplation, I have decided to upgrade...
        12 October 2021, 10:42 Tuesday
        • Mikerodrig27
        Bordeaux Speaker Kit Build
        by Mikerodrig27
        I just recently finished building the Bordeaux speaker kit by Jim Holt and Curt Campbell. It is a great kit with a great set of plans. Very refined and thorough. Jim was available to answer questions and took the time to Email me information as well as pictures of his build process.
        They...
        30 March 2020, 16:47 Monday
        • grubby
        Mini Statement Build
        by grubby
        Over the last year I have been searching the Web for speakers to be used for Music and in a Home Entertainment System. I read the reviews on everything from Rockets to the Salk Sound Towers. Speakers like most things have almost a cult like following. I was confused with what to purchase and since...
        15 August 2008, 11:29 Friday
        • kirknelson
        Kirk's NatalieP Build
        by kirknelson
        I actually began this build about a week ago but am just now getting around to posting about it.
        Ultimately I plan on using the NatPs as surrounds in a system with Khanspires and a WTMW Center up front. Since I'll be using them as surrounds on stands, I chose to build the cabinets to the...
        04 April 2009, 17:35 Saturday
        • DocNice
        Statements II Build Thread
        by DocNice
        Budget:...
