I would like to build a pair or two of surround speakers to go with my Statement Monitor/2RCC front stage. I want something that can be wall mounted and not protrude into the room significantly. I may also design a sort of post that they could be mounted on so that I could pivot them once mounted but I'm not sure on that. Preferably, I would like it to be maybe 6" deep or less. Looking through existing designs I haven't seen anything that fits the bill except the In-Kahns which I think may be overkill. Are there any designs that can be altered to a reduced depth cabinet that would work? I know I would have to keep width the same but maybe if I could add to the length? The full range Lineups could work if I could reduce box depth in them. If I can't find something to build I am going to be stuck buying some in-ceiling speakers to serve as surrounds.
Thanks for any ideas.
Matt
Matt
