Hey all,
I'm thinking of trying my hand at designing a small wall-mount speaker. This would likely be used for satellites in a 5.1 system, or wherever I need a small set of decent speakers. I like Zaph's "Slimline Wallmount" design, however the Aura driver is out of stock, and I have no interest in using Aura drivers given the history of supply issues.
My inclination is to use the Dayton ND20FB-4 tweeter and RS100S-8 mid crossed over around 3.5kHz, with the drivers spaced as closely as possible.
The main question I have regards BSC. I know that with the wall-mount design there is minimal (if any) baffle step to account for. When designing the crossover, is there any use in simulating the baffle diffraction ripple and applying that to the infinite baffle frequency response? I assume that the small amount of ripple wouldn't even be worth adding to the response before Hilbert transforming to extract the phase, thoughts?
This will be my first attempt at actually designing a decent crossover, I don't expect that it will be perfect (especially given my lack of test equipment) but I'd like it to be as good as possible.
Ed
Ed
