Deleted.
Deleted.
Well, there is much more than the Kits. In the Mission Accomplished section, there are several designs that have been built by many people and receive very good acclaim. Some have been compared to some good commercial speakers and done very well or better. Any of these are recommended. All you have to do is follow the recipe in the thread. Other websites have some great designs also, such as zaphaudio.com.
Kits should be discussed with the kit seller and not really here. See the rules.
First thing you need to tell us your budget. If you like big, sealed 3-ways, then I would highly recommend my Khanspires. They sound fantastic! Will work well with your subs, as that s how they were designed. If you're in Chicagoland, you're welcome to come by for a listen (which is why you should put your general location in your profile).
The Statements are another big 3-way, but use a ribbon and are ported, but they sound good also.- Bottom
This is an incredibility broad set of questions. And the fundamental answer is we choose speakers the same way you chose your Butler amp. We try drivers until we find ones we like.
Some of us have been doing the DIY speaker thing for a very long time (40+yrs in my case). This mean we've been exposed to many, many drivers.
You cringe at the thought of experimenting with different drivers, but post a long list of assembled speakers you've owned. DIY is a similar process. If you don't want to engage in that process buy more Snell XA1900s..
by daniel4381Hi, This will be my first try of building a speaker, but I am confused in selecting the kits. I have a Bose Acoustimass 10 for enjoying movie that is powered by Onkyo NR 727. According to my experience the performance of Bose for listening music is awful. I have another receiver that is Yamaha rxv 595...-
Channel: Mission Possible DIY
by spiritedMy friends are audiophiles like yourselves, and have asked me to build them a couple of speakers. I am recently out of work technician, trying to find a job in the Montreal area to no avail. It was suggested to me (thanks Andrew) to try my hand at speaker kits instead of starting from scratch.
by ThomasWOver the years we've attempted to have discussions regarding the various kit speakers offered by vendors. Almost without exception these threads have ended up locked. As a result we're going to prohibit discussion regarding any kit loudspeaker.
Why?
1) Some vendors view...-
05 January 2007, 00:12 Friday -
New info about the kits:
http://www.zaphaudio.com/ZA5/
Also, Madisound is starting to update their website with them.
Questions/Statements:
1) Why is sealed an option only for the TM and not the other variants?
2) Another good...-
by crytklmassI Would like to DIY an amplifier (no special requirements) but im not sure what the difference is between these two kits. Which one will sound/perform better, does the Toroidal power supply make a difference in relation to sound/power? They are both Class D however kit A only supports 200wpc @ 4 Ohm...-
- Loading...
- No more items.
