ACOUSTA-STUF vs. Pillow stuffing from wallyworld
  • digital desire
    • 250
    Any thoughts on this?
    I have to place another order for my wwmt's (using the link above )
    And for the wwmts/plus matching center, I am looking at about 3 pounds of it. Maybe the 5 lb bag.
    I don't want to cheap out, because I have not yet on this project - I'll have about $1600 or 1700 into the project all together (had to hire out the mdf work). But I can't help but think it is just pillow stuffing!
    Opinions?
    Peter
    Syracuse, N.Y.
  • jkrutke
    • 590
    I used to think the same thing, but it's not just pillow stuffing. Acousta-Stuf is made of large trilobal fibers while Dacron is smaller round fibers. The former does a much better job of damping and absorption. I don't use Dacron anymore because I've actually heard the difference and have been able to see it in some tests.
    Zaph|Audio
    • digital desire
      • 250
      I did find this just now, dealing with pillow stuffing.
      But I certainly respect your opinion John. I figure 3 lbs of the "stuff" for a complete set (3) of the wwmt's and center.
      Peter
      Syracuse, N.Y.
      • Mazeroth
        • 422
        With $1600 to $1700 already invested I would definately spring for the Acousta-Stuf. That way you'd never have to second guess your decision. :T
        • jkrutke
          • 590
          For a bit more information, (a little on the technical side) see this final update to one of Ken Kantor's old blogs before he moved to a different blog.
          My own experiments have revolved around using a certain weight of each type and observing a high resolution ungated response measurement to guage dip/peak combos resulting from internal reflections. Zooming in to the midrange with a measurement of no smoothing or gating can really show a lot. Personally, I was more concerned with midrange box reflections than the effects on the bass tuning.
          Zaph|Audio
            Zaph, have you compared acoustastuff to fiberglass?
              Besides, wally-world is evil, even more evil than Evil Twin. You shouldn't shop there. :P
              • digital desire
                • 250
                The BORG.
                You will be assimilated.
                Peter
                Syracuse, N.Y.
                • warnerwh
                  • 261
                  According to tests conducted by Vance Dickason in The Loudspeaker Design Cookbook good old fiberglass works very nearly as well as acousta stuff and is much cheaper. Fiberglass is one of the best things you can use for stuffing. The little those of us are using it I doubt it's any health hazard especially if you wear a dust mask.
                  • jkrutke
                    • 590
                    I agree, fiberglass works better than Acousta-stuf. I just hate handling the itchy stuff.
                    I pretty much just use Acousta-stuf in sealed boxes, Sonic Barrier in smaller vented boxes and Whispermat in large vented boxes.
                    I recall some stuff called Miraflex from Owens Corning, but it was discontinued before I got a chance to try it out.
                    Zaph|Audio
                      Miraflex was great, much nicer to work with compared to standard fiberglass, it's really a drag it was discontinued....
                      • speedle
                        • 103
                        IIRC, wasn't Miraflex just a wrapped version of the regular stuff? I didn't think you could use it in speakers because of that very reason.
                          Miraflex fiber was created using proprietary bi-component fiber technology
                          in which two different types of glass are fused together into a single
                          filament. Unlike traditional fibers that are straight, Miraflex fibers have
                          a random twist, resulting in a virtually itch-free glass fiber that's also
                          highly compressible
                          With any encapsulated 'glass', one removes the plastic wrap when using the product to damp sound waves.
                          • Paul H
                            • 904
                            Why aren't people using mineral wool insulation (ie Roxul) for speaker stuffing, diy sound absorption panels, etc? It tests at least as good or better than the fiberglass 'pink stuff' for sound absorption and isn't itchy.
                            • Amphiprion
                              • 886
                              In my very limited experience in testing stuffing, wally world stuff was effective enough to totally ruin the Ql of a vented box at 50% fill (it was just a for-the-hell-of-it test, I don't stuff vented boxes as a matter of practice ) I've got a sealed RS315HF in a high-Q box that I've been intending for a Linkwitz Transform project (now that I have access to PCB design software and a PCB mill at work ). I might fiddle with measuring polyfill vs. fiberglass effects as I have both laying around. Anyone wants to send me some acoustastuff and I'll toss it in the mix.
                              • Amphiprion
                                • 886
                                I also wonder about the lack of use of mineral wool, at least for acoustic treatments and box lining. I have no experience working with it, but it's waaay cheaper than OC703 and just as available if not more so. I've been quoted 88c/sqft USD for 4pcf 4" thick mineral wool.
                                  Kid, our Thinsulatetm not only is a thermal, but an acoustic insulation:
                                  3M applies science and innovation to make a real impact by igniting progress and inspiring innovation in lives and communities across the globe.
                                  I've got a bag in the form of batting. How much of it do you need in order to test it?
                                  • Amphiprion
                                    • 886
                                    The box is 15.5" cubed externally built with 3/4" MDF, however much it takes to stuff it at the density you want (1-2pcf?). I forget what the net internal volume. We could do this real easy whenever I get over there to test stuff. I'll just drag the box and driver along, don't need the LT done for tests like these.
                                      Sounds good - bring 'em along. I've got six new drivers for us to test.
                                      • TacoD
                                        • 1080
                                        The link is an interesting read, recommended.
                                        • edwardj
                                          Question on Polyfill stuffing
                                          by edwardj
                                          Good evening,
                                          I have probably a really dumb question on the best way to stuff polyfill in the sub I am building. I am building the Adire alignment sub from the plans from the Acoustic Visions site. In the instructions it states to stuff the cabinet with 64oz of polyfill stuffing....
                                          27 June 2007, 20:48 Wednesday
                                        • zjeff222
                                          Questions for my Khancenter build (padding/stuffing and crossover placement)
                                          by zjeff222
                                          I chose the Khans for my HT system. I'll start with the center because my current one is tiny while my current towers are, well, towers I already built a subwoofer box but I have no experience with loudspeakers.
                                          I only have a few questions left.
                                          1. Padding/stuffing: which...
                                          01 November 2014, 18:43 Saturday
                                        • madmac
                                          Stereo outdoor pillows??!!
                                          by madmac
                                          Hey all,
                                          I bought this speaker pillow (yes...who would have thought that this kinda' thing could exist!!) and I must say, it's pretty neat!!. Basically, it's a battery operated speaker pillow that you connect your audio device to via it's 3.5mm audio jack on the side and it plays your...
                                          09 May 2012, 17:47 Wednesday
                                          Logan's Run & Other Titles @ WalMart for $5.99
                                          by David Meek
                                          Hi all. The subject line says it all. WallyWorld is having a clearance on many not-so-popular titles. In fact there is quite a selection at $9.99 also. One good note: the Logan's Run DVD is anamorphic 2.35:1.
                                          With a little searching you might find that gem . . .
                                          11 April 2002, 13:31 Thursday
                                        • George Bellefontaine
                                          One from the bargain bin...
                                          by George Bellefontaine
                                          THE BIG EASY
                                          I got this at Wallyworld for $6.88. It wasn't anamorphic and the transfer was probably the same one used for the vhs tape and the laserdisc, so it wasn't the best, folks, but adequate; as was the soundtrack. No 5.1 here and no LF.
                                          For those who haven't seen...
                                          05 March 2004, 12:01 Friday
