I chose the Khans for my HT system. I'll start with the center because my current one is tiny while my current towers are, well, towers I already built a subwoofer box but I have no experience with loudspeakers.
I only have a few questions left.
1. Padding/stuffing: which surface should I pad, and/or which chamber should I stuff? I guess stuffing is easy to try but padding is not easy to change once the speaker is built. I'm not even sure I would know what to listen to make adjustments. So what do you guys do?
2. Crossover placement/fixation: I plan on having 3 boards fixed on the back walls. This would place them directly behind the drivers, so I'm not sure it's a good idea if the enclosure is padded and not stuffed. I chose this placement base on accessibility and induction between coils (crosstalk). So what would be the best placement?
