OEM Bose cube beater or cure for the MTM blues?
  • AJINFLA
    • 682
    Looks like something that could be used to create a true Bose cube sized design if you (or more like your wife) had such an inkling.
    More useful IMHO would be used as a T in a MTM LCR with a low xo, preferably below 1k to avoid some of the off axis chaos I abhor in the typical design, especially centers.
    A few others http://www.tymphany.com/products_Peerless.html
    The question of course is whether they become available to DIY like some of the other former OEMs like the TG9's.
    Hope I'm not redundant posting this, but here are the LAT's as well.
    cheers,
    AJ
    Manufacturer
    Hmmm, a 1.5" dome with a 2" frame. No way it's a fullrange driver but it might be a pretty good mid-tweet.
    • joecarrow
      • 754
      Yes, it might be an interesting alternative to the 2" tweeter used in the Linkwitz Pluto. If it's like that tweeter and the Hi-Vi B1S that Zaph recently tested, then it will be fairly sensitive to the enclosure. I'd expect a stuffed terminated tube to be a good thing to try- but we'll need to get some aluminum plate.
      -Joe Carrow
      • PMazz
        • May 2001
        • 861
        Look at the sensitivity! It'd be the first time you'd have to pad down the midwoofs in an MTM.
        Pete
        Birth of a Media Center
        • AJINFLA
          • 682
          Shame on you Dennis. Don't you recognize what that is? It's a twiddler .
          Pete
          True Pete, but I figure most of those small speakers (like the Bose Buster thread) are going to be low sensitivity with the smaller woofers and diffraction losses from the small baffles. Maybe flank it with a pair of NS4's crossed @ 800hz.
          That's just me thinking out loud if I were forced at gunpoint to do an "MTM"
          cheers,
          AJ
          Manufacturer
          • jdybnis
            • 399
            The classic bose formula is a pair of drivers on each side, against a wall or in a corner. I think these drivers could pull off 150Hz under those conditions. Max SPL would be in the upper 90's but that is all HTIB systems do. The "Acoustimass" cubes are actually big enough for 3" drivers.
            -Josh
              Bose (I know) TriPort OE Headphones.
              by Hdale85
              Just wondering if any of you have listend to these? I heard them at a local store the other day on the little demo thing and thought they sounded really good. Goes way low, seemed to have a pretty good balance of bass mids and highs though.
              Bose TriPort OE
              I know that bose...
              12 December 2006, 02:07 Tuesday
            • Preacherman
              Bose ?.....don't hurt me.
              by Preacherman
              Hello all, time again to pick ya’lls brain. I have just received a Bose Lifestyle 12 series 1 system (1996 model) as a hand me down from Mother.
              OK...I know that Bose is not at all anything spectacular.
              Right now within my budget theater I have a Onkyo 801b 7.1 receiver....
              31 July 2006, 12:40 Monday
            • 123Toid
              Cube Cubed - A Passive Radiator Build
              by 123Toid
              I have always loved passive radiators, so I thought I would finally do a build log along with all the parts needed. Thanks to Parts Express, I am able to bring one of these Passive Radiator Builds to life. My goal was to make a small subwoofer that would still have high spl, for a smaller room all...
              26 July 2017, 21:44 Wednesday
            • mackintire
              Starting my first project, something like the Bose Buster only bigger
              by mackintire
              I 'm working on a project to replace the speakers that came with my Onkyo HT-800. My wife has decreed that they do not match the furniture.
              I started out by looking that the Bose Buster project with with a 5.1 setup in mind. Then I got it into my head that I could do better. So here...
              13 January 2009, 18:42 Tuesday
            • DeathMonk
              Bose Buster 5.1 Setup Done
              by DeathMonk
              Built these for a friend.
              Bose Buster 5.1 setup (Sub is 2.0-2.1cu ft. sealed RSS315HF+500W plate amp). Being delivered today.
              They really exceeded my expectations. Really makes me look forward to the Bose Buster V.2's. Props to Brandon....
              26 September 2009, 15:42 Saturday
