I 'm working on a project to replace the speakers that came with my Onkyo HT-800. My wife has decreed that they do not match the furniture.
I started out by looking that the Bose Buster project with with a 5.1 setup in mind. Then I got it into my head that I could do better. So here goes.
The mains are in two parts The top is MTM with the dayton DB20's and (2) HiVi B4N's in cabinets that are 15" high, 6.5" wide and 9" deep.
I 'm going to start things out by doing two things at once. Modeling the setup with the origional bose buster X-over in LSP-cad and at the same time planning on doing my own thing using 4th order LR crossovers.
The two mains will sit on cabinets that not only act as stands but have side firing woofers. The woofers are 6.5" and are from Klipsh promedia 2.1 units that had damage elsewhere. I 'll have to test the speakers to get the exact specs but in general they will probably be crossed over around 120hz with extension down below 40hz in their vented cabinet, I'm using the volume of the origional cabinet. The Klipsh woofers are 4 ohm and 50 watts each. Their cabinets will be 3/4" MFD 25.5" high , 6.5" wide, and 9" deep.
So so far I 've selected drivers and tinkered with CAD modeling the cabinets.
The Center Channel speaker is giving me more design problems. I'm trying to figure out a way to extend the response and still fit everything my constrained box size 18" wide, 7.5" deep and 6.5" high.
I was thinking about doing a WWMTWW arrangement via 3.5 crossover.
That being Tweeter (6 Ohms) Mid (8 Ohm) Two woofers in parrallel (4 ohm) with the final two woofers being parrallel in series, X-over around 120hz so that at 60hz the sum load will be back to 8 ohms. I 'll have to do more modeling to see where this goes. But the idea is as the frequincy goes lower more of the load is redistributed to all four of the woofers so at some point all four are being equally driven at a 8 ohm load. At 300Hz the second set are not being driven and the unit acts near identical to the Center channel design used in the Bose Buster project. I tried to model it as a vented enclosure, but that did not work out very well. I 'm thinking of used the a resistive port instead.
Ok small update: I think I've settled on using the origional design with a resistive vent. -3db should be right below 80hz.
Any thoughts Ideas?
This project is kind of a long term. I should have the cabinets assembled within the next 3 months and some driver testing done while things are coming together. Also I need to ask. Is there a design issue with the Bose Busters in regards to the placement of the tweeter? I know I am going to have different baffle related issues, but can I prevent any of it by offsetting the tweeter?
Any thoughts Ideas?
