Wall mount brackets...
  • nelsondog
    • 9
    What are you using to wall mount your speakers? I'd like some to tilt and pan easily but hold tight when the correct position is found. The enclosures will be same as the PE .25 cf. Any recommendations?
    Brian
    Brian
    Here's the one that I use. Over kill for a .25 cabinet though.
    • chasw98
      • 1360
      Check out Omnimount's "Pro" line of mounts. They work very well and will not come down. Little bit pricey but worth it.
      Chuck
        I use some Premier (a Paradigm company) wall brackets. Got them from my local Paradigm dealer for $27 total. They work well. They are the common ball and socket design, so they allow movement in any direction. I tighten them down with a big wrench and they don't move. I think they are rated to support up to 30 pounds.
        Probably not the cheapest solution, but easy to get your hands on and look at.
