Pls Guide: 4K Display TV: Size, Mount, Ideas - Tilted Angled Down, Corner, Flush to wall
Please advise on 4K Display TV - Size + Mount & mounting ideas - Tilted Angled Down, Corner, Flush to wall
Suggestions on TV size & Mounts/ ideas on designing & implementing this correctly.
Will mostly be using this for computing - no gaming - Serious work with high res 4K space.
Needed Positioning Scenarios:
- Display TV can be Tilted/ Decline Angled appropriately | Much above head mounting
- Need variable/ changeable decline Angle / tilt to find sweet spot
- As I'll be sitting on chair back reclined at 135 deg:
- Why? - Anti Slouching Posture; Neck, Spine & Shoulder saver
+ Standing usage as well - Have an Ergotron arm for that
- Rotate Display in Corner at 45 deg to both Walls - Pos.2
OR
- Rotate Display to be Flush parallel to a Wall/ Walls - Pos.1, 3 & 4
Will probably put whiteboard paint/ coating on Walls for use
Based on the tools/ articles on: http://www.rtings.com/tv
TV Size to Distance Calculator and Science
Based on TV Size - Widths here, I could fit these in 51/ 52" of Wall to the right.
42" 36.6"
46" 40.1"
50" 43.6"
55" 47.9"
But the larger it is the more front space it takes up when at 45 deg in Corner - Pos.2
Plan, Elevation & Dimensions attached {Do ask, will update if I missed something}:
Right Wall: Brick - Thicker - Probably Stronger?
Back Wall: Siporex Board - Slimmer wall - Will check with Archi/Engg of its load capacity
SIPOREX' - lightweight Autoclaved Aerated Concrete (AAC)
Manufactured from the same components as conventional concrete: cement, sand and water in addition to aluminum powder and other
additives
PS: I must go 4K for Computing Resolution even if Video hasnt caught up yet
OR
42" 36.6"
46" 40.1"
50" 43.6"
55" 47.9"
additives
. Unfortunately i don't have his skills and don't have access to the same kind of equipment....
