Baffle Width
  • berlin07
    • 19
    Baffle Width
    Hi all. I am starting box construction on the Modula MT's,Natalie P's, and the
    RS CC this weekend and have just a few questions on baffle width. I want to copy dCraig's design https://www.htguide.com/forum/showth...hlight=natalie but am not sure of the affects that the angle cut sides have on baffle width, diffraction, etc.
    1. Is the front baffle width calculated from the end of the tapers or from the actual width of the sides?
    2. Are there any negative effects with using tapered cut sides as in dCraig's design.
    Last edited by theSven; 17 August 2023, 00:47 Thursday. Reason: Update htguide url
  • TacoD
    • 1080
    Tapering or a fillet has a positive effect on baffle diffraction, how larger the radius the better (within reason ofcourse). Normally the dictating width would be the width between the sides (as if no tapering is applied).
    When the sharp edge is smoothed (by tapering or filleting the corner). The sound waves propagating near the corner are less affected to this abrupt change. Obviously the high frequencies with corresponding small wave lengths benefit from this.
    Check Linkwitz' informative site for the physics behind this.
    • berlin07
      • 19
      That was a great read. Thank You TacoD
      • JonW
        Some things I learned from baffle diffraction simulations
        by JonW
        I'm designing my first speaker, a simple 2 way MT, and I’m currently looking into various cabinet styles. How might one best control baffle diffraction effects? There are two good free programs out there: Edge and Baffle Diffraction Simulator (BDS). I’ve been trying out various baffle designs to...
        21 February 2007, 12:09 Wednesday
      • Saurav
        Open baffle plan/layout
        by Saurav
        I'm trying to figure out how to design my OB to minimize the amount of cutting I need to do (since my woodworking skills are close to zero). Drivers:
        * 12" woofer
        * 6.5" midrange
        * 10" WG (probably)
        Based on advice in ABCDipole, I'd like the baffle...
        10 June 2008, 10:05 Tuesday
      • JoeAngelicchio
        Quick Question, what is baffle step?
        by JoeAngelicchio
        Just wondering what this was. Is there a glossary somewhere on this forum that lists some of the terminology?
        Joe
        14 February 2009, 13:38 Saturday
      • dsrviola
        Wvaeguides and edge diffraction frequency
        by dsrviola
        Since I didn't get much response (just one) over on the PE board, I thought I'd try over here. Here's my query: Can anyone point me to a formula or a discussion on how to determine what the diffraction frequency of a given baffle width with a waveguide of a given depth? Or is it depth and width of waveguide...
        02 June 2012, 11:29 Saturday
      • Eton
        Baffle diffraction step Vertical vs. Horizontal ?
        by Eton
        When designing a Baffle diffraction step, all calculations are based on width of the baffle the assumption that the speaker is placed vertically.
        So, we have a perfect x-over that has the baffle step for reduction in high frequency at a calculated F3.
        Now what happens when the same...
        01 October 2007, 20:08 Monday
