I'm trying to figure out how to design my OB to minimize the amount of cutting I need to do (since my woodworking skills are close to zero). Drivers:
* 12" woofer
* 6.5" midrange
* 10" WG (probably)
Based on advice in ABCDipole, I'd like the baffle around the midrange to be ~12" wide, and I'll keep the driver centered. Not sure about the tweeter yet, I don't know how much baffle edge diffraction is a factor with a WG/compression tweeter.
I'd initially planned on a trapezoid, narrowing from 16" on the ground to 12" on top, but there's no way to get that cut at Home Depot, so it would be up to me to get clean cuts for that. Instead, I've been thinking about something like this:
The lower part is roughly 16" square, and I'll probably put some wings on the sides for stiffness (and increased baffle width). The upper part is 12" wide, which should be an easy size to get. I was thinking of extending the narrow baffle down to the ground and gluing it to the back of the lower baffle. That gives me extra thickness around the 12" driver, and should hopefully be attached well enough to the lower baffle. I might make the upper baffle 14" wide instead of 12", that might make it easier to cut the woofer hole in the doubled thickness.
Does this seem doable? Or will I run into any construction issues I haven't thought of? I've modeled this in EDGE and the response isn't too far off my trapezoid baffle.
* 12" woofer
* 6.5" midrange
* 10" WG (probably)
