Need a good amplifier...need suggestions
  • jmcox44
    • Nov 2006
    • 10
    Ok, so I finally bought all the parts to build the modula MTM and will be undering going the project in about a week, and am confused about a few things. First thing, I think I just realized that my receiver will not be compatible with it. I have the Onkyo TX-SR573 and read that it puts the power out into an 8-ohm load....so my question is whether the modula MTM is an 8-ohm speaker, or if my calculations are correct and it is a 4-ohm speaker.
    If it is an 8-ohm speaker then I am fine and I'll worry about a new amplifier later. If it is a 4-ohm speaker then I need a good amp and need some suggestions. My budget is probably $200 or around there (I'm ok with used amps). What I was thinking was that a 3 channel or 5 channel would be good for me. I do plan on building the MTWW Fronts sometime in the next year so if I'm going to buy an amp I'll probably go for a good one.
    All I'm really looking for is the first question and then some suggestions.
    Thanks in advance.
    Jacob
    Well the Modula MTM is a 4ohm speaker. And weather your receiver can handle that or not I'm not sure. Some do some dont. As for a 3 channel amp for 200 bucks? Good luck. You could get this it's probably the best your going to do for 200 bucks. http://www.parts-express.com/pe/psho...number=248-749
    Free shipping too.
    • Marzen
      • 302
      Jacob,
      You're correct in that the Modula MTM is a 4 ohm speaker; and I wouldn't worry to much about using it with your Onkyo receiver. I've run these same speakers on my inexpensive JVC reciever with no problems; it's spec'd for 8 ohm speakers also. There is a shut down feature that will protect the amp if you drive it too hard.
      Assuming you're going with the RS28A tweeter:
      ...and as Jon mentions "Impedance curve is reasonably benign, but if the drop in the upper frequencies bothers your gear, then just pull the tweeter comp series RC", that being R6 & C11.
      -Ward
      Last edited by theSven; 13 December 2024, 07:19 Friday. Reason: Update image location
      What if the Hokey Pokey really IS what it's all about?
      • jmcox44
        • Nov 2006
        • 10
        dougie085, thank you very much. I might actually look into that amp for when i pursue the fronts and need to power them with more than 75 watts a piece. Do you have any other recommendations for amps in that general price range, new or used, that would be better? Thanks again.
        marzen, you are correct with the rs28 tweeter. I guess i will just follow through with the project and hook it up and see how it sounds. I don't normally go too loud due to living in a duplex and only having a 22' x 12' x 8' living room where this will be playing. Thanks again.
        • Brian Walter
          Modula MT or MTM with RS10 Sub?
          by Brian Walter
          I would like to build either the Modula MT or MTM and cross it actively over to a pair of Dayton RS 10" HF subs (one for each MT or MTM). I have numerous questions, but primarily I'm wondering what would be the best match for the 10" sub, the MT or the MTM and what frequency would you recommend...
          24 September 2005, 17:13 Saturday
        • Cool Mr Steve
          Modula MT vs MTM
          by Cool Mr Steve
          I keep asking dumb newbie questions on this forum, and I apologize for that, but I've got one more for now... What are the benefits of using two midwoofers as opposed to one, as in the MTM vs MT. Would I be correct in assuming that the MTM has noticeably better sound quality than the MT? Are there tradeoffs...
          31 October 2006, 04:38 Tuesday
        • Efalegalo
          Questions Re - Measuring MTM for Crossover-Modeling in VituixCAD:
          by Efalegalo
          Hi All,
          Working on my first DIY MTMs and wanted to begin by first confirming the measurement technique that should be employed.
          I’ve read through the “Measurement Preparation with ARTA” document, but still have a couple of questions (included below). I think...
          11 November 2019, 14:23 Monday
        • bobhowell
          What will 15w/4ohm amp drive
          by bobhowell
          I am looking at a a 2x15/4ohm watt Pyle amp from PE, for my daughter. I want to understand just what it will drive. Also, HD seems high, but I guess its ok.
          I made Zaph's BAMTM which is 4ohms. Will it drive that? Or ZBM4/8ohm for the short term?
          I am looking at eventually...
          09 December 2008, 08:07 Tuesday
          by cjd
          By request, this one's for Jagman.
          Fronts (the Ansonica)
          Max total height, 36"
          Use the new Exodus Anarchy, to be a 2.5way TMM.
          Surrounds (the Marsala):
          Use what I learned on my own surrounds
          Selected tweeter:
          SB-Acoustics SB29RDC-C...
          08 January 2010, 17:18 Friday
