Bottles as bass traps?
  • cdwitmer
    • 136
    I have been reading an article from a 1972 Japanese audiophile magazine about using bottles of various sizes and shapes to absorb frequencies in the low midrange and upper bass region. The author was primarily doing tests to show how their use inside an enclosure could help precisely eliminate a speaker's peaks and dips and thus create a flatter frequency response, but he also mentioned that judicious placement of empty bottles around a room could also improve the sound of the bass. (Perhaps that explains why my system always sounds better after I've been drinking.)
    Does anyone have any experience with this approach? And are there any good information sources available in English?
    Thanks!
  • joecarrow
    • 754
    An empty bottle is nothing more than a helmholtz resonator. I've heard big wine bottles with impressively low (for a bottle) fundamentals, so this could work.
    A while ago I saw some architectural windows that used helmholtz resonators to cut down on outdoor noise while allowing fresh air into a room. I couldn't find a link just now, but I did find this: http://www.trenwyth.com/aw_faq.asp
    As you can see, they don't need to be bottles. If you google for helmholtz resonators, you should find many resources. The math is simple enough that if you're able to approximate the volume of air in the body of the bottle and the volume of air in just the neck of the bottle, then you should be able to calculate something very close to the resonant frequency of the bottle.
    -Joe Carrow
    • Patrick Bateman
      • 45
      Thanks!
      Earl Geddes covers that in his home theater book. You can buy it at www.gedlee.com.
        The problem with Helmholtz resonators as bass traps is the very small area of the "ports." Setting aside the bottle thing, say you park the equivalent of a tube sub in your corner with the sub's port absorbing bass. Well if the "sub" has a 10" port, that 10" round tube will absorb all the bass that hits it at a certain frequency. But that port is TINY compared to the surface area of the corner where you place it. Effect -- almost none. Stuff the corner with fiberglass equal to the volume of the resonator and you'll have a lot better bass trap -- big surface area and it works at all frequencies.
        • Pieter
          Acoustics - The broad brush approach
          by Pieter
          Let’s see if there’s any consensus about this.
          For HT we want the front wall absorptive as low and high in frequency as possible. The rear wall diffusive and the side walls a mixed bag of diffusion and absorption. The ceiling mostly diffusive with a touch of absorption and the floor...
          06 June 2005, 02:25 Monday
        • capslock
          dual bass arrays / active traps?
          by capslock
          I read up on bass absorbing panels, membrane absorbers and Helmholtz resonators. All very nice, but with a lowish SAF. How about active traps?
          1. classic DBA (delay between arrays)
          The one thing I came accross is a DBA (dual bass array), as it is known in German discussion...
          15 August 2006, 02:23 Tuesday
        • cdwitmer
          Can I use short pipes to join two sealed subs into one?
          by cdwitmer
          I want to use two sealed subs side by side in a push-pull alignment to reduce distortion. To do that properly, I need to get the volume of the two subs the same, which is a bit of a pain since I don't have any good way of accurately measuring the displacement of the driver. Of course, if the two drivers...
          30 April 2007, 10:03 Monday
        • Bob
          Bottle Shock
          by Bob
          Very fun film that is based on true events.
          When it comes to a end you will find yourself in the nearest wine shop along with your fellow movie patrons....
          01 September 2008, 10:47 Monday
        • Denver Jerry
          On Screen Display shows EMPTY
          by Denver Jerry
          I'm trying to get to the On Screen display on the TV. On the remote, RR-1050, I press AUD, then push Menu/OSD --- Menu pops up and says EMPTY. Nothing shows on the TV screen. Yesterday a "technician" got the Menu to display on the TV screen, but was unable to make any changes using the directional...
          20 September 2011, 18:18 Tuesday
