Wire/cable Management
  • jimmyp58
    • 1449
    With all the gear I have, I have quite a rat's nest of wires behind my racks/RPTV. I am sure many of you can relate! This may be a dumb question but here goes. Does anyone know if there exists a managment system, sort of a conduit, that can be placed behind your racks/tv? I'm thinking specifically of something that not only hides the unsightly mess of wires but can shield and separate power cords, speaker cables, and interconnects.
    Please advise.
    Thanks....
    jpiscitello@ameritech.net
  • mkoreiwo
    • Sep 2003
    • 4
    I sympathize, and concur....
    I was thinking of doing something as well. I'm going to search the 'net. If I find anything wothwhile, I'll put it here.
    Mike K.
    Mike K.
      • 16478
      I keep trying to clean up the mess behind my rack but each time even with the best intentions it ends up looking horrible...there are simply too many wires running all over to try and make much order of it.
      • jimmyp58
        • 1449
        I think I found my answer. Visit the Smart Home website. They have exactly what I am looking for and it is very inexpensive. I am going to try it out to see if it works --- hey, it's only going to cost me ~ $45 so if it doesn't work, my wife won't shoot me!
        I'll report back on my hopeful success (or failure).
        • George Bellefontaine
          • Jan 2001
          • 7636
          Man I'm afraid to look behind my rack anymore, let alone trying to organize the mess. Scary 8O
          My Homepage!
          My Homepage!
          • Sonnie Parker
            • Jan 2002
            • 2876
            Here, want a real mess:
            Not sure what your rack looks like but I partially enclosed the back of my rack with painted cut outs allowing just enough room for rear connections and some air flow space. You can't really notice any of the cabling from the front view.
            Fortunately I installed PVC pipe in the walls for running cables out to the RPTV and speakers.
            SONNIE
            Cedar Creek Cinema
            DVD Collection
            BFD Comprehensive Setup Guide
              Hi Jim,
              A couple of things I've found are:
              1) Don't tightly stuff all the cables into one run of tubing. I did this with our upstairs system and some interaction between a couple (or several) of the cables caused my TV picture to degrade very noticably. Pulling the cabling back out and breaking it up into 2 separate tubes with plenty of room solved that problem.
              2) If you have extra speaker cable, don't coil it into loops as it can cause a nice irritating hum in your speakers. Run it in a long S-curve layout.
              David - HTGuide flunky
              Our "Theater"
              Our DVDs on DVD Tracker
              • Gordon Moore
                • Feb 2002
                • 3188
                If you are doing it on the cheap (like 98% of what I do), then you may want to drop in at the automotive center and look for that flexible automotive conduit. It comes in various sizes, it's black and works very well. It won't really organize anything but it does give everything a nice clean look.
                "A RONSTER!"
                • Uncle Clive
                  Former Moderator
                  • Jan 2002
                  • 919
                  Jim would you be able to put up the exact page Address from smart home you were referring to?
                  CLIVE
                  CLIVE
                  • jimmyp58
                    • 1449
                    www.smarthome.com
                    • Gordon Moore
                      • Feb 2002
                      • 3188
                      Yup that's the same stuff you can buy at any automotive center. No shipping and you can buy it today.
                      For Canadians it's available at Canadian Tire.
                      Not sure if this is what you had in mind, but that's identical to what I used.
                      "A RONSTER!"
                        You can also get it at major hardware/lumber chains like Lowe's and Home Depot, if one's available.
                        Our "Theater"
                          Double post. Sorry.
                          Our "Theater"
                            Again? Huh?
                            Our "Theater"
                            • Rolyasm
                              Connection for Speaker wire behind wall?
                              by Rolyasm
                              I have some wire run behind my wall for speaker and am preparing to finish the room with paint and carpet. The wires are extra, but I want to be able to access them later. I know I should run them through a box, but is there a face plate that I can wire to and then run my speaker to this face plate...
                              06 November 2005, 15:20 Sunday
                            • beden1
                              Classe Amps - Possible Case for Speaker Wires
                              by beden1
                              Possible case that speaker wires and balanced versus RCA connections make a difference that I had not considered.
                              This hobby is complex in nature, and it's interesting that one gets to continue learning along the way through experimentation.
                              Case in point: I have owned...
                              20 October 2008, 12:24 Monday
                            • Penningtonsm
                              Wires Wires WIres
                              by Penningtonsm
                              Hey guys. Just joined this site and I love it. So much knowledge. And since I am on it I might as well ask a question thats been kinda puzzeling me and see if I can get some help. Question is: If i wall mount my speakers what can i do to hide the wires. I have a room that i cant run wires through the...
                              19 January 2005, 20:14 Wednesday
                            • jquin
                              Science behind speaker cables??
                              by jquin
                              Hi all
                              I was looking for some links that might point out some science to explain the exotic speaker cables on offer.
                              You know we have lovely platting of the wire now and the like.
                              Now I am not ask to be redirected to the manufacturer's technobabel explanation but rather university...
                              06 July 2007, 07:12 Friday
                            • NHT
                              Lets see all the nice racks you guys have.
                              by NHT
                              Its show and tell time everyone. I need inspiration for my next upgrade and want to see your racks, be it small or large.
                              29 October 2004, 00:51 Friday
