OT: Cloning WinXP Pro installs ....
    I'm basically really lazy, so forever I've just deleted the Enum key in the Windows 98 registry and thrown in the new MB and away we'd go......
    But I was told that was not possible with XP. So the search was on........
    The results have been fruitful. I'm not using the Home version of XP, so I don't know if this technique will work for it. But I've used it successfully with XP Pro.
    Go into the device manager and set the IDE controller setting to dual channel ATA. Also set the display to a 'generic' setting.
    Now follow the instructions below regarding 'RESEALING' XP
    Solution 5; Microsoft SYSPREP:
    There is a SYSPREP tool on the XP CD.
    You will need to extract files from the Windows XP CD, files are located at CD:SUPPORTTOOLS in a cab file called DEPLOY.CAB. The files are Sysprep.exe and Setupcl.exe. Extract these files to the same folder.
    With the old motherboard still in the system:
    You run sysprep.exe and tell it to "RESEAL" Windows XP. Note that it will shutdown the PC when it completes the reseal process.
    Now pull out the old MB, install the new one and fire up the machine. It re-activates Windows XP and populates the device manager list.
    You do need to re-activate with the same key-code.
    Since this technique has been so successful; I now keep a spare HD with all my major software preinstalled as a backup. I clone this drive and use it when I setup a new PC, or change out the MB in an existing PC.
    Unlike some MB changing techniques, this doesn't result in dual entries in the registery, and it works when there are drastically different chipsets on the motherboards.
    Hope this helps ..........
    Regards
    Thomas
    • 16205
    This is a very useful trick to have dug up-
    I wonder if you could "reseal" a drive this way, then plug it into a running system as a secondary drive, and backup the image using my Acronis True Image to make a delpoyable image for restoring a PC in the household? Obviously, at least the current drive copy should cover backing this up, too.
    Still, this is a great way to be able to have an installed configuration which can be used to restore to different computers quickly in the event of a hardware problem.
    In Microsoft Knowledge base article 302577, the use of SYSPREP is documented for creating deployable images; obviously, that must be the intent, to provide the functionality which by default existed without special measures in WIN2K. It must be an issue with the activation and copy proteciton stuff, I bet.
    Thanks for passing on these tips.
      Just a guick update. First the process works with XP Home and the files are on the CD.
      Second the Reseal process can be used in 'safe mode'.
      I had a CPU fan seize. That of course fried the CPU, and damaged the MB. This wasn't an anticipated experience
      Out of despair I loaded the hard drive into a different MB and booted into safe mode. From there I was able to extract the appropriate files to a folder and reseal the drive.
      It was then installed in a completely different MB and ran perfectly.
      FYI the chain of MB's where this HD was installed in was, an old Abit K7, then a MSI nforce, then into new Albatron. That speaks well for the Reseal process..
        • 16478
        Thanks for the follow up Thomas.
          Twin Moderator Emeritus
          • 16706
          Absolutely good to know!
          Need a new display? Questions about new display technologies? Visit RPTVs, plasmas, and other monitors @ HTguide
            • 16205
            Gigabyte: It lives....
            Well, here's to re-sealing and un-sealing! :5:
            You'd think we were talking about fine bottles of wine, huh? :T
            It went pretty smoothly; the only glitch was that although the new MB had ATA133 built in (necessary for the Maxtor 160GB drive I have), it didn't want to come up properly with the onboard controller; had to pop the Maxtor supplied PCI adapter in a slot, and set it up for boot like a SCSI adapter. I also turned off the on-board audio and for now the unused RAID controllers, so they wouldn't be scanning during boots, looking for drives.
            Once that was done, it came up normally like it was a brand new system that you had to enter your Key code and personal data; breezed through that (had the forethought to check the key data before re-sealing), it re-booted, and started up normally.
            At that point I popped in the new MB CD, installed the various drivers, re-booted, and checked the config. All drivers looking good, and I'm back on the network with my original configuration.
            Running Office 2003, it detected the change in configuration, and insisted on re-activation. No problemo. My protected CAD program, OTOH, was happy wtih things as they are (maybe since it's still the same HD and same key code for XP), and runs fine.
            Mission accomplished.
            Oh, and no graphics problems at startup like the old ASUS MB. (same video adpater, same drivers)
            ~Jon
            • Anton
              Cloning Sunfire XT - Thinking out loud
              by Anton
              Hi Guys,
              I’m really interested in cloning the Sunfire XT CRM-2 for my stereo listening. They have an interesting look and possibly an enjoyable sound, If I make them right.
              From the image it appears that the planar tweeter is a Silver Flute YAG-20 (Dayton PT2B-8 ), with two high...
              09 May 2007, 08:50 Wednesday
            • kpodolski
              CDP-300 with Sony AD-7800H-01 drive issue
              by kpodolski
              Got a question for owners of a CDP-300 with the Sony AD-7800-01 optical drive.
              I picked up a basket case CDP-300 player off EBay that needed some TLC. The rubber stand offs for the optical assembly all went gooey over time. I found replacements and got that all sorted out. There are...
              25 December 2021, 19:46 Saturday
              WinXP anyone else using it?
              by Andrew Pratt
              I installed XP last night over my win98 partition. All in all it went very soothly with all devices except my TV Capture card being recognized. My inital thoughts upon seeing the new GUI is the it sure looks like a MAC OS and its sometimes hard to find familar items but once you get used to it its not...
              12 September 2001, 12:28 Wednesday
            • pcatt
              Cloning various Totem loudspeakers
              by pcatt
              HI HI!!
              I am willing to clone the TOTEM SHAMAN!!
              The biggest problem for me is the bass driver.. I can nowhere find a speaker with the same specs. Maybe someone knows which speaker is used in the bass bin of the SHAMAN???
              if you want to take a look:
              http:...
              17 January 2006, 15:31 Tuesday
            • InTheRed
              Basment Installs
              by InTheRed
              Well, I was about to upgrade my system, but it now seems I will be upgrading my residence instead. Most exciting is that the new place has a finished basement which my wife has generously granted to me to "do whatever you want with it". Of course, we all know what that means.
              09 April 2004, 12:31 Friday
