First, I am an experienced W2K user. But this Abit Raid board, Quantum drive, 512 meg ram, Asus 8200 Ge-force 3 system seems to have problems learning who's boss here. 3 installs, 2 with fresh formats, tried raid 1 fresh install with format, now trying striped or raid zero after fresh install and formatting the 2 40 gig quantum drives as one big drive. But read on:
1. When I go to restart the computer, (shut down but restart option) after windows has been running, it just sits there idling after shutting down to the point he should reboot, monitor is on standby, and it won't restart (boot) until I hard power it off, and back on. However, he will Auto-off when I shut it down properly.
2. Network connectivity: Initially, after lan card installed (tried 2 different cards, an Intel and another, as well as 2 cables, and multiple ports on the hub), he may see the cable modem, (fixed IP), and it's even capable of initiating the login. This process does require 2 way communication. But then, before he gets to the point he says connected, the lan connection dies, and it sees nothing else, and receives nothing else. However, the other computer on the hub does see it, and the modem is connected just fine. It seems that rebooting is the only sequence that makes it so that you can see the cable modem again, but again, it won't ever actually access content. He just freezes up on the receiving end of the protocol (TCP/IP)
I have not done an upgrade of W2K, applying patches. Honestly, I need the net connection before I can gain access to do that. However, I did confirm network card settings and paralleled my main computer which works like a champ.
W2K install appears successful, running in stripe mode (after first trying raid 1) The above problems held through 3 installations. Very perplexing. I am wondering about Mboard issues at this point, honest.
Of course, I can put a modem in and back up to a 56K connection if need be for loading W2K updates.
Lex
Lex
